Home » Archived » M2M (model-to-model transformation) » [qvto]how to run qvto stand-along(how to run qvto stand-along)
[qvto]how to run qvto stand-along [message #846525] Mon, 16 April 2012 02:21 Go to next message
Hi, now I do my transformation within eclipse. How can I write a stand along Java project, the input is the source model and the output is the target model?Is there a jar library or else?Is there a sample project?
Thank you very much.
Re: [qvto]how to run qvto stand-along [message #846700 is a reply to message #846525] Mon, 16 April 2012 04:57 Go to previous messageGo to next message
See http://www.eclipse.org/forums/index.php/mv/msg/299364/807941/#msg_807941
Ed Willink
> project?
Re: [qvto]how to run qvto stand-along [message #853264 is a reply to message #846700] Sun, 22 April 2012 18:14 Go to previous messageGo to next message
Hi, thank you very much.
Where can I find the latest codes of qvto?I download from eclipse website, but there is no plugin.xml for qvto.I want to read the codes after I select the source, target in the UI and before you call the executer.
Edward Willink wrote on Mon, 16 April 2012 04:57
See ...
Ed Willink
> project?
Re: [qvto]how to run qvto stand-along [message #853584 is a reply to message #853264] Mon, 23 April 2012 02:28 Go to previous messageGo to next message
Your questions make little sense.
There are many QVTo plugins, not all of which need plugin.xml.
Your last sentence has a bewildering mix of concepts.
Ed Willink
> executer.
>> Hi
>> See ...
>> Regards
>> Ed Willink
>> stand > along Java project, the input is the source model and the
>> output is > the target model?Is there a jar library or else?Is there
>> a sample > project?
Re: [qvto]how to run qvto stand-along [message #855227 is a reply to message #853584] Tue, 24 April 2012 12:16 Go to previous messageGo to next message
Hi, sorry for my silly question, as I have no experience on developing EMF or Eclipse Plug-in project before.
Now I come into another problem, I got an exception:
java.lang.IllegalArgumentException: resolve against non-hierarchical or relative base
at org.eclipse.emf.common.util.URI.resolve(URI.java:1950)
at org.eclipse.emf.common.util.URI.resolve(URI.java:1923)
at org.eclipse.m2m.internal.qvt.oml.compiler.URIUnitResolver.doResolveUnit(URIUnitResolver.java:105)
at org.eclipse.m2m.internal.qvt.oml.compiler.URIUnitResolver.doResolveUnit(URIUnitResolver.java:87)
at org.eclipse.m2m.internal.qvt.oml.compiler.URIUnitResolver.getUnit(URIUnitResolver.java:127)
at org.eclipse.m2m.internal.qvt.oml.compiler.UnitResolverFactory$BasicRegistry$1.findUnit(UnitResolverFactory.java:89)
at org.eclipse.m2m.internal.qvt.oml.compiler.UnitResolverFactory$BasicRegistry.getUnit(UnitResolverFactory.java:120)
at org.eclipse.m2m.internal.qvt.oml.InternalTransformationExecutor.doLoad(InternalTransformationExecutor.java:231)
at org.eclipse.m2m.internal.qvt.oml.InternalTransformationExecutor.loadTransformation(InternalTransformationExecutor.java:119)
at org.eclipse.m2m.internal.qvt.oml.InternalTransformationExecutor.execute(InternalTransformationExecutor.java:163)
at org.eclipse.m2m.qvt.oml.TransformationExecutor.execute(TransformationExecutor.java:88)
Do you have any suggestions about this exception?
Really thank you very much.
Edward Willink wrote on Mon, 23 April 2012 02:28
Ed Willink
> executer.
>> Hi
>> See ...
>> Regards
>> Ed Willink
>> a sample > project?
Re: [qvto]how to run qvto stand-along [message #855239 is a reply to message #855227] Tue, 24 April 2012 12:22 Go to previous messageGo to next message
If you have no experience doing EMF or Eclipse Plug-in project you're
really diving into the deepend trying to do standalone headless QVTo
then… The error below tells us very little other than your URI is
incorrect. What is the URI you are putting in and how are you creating
it? Without even basic information like that it's very hard to provide
any meaningful help.
> relative base
> at
> at
> at
> at
> at
> at
> at
> at
> at
>> Hi
>> Regards
>> Ed Willink
>>> executer.
>>>> Hi
>>>> See ...
>>>> Regards
>>>> Ed Willink
>>>> output is > the target model?Is there a jar library or else?Is there a
>>>> sample > project?
Re: [qvto]how to run qvto stand-along [message #855246 is a reply to message #855239] Tue, 24 April 2012 12:29 Go to previous messageGo to next message
To gain some relevant experience, you might try to write a tiny Java
transformation that loads your input file, resolving URIs correctly,
traverses the model tree converting all "name" attributes to upper case,
then saves the resulting resource to a distinct URI; again, verifying
the utility of your output file names.
Ed Willink
>> or relative base
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>> Hi
>>> Regards
>>> Ed Willink
>>>> call the executer.
>>>>> Hi
>>>>> See ...
>>>>> Regards
>>>>> Ed Willink
>>>>> there a sample > project?
Re: [qvto]how to run qvto stand-along [message #856183 is a reply to message #855239] Wed, 25 April 2012 08:50 Go to previous messageGo to next message
Hi, thanks for your reply.
I tried a demo plug-in project and it works OK, because I don't need to register the EMF model myself.
