Home » Language IDEs » Java Development Tools (JDT) » Different New Java Project vs Plug-in Project Behavior...
| Different New Java Project vs Plug-in Project Behavior... [message #85106] |
Tue, 12 August 2003 17:46  |
Originally posted by: john.ellis.ascentialsoftware.com
Using:
Version: 2.1.1
Build id: 200306271545
Wondering if the following is known behavior or a bug.
I have noticed different behavior b/w the new Java Project Wizard and the
new Plug-in Project Wizard.
Prior to running the New Project Wizard, I create the following directory
structure on disk somewhere.
+---eclipse
| \---projects
| \---com.finbar.myjavaproject
| \---com.finbar.myjavaproject2
I then use the New Java Project Wizard and specify project contents to be
the location created above i.e. I uncheck the "Use default" checkbox and
browse for a project location. Then follow the rest of the Wizard.
I repeat this for com.finbar.myjavaproject successfully.
The result is that I have two Java Projects in my workspace whose contents
is elsewhere. This allows me put the Java Projects in source control and
have them remain portable with the use of variables.
However, the above does not seem possible with Plug-in Projects. I cannot
create a Plug-in Project under eclipse\projects shown below b/c it overlaps
with existing Java Projects.
+---eclipse
| \---projects
| \---com.finbar.mypluginproject
| \---com.finbar.mypluginproject2
The questions are...Why will Eclipse allow Java Projects to reside in a
common external directory and not Plug-in Projects?
Cheers, John
| Re: Different New Java Project vs Plug-in Project Behavior... [message #85301 is a reply to message #85153] |
Wed, 13 August 2003 08:47   |
I am not trying to create two projects in the same directory. I realize that
there cannot be two .project and .classpath files in the same directory.
I can create more than one Java Project using the New Project Wizard that
results in what I would expect below.
+---eclipse
| \---projects
| \.project
| \.classpath
| \.project
| \.classpath
I understand that Plug-in projects are java projects, but the point is I
want to use the New Plug-in Project wizard to generate the project and
initial source. However, the New Plug-in Project Wizard will not allow me to
+---eclipse
| \---projects
| \---com.finbar.myjavaproject (SUCCEEDS:
File->New->Project->Java->Java Project)
| \.project
| \.classpath
| \---com.finbar.myjavaproject2 (SUCCEEDS:
| \.project
| \.classpath
| \---com.finbar.mypluginproject (FAILS: File->New->Project->Plug-in
Development->Plug-in Project)
| \.project
| \.classpath
If I use the default workspace for the location of projects above, both New
Project Wizards will succeed. However, this is not ideal because using -data
to point at a location in my CVS source tree means that developers need to
maintain the .metadata directory in a transient source structure.
The idea of the "Use default" checkbox, as I understand, is to locate any
project outside the default workspace.
Cheers, John
"Richard L. Kulp" <richkulp@NOSPAM.us.ibm.com> wrote in message
news:bhbsca$a4b$1@eclipse.org...
> You can't have two projects that point to the same area on the disk. So
> you can't create a JavaProject AND a Plugin Project that both come from
> com.finbar.myjavaproject. That is because when you do what you did it
> will actually modify the directory com.finbar.myjavaproject to put a
> .classpath file, a .project file, and other control files. So it can't
> put a different .project file in there because it is already used by the
> javaproject.
> PS: A plugin project is by default also a java project. You don't need
> to create a separate project.
> John Ellis wrote:
> > Hi,
> > Using:
> > Version: 2.1.1
the
directory
> > +---eclipse
> > | \---projects
be
contents
cannot
overlaps
> > +---eclipse
> > | \---projects
> > Cheers, John
> Thanks, Rich Kulp
| Re: Different New Java Project vs Plug-in Project Behavior... [message #85360 is a reply to message #85301] |
Wed, 13 August 2003 10:06   |
> +---eclipse
> | ---projects
> | .project
> | .classpath
> | .project
> | .classpath
> +---eclipse
> | ---projects
> | .project
> | .classpath
> | .project
> | .classpath
> | .project
> | .classpath
What are you typing in for the Project Name and Directory text boxes for
each of the projects? It works for me if I enter
eclipse/projects/com.finbar.my<java/pluginproject> in the Directory field
and give it a name in the Project Name field.
> Cheers, John
> > javaproject.
