Home » Eclipse Projects » Remote Application Platform (RAP) » Integrating Eclipse Problems View in RAP application?
Integrating Eclipse Problems View in RAP application? [message #850767] Fri, 20 April 2012 06:03 Go to next message
Hi guys,
I am trying to integrate the Eclipse Problems View in my RAP application. I added it to my perspective but did not succeed to get it running since there are dependencies to org.eclipse.ui stuff.
Can somebody please give me a hint how to achieve the integration? Is there a workaround or a RAP implementation available or do I have to copy (and tailor) the classes needed into a new bundle having dependencies to the rap ui bundles?
Many thanks in advance for your help.
Marcus
Re: Integrating Eclipse Problems View in RAP application? [message #851701 is a reply to message #850767] Sat, 21 April 2012 03:42 Go to previous message
Marcus,
unless someone else has done this before and is willing to share the
result, I'd recommend to copy and adjust the code.
RAP has the policy to provide API only if it works (i.e. no empty API).
Once you changed the dependencies, you can go along the compile errors
to see what needs to be adjusted or what doesn't work.
HTH
Rüdiger
On 20.04.2012 12:03, Marcus Marcus wrote:
> Hi guys,
> Marcus
Rüdiger Herrmann
http://codeaffine.com
Previous Topic:Rounded corners in Browser Widget (IE9)
Next Topic:PDE incubator: patch proposal
Current Time: Mon Jul 21 00:35:39 EDT 2025
Powered by FUDForum. Page generated in 0.04516 seconds
