Home » Archived » Test and Performance Tools Platform (TPTP) » Exception handling in custom rules/templates
Exception handling in custom rules/templates [message #85270] Fri, 13 October 2006 14:34 Go to next message
Originally posted by: matthew.gregory.us.michelin.com
I just want to make sure I handle exceptions correctly in my custom
templates and rules (TPTP 4.2.0). So I started looking through the
existing one's code and it looks like there isn't any exception handling
going on in the rules (no results from grep for 'throw' or 'catch'). In
the templates code there are three try/catch blocks, but all the catch
blocks swallow the exception. Is there a reason for this? And should I
follow the same model? Is there anywhere I can find some info how
exceptions should be handled?
Thanks in advance,
matt.
Re: Exception handling in custom rules/templates [message #85285 is a reply to message #85270] Fri, 13 October 2006 17:03 Go to previous messageGo to next message
Originally posted by: s_gutz.ca.ibm.com
Since a rule can literally do just about anything, we are protectionist
about any exceptions that get thrown. If you look at the analyze()
method in DefaultAnalysisCategory (the place where rules get executed)
you will see that we wrap the whole process in a generic try/catch
block. This ensures that no matter kind of a mess the rule gets itself
into it can't take down the analysis process.
You can certainly do any exception handling you want inside your
rule/template. In the event that an exception does happen you can use
the Log.severe() method to write a message to the log file and simply
return from your rule without generating any results.
Steve
> Thanks in advance,
> matt.
Re: Exception handling in custom rules/templates [message #85405 is a reply to message #85285] Tue, 17 October 2006 09:00 Go to previous message
Ah, I see now ... new Throwable it is! ;-)
Previous Topic:Custom Test Execution (perl) + RAC 4.2 Deployment problem ?
Next Topic:ClassNotFoundException - Verification hook class not found
Current Time: Sun Nov 09 11:26:14 EST 2025
Powered by FUDForum. Page generated in 0.04190 seconds
