Installing spring security [message #851164] |
Fri, 20 April 2012 14:09  |
I´m trying to deploy an application I´m developing with spring and virgo server, but I can´t get the spring security bundles get installed in my Virgo instance.
The error I get when I try to deploy my app is this:
initialization failed org.springframework.beans.factory.parsing.BeanDefinitionParsingException: Configuration problem: Unable to locate Spring NamespaceHandler for XML schema namespace [://www.springframework.org/schema/security]
Offending resource: ServletContext resource [/WEB-INF/applicationContext.xml]
at org.springframework.beans.factory.parsing.FailFastProblemReporter.error(FailFastProblemReporter.java:68)
at org.springframework.beans.factory.parsing.ReaderContext.error(ReaderContext.java:85)
at org.springframework.beans.factory.parsing.ReaderContext.error(ReaderContext.java:80)
at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.error(BeanDefinitionParserDelegate.java:284)
at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1332)
at org.springframework.beans.factory.xml.BeanDefinitionParserDelegate.parseCustomElement(BeanDefinitionParserDelegate.java:1325)
at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.parseBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:135)
at org.springframework.beans.factory.xml.DefaultBeanDefinitionDocumentReader.registerBeanDefinitions(DefaultBeanDefinitionDocumentReader.java:93)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.registerBeanDefinitions(XmlBeanDefinitionReader.java:493)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.doLoadBeanDefinitions(XmlBeanDefinitionReader.java:390)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:334)
at org.springframework.beans.factory.xml.XmlBeanDefinitionReader.loadBeanDefinitions(XmlBeanDefinitionReader.java:302)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:143)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:178)
at org.springframework.beans.factory.support.AbstractBeanDefinitionReader.loadBeanDefinitions(AbstractBeanDefinitionReader.java:149)
at org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext.loadBeanDefinitions(OsgiBundleXmlApplicationContext.java:164)
at org.springframework.osgi.context.support.OsgiBundleXmlApplicationContext.loadBeanDefinitions(OsgiBundleXmlApplicationContext.java:136)
at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:130)
at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:467)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:397)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.access$301(AbstractDelegatedExecutionApplicationContext.java:69)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$1.run(AbstractDelegatedExecutionApplicationContext.java:186)
at org.springframework.osgi.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.normalRefresh(AbstractDelegatedExecutionApplicationContext.java:182)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$NoDependenciesWaitRefreshExecutor.refresh(AbstractDelegatedExecutionApplicationContext.java:89)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.refresh(AbstractDelegatedExecutionApplicationContext.java:175)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:276)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:197)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:47)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4723)
at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5226)
at org.apache.catalina.core.StandardContext$1.call(StandardContext.java:5221)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:680)
[2012-04-20 14:55:56.783] ERROR Thread-33 o.a.c.c.ContainerBase.[Catalina].[localhost].[/listadecompras] Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener org.springframework.beans.factory.parsing.BeanDefinitionParsingException: Configuration problem: Unable to locate Spring NamespaceHandler for XML schema namespace [//www.springframework.org/schema/security]
My app doesnt have too much.
My applicationContext.xml is the one explained in the spring security reference
<beans:beans xmlns="://www.springframework.org/schema/security"
xmlns:beans="://www.springframework.org/schema/beans"
xmlns:xsi="://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="://www.springframework.org/schema/beans
://www.springframework.org/schema/beans/spring-beans-3.0.xsd
://www.springframework.org/schema/security/spring-security-3.1.xsd">
<http use-expressions="true">
<intercept-url pattern="/**" access="permitAll" />
<form-login />
</http>
<authentication-manager>
<authentication-provider>
<user-service>
<user name="rod" password="koala" authorities="supervisor, teller, user" />
<user name="dianne" password="emu" authorities="teller, user" />
<user name="scott" password="wombat" authorities="user" />
<user name="peter" password="opal" authorities="user" />
</user-service>
</authentication-provider>
</authentication-manager>
</beans:beans>
I think the problem is in my instaled bundles, I copied the security files in the usr directory but the OSGI state in the web manager doesn´t show them.
I´m using the 3.0.5.RELEASE version of spring, and the 3.0.4.RELEASE version of spring security.
Any ideas?
Thanks in advanced. If more info is needed please let me know.
Re: Installing spring security [message #886227 is a reply to message #878141] |
Thu, 14 June 2012 09:33  |
Sorry, I dont know why I´m not recieving mail notifications.
¿Did you solve this? You need to import the package where the namespace of spring security is, org.springframework.security.config, I think.
FUDForum. Page generated in 0.26652 seconds