I get source model resource by:
URI bpel = URI.createPlatformResourceURI("/ModelTransformation/source/searchProcess.bpel", true);
Resource bpelResource = new ResourceSetImpl().getResource(bpel, true);
"ModelTransformation" is a project under the run-time workspace
I get qvto file by:
String pluginURIPrefix = "/" + Activator.PLUGIN_ID;
URI transformationURI = URI.createPlatformPluginURI(pluginURIPrefix + "/m/transformation1.qvto", true);
For transformationURI, I tried createPlatformResourceURI like before and createURI by absolute path, but not work. I'm sure the path is right. I don't understand why it doesn't work.
For me, it's good enough to run it in a plug-in project. But I still want to get it work standalone.
I tried this:
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("bpel", new BPELResourceFactoryImpl());
resourceSet.getPackageRegistry().put(BPELPackage.eINSTANCE.getNsURI(), BPELPackage.eINSTANCE);
URI bpelURI = URI.createURI("/Users/Allen/Documents/workspace/Test/test.bpel");
URI transformationURI = URI.createURI("/Users/Allen/Documents/workspace/Test/BpelTest.qvto", true);
TransformationExecutor executor = new TransformationExecutor(transformationURI);
But exception: java.lang.IllegalArgumentException: resolve against non-hierarchical or relative base
I tried createPlatformResourceURI or some else, but none worked.
Alan McMorran wrote on Tue, 24 April 2012 12:22
then... The error below tells us very little other than your URI is
[Updated on: Wed, 25 April 2012 08:51] by Moderator
Re: [qvto]how to run qvto stand-along [message #856187 is a reply to message #855246] Wed, 25 April 2012 08:56 Go to previous messageGo to next message
I tried a demo plug-in project and it works ok. After that I also tried standalone project, but still not work.
Please read my last reply to Alan McMorran.
Edward Willink wrote on Tue, 24 April 2012 12:29
Ed Willink
>> or relative base
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>>> Hi
>>> Regards
>>> Ed Willink
>>>> call the executer.
>>>>> Hi
>>>>> See ...
>>>>> Regards
>>>>> Ed Willink
Re: [qvto]how to run qvto stand-along [message #856204 is a reply to message #856187] Wed, 25 April 2012 09:14 Go to previous messageGo to next message
Indeed; you must get standalone to work.
Which either means making relevant platform:/... URIs work, or using an
alternative file: scheme everywhere.
The former can be done using the URI_MAP global registry to map each URI
in use to a file: URI that exists. Set a breakpoint on
MalformedURLException and in EcoreUtil.resolveProxy to discover each URI
that is failing.
The latter is really hard when you have a mix of files prepared in
Eclipse that you re-use standalone.
Alternatively you can use
org.eclipse.ocl.examples.domain.utilities.StandaloneProjectMap which
will scan the classpath and read .project files and plugin.xml files to
provide all the registrations automatically.
Ed Willink
>> Hi
>> case, then saves the resulting resource to a distinct URI; again,
>> verifying the utility of your output file names.
>> Regards
>> Ed Willink
>> you're > really diving into the deepend trying to do standalone
>> headless QVTo > then... The error below tells us very little other
>> than your URI is > incorrect. What is the URI you are putting in and
>> how are you creating > it? Without even basic information like that
>> it's very hard to provide > any meaningful help.
>> >> Hi, sorry for my silly question, as I have no experience on >>
>> non-hierarchical >> or relative base
>> >> at >>
>> >> at >>
>> >> at >>
>> >> at >>
>> >> at >>
>> >> at >>
>> >> at >>
>> >> at >>
>> >> at >>
>> >>> Hi
>> >>> Regards
>> >>> Ed Willink
>> eclipse >>>> website, but there is no plugin.xml for qvto.I want to
>> read the >>>> codes after I select the source, target in the UI and
>> before you >>>> call the executer.
>> >>>>> Hi
>> >>>>> See ...
>> >>>>> Regards
>> >>>>> Ed Willink
>> the >>>>> output is > the target model?Is there a jar library or
>> else?Is >>>>> there a sample > project?
Re: [qvto]how to run qvto stand-along [message #856742 is a reply to message #856183] Wed, 25 April 2012 19:56 Go to previous message
> URI bpel =
> true);
> I get qvto file by:
> String pluginURIPrefix = "/" + Activator.PLUGIN_ID; URI
I'm confused in the line above you have:
but then you're saying you tried to load it with the
createPlatformResourceURI? Is the transformation in a plugin or within
a workspace? if it's within a plugin then you should be using the
createPlatformPluginURI not createPlatformResourceURI. If it's within
the workspace, what error are you getting? Are all the plugins being
registered correctly? Are you running it within an OSGi runtime?
> I tried this:
> BPELPackage.eINSTANCE); URI bpelURI =
> true);
That looks like an absolute file URI so you would need:
URI.createFileURI("/Users/Allen/Documents/workspace/Test/BpelTest.qvto",
true);
otherwise the URI resolver has no idea what sort of URI you are
providing. Alternatively do:
URI.createURI("file:/Users/Allen/Documents/workspace/Test/BpelTest.qvto",
true);
Saying that, I had trouble running QVTo files from anything other than
a platform or plugin URI so this may still not work.
Alan
Previous Topic:[QVTo] UnitResolverFactory weiredness
Next Topic:[QVTO] Resolve on disjunctive mapping
Current Time: Fri Jul 18 22:42:04 EDT 2025
Powered by FUDForum. Page generated in 0.23842 seconds
