Home » Eclipse Projects » GEF » ManhattanConnectionRouter revisited
ManhattanConnectionRouter revisited [message #8422] Thu, 06 June 2002 12:40 Go to next message
OK, I guess I'm just too dumb (lazy?) to see through the obtuse hierarchy of
classes in the logic demo - I just can't figure out how to implement a
ManhattanConnectionRouter. Can someone please explain to this simpleton
(i.e. me) how to do this? Thanks in advance...
Bob
Re: ManhattanConnectionRouter revisited [message #8451 is a reply to message #8422] Thu, 06 June 2002 14:17 Go to previous messageGo to next message
I'm not really sure what you're having trouble with. Could you be more
specific?
Eric
"Bob Brodt" <rbrodt@hotmail.com> wrote in message
news:ado29e$gbj$1@rogue.oti.com...
of
> Bob
Re: ManhattanConnectionRouter revisited [message #8482 is a reply to message #8451] Thu, 06 June 2002 16:03 Go to previous messageGo to next message
Bob,
there's nothing to implement, you can use the class as is.
just
- create two figures
- create an anchor per figure (eg ChopboxAnchor) and refer to the
figure in the anchor's constructor
- create an connection (Polyline..)
- set the connections start and end anchor
- set a router (i.e. ManhattanConnectionRouter) for the connection
- invoke route() on the connection
the router will then:
- erase the pointlist of the connection
- let the anchors calculate their resp. positions (for a chopbox this
is determined by the intersection of the line going through the centers
of the enclosing rectangles of both figures and those rectangles
themselves )
- add a start and end point to the pointlist of the connection
corresponding with the positions of the anchors
- add points between those begin and end point specific to the router's
algorithm. For a manhattan algorithm the connection will have only
vertical and /or horizontal strokes.
Bram
> specific?
> Eric
> of
>>Bob
Re: ManhattanConnectionRouter revisited [message #8511 is a reply to message #8482] Thu, 06 June 2002 17:01 Go to previous messageGo to next message
Originally posted by: none.ibm.com
> Bob,
> just
You don't need to invoke route(). route is part of validate(), which gets
called automatically.
> themselves )
> Bram
> > specific?
> > Eric
hierarchy
> > of
> >>Bob
Re: ManhattanConnectionRouter revisited [message #8592 is a reply to message #8511] Fri, 07 June 2002 04:12 Go to previous messageGo to next message
Originally posted by: g.wagenknecht.intershop.de
Hi!
The ManhattenRouter is great, but it is possible to modify it a little bit
for 2.0 release?
Look at the attached picture. I added a arrow decoration to the end of the
target connection. The ManhattenRouter routes after its strict algorithm. I
think it should look at decorations (especially arrows) to ensure a better
quality of routing, which looks nicer.
Cu, Gunnar
Re: ManhattanConnectionRouter revisited [message #8640 is a reply to message #8592] Fri, 07 June 2002 09:41 Go to previous messageGo to next message
Please open a feature request. There is nothing on the decoration that
would tell us how "big" it is. Maybe you could just configure the router
with an offset.
"Gunnar Wagenknecht" <g.wagenknecht@intershop.de> wrote in message
news:adpoq8$60d$1@rogue.oti.com...
> Hi!
> for 2.0 release?
I
> Cu, Gunnar
Re: ManhattanConnectionRouter revisited [message #9556 is a reply to message #8640] Tue, 11 June 2002 14:57 Go to previous messageGo to next message
Opened http://bugs.eclipse.org/bugs/show_bug.cgi?id=19931
Dave Orme
Advanced Systems Concepts
http://www.asc-iseries.com
Re: ManhattanConnectionRouter revisited [message #9746 is a reply to message #9556] Wed, 12 June 2002 01:43 Go to previous message
Hi!
Sorry, I was a little bit faster ;)
http://bugs.eclipse.org/bugs/show_bug.cgi?id=19601
Cu, Gunnar
Previous Topic:OK I'll start the ball rolling...
Next Topic:GridLayout
Current Time: Fri Nov 07 07:18:50 EST 2025
Powered by FUDForum. Page generated in 0.04745 seconds