> > John Ellis wrote:
> > > Hi,
> > > Using:
> > > Version: 2.1.1
> the
> directory
> > > +---eclipse
> > > | ---projects
> be
> contents
> cannot
> > > create a Plug-in Project under eclipseprojects shown below b/c it
> overlaps
> > > +---eclipse
> > > | ---projects
> > > Cheers, John
> > Thanks, Rich Kulp
| Re: Different New Java Project vs Plug-in Project Behavior... [message #85412 is a reply to message #85360] |
Wed, 13 August 2003 10:42   |
It doesn't matter what I type. There is an overlap detected when using the
New Plug-in wizard.
The difference b/w the New Java Project Wizard and the New Plug-in Project
Wizard is that the Plug-in Wizard will create a new directory under the
selected directory.
E.g. If I select eclipse/projects/com.finbar.mypluginproject as the location
the Plug-in Wizard will succeed. However, the directory structure ends up
being:
eclipse/projects/com.finbar.mypluginproject/com.finbar.myplu ginproject
I simply want to to create:
eclipse/projects/com.finbar.mypluginproject/.project
eclipse/projects/com.finbar.mypluginproject/.classpath
What is it about Plug-in java Projects that make them different to regular
Java Projects that prevents my desired structure?
I'm beginning to think it is a defect in the Wizard. A simple test provided
me with some evidence of this possibility.
1. Create
eclipse/projects/com.finbar.mypluginproject/com.finbar.myplu ginproject via
the Plug-in Wizard
2. Delete com.finbar.mypluginproject project from the workspace, but
leave contents of directory
3. Move contents of
eclipse/projects/com.finbar.mypluginproject/com.finbar.myplu ginproject to
eclipse/projects/com.finbar.mypluginproject.save
4. Delete eclipse/projects/com.finbar.mypluginproject from file system
5. Rename eclipse/projects/com.finbar.mypluginproject.save to
6. Import the project
7. Bingo! Now I have eclipse/projects/com.finbar.mypluginproject that is
just fine...
"Dave Wegener" <wegener@cboenospam.com> wrote in message
news:bhdgl0$nsi$1@eclipse.org...
that
that
> > +---eclipse
> > | ---projects
> > | .project
> > | .classpath
> > | .project
> > | .classpath
me to
> > +---eclipse
> > | ---projects
> > | .project
> > | .classpath
> > | .project
> > | .classpath
> > | .project
> > | .classpath
New
using -data
to
any
> > Cheers, John
So
from
the
> > > javaproject.
> > > John Ellis wrote:
> > > > Hi,
> > > > Using:
> > > > Version: 2.1.1
and
> > the
> > directory
> > > > +---eclipse
> > > > | ---projects
to
> > be
and
> > contents
and
> > cannot
> > overlaps
> > > > +---eclipse
> > > > | ---projects
in a
> > > > Cheers, John
> > > Thanks, Rich Kulp
| Re: Different New Java Project vs Plug-in Project Behavior... [message #85555 is a reply to message #85412] |
Wed, 13 August 2003 15:57  |
> New Plug-in wizard.
> selected directory.
I see what you mean now. I agree that this behavior is inconsistent. In
the New Java Project Wizard, the project is created in directory specified
in the directory name text box. In the New Plugin-in Project Wizard, a
subdirectory with the plugin name is created as a subdirectory of the
directory specified in the directory name box. This is confusing and as
you state leads to a redundant directory being created for plugin projects.
Interestingly, if the default location is used for a project, a new
directory with the projects name is created in the default workspace
location. In fact the directory name dialog box displays the new
directory as you type the name.
I would suggest that you open a bugzilla request asking for a more
consistent behavior. You can include the contents of this thread to
describe the problem.
> being:
> 1. Create
> the Plug-in Wizard
> 3. Move contents of
> just fine...
> that
> that
> > > +---eclipse
> > > | ---projects
> > > | .project
> > > | .classpath
> > > | .project
> > > | .classpath
> me to
> > > +---eclipse
> > > | ---projects
> > > | .project
> > > | .classpath
> > > | .project
> > > | .classpath
> > > | .project
> > > | .classpath
> New
> using -data
> to
> any
> > > Cheers, John
> So
> from
> the
> > > > javaproject.
> > > > John Ellis wrote:
> > > > > Hi,
> > > > > Using:
> > > > > Version: 2.1.1
> and
> > > the
> > > directory
> > > > > +---eclipse
> > > > > | ---projects
> to
> > > be
> and
> > > contents
> and
> > > cannot
> > > overlaps
> > > > > +---eclipse
> > > > > | ---projects
> in a
> > > > > Cheers, John
> > > > Thanks, Rich Kulp
Current Time: Mon Oct 27 15:00:35 EDT 2025
Powered by FUDForum. Page generated in 0.04961 seconds
