| Home » Archived » Visual Editor (VE) » No New-Visual Class Menu Item
 Goto Forum:|
| No New-Visual Class Menu Item [message #84877] | Sat, 26 March 2005 20:01  |  |
| Eclipse User  |  |  |  |  | Originally posted by: PeterNZ.gmx.net
 I downloaded VE-SDK 1.0.2  and put it on top of a working Eclipse 3.0.1.
 (incl. JDT 3.0.1). I checked the information under Help - About Eclipse
 Platform - Plugin Details and it shows all the entries listed in teh FAQ. I
 also read through all the artikles I could find here in the newsgroups and
 checked all recommended settings I found there. I also did a
 "D:\eclipse\eclipse.exe -clean"
 I still don't get the Visual Class Menu Item under "New"
 My OS is Win XP Professional and I am using JRE 1.5
 Does anyone have a clue of what I do wrong? Some help would be greatly
 appreciated. Please let me know if you need any additional information.
 Cheers
 PeterNZ
| Re: No New-Visual Class Menu Item [message #84992 is a reply to message #84952] | Sun, 27 March 2005 02:09   |  |
 Yepp, all there, org.eclipse.ve, org.eclipsie.ve.sdk and
 org.eclipse.ve.source
 Cheers
 Peter
 "ian" <ian@amham.net> wrote in message news:d257mr$sav$1@news.eclipse.org...
 > Also have a look under Help About - Feature Details and verify that the VE
 > is there.
 > PeterNZ wrote:
 >> Thanks Ian for your quick reply. But no, sorry also under "Other" no
 >> Visual Class, only Package, Class, Interface etc.
 >> Cheers
 >> Peter
 >> news:d255r3$qg2$1@news.eclipse.org...
 >>>Peter NZ wrote:
 >>>>Hi,
 >>>>FAQ. I
 >>>>and
 >>>>Cheers
 >>>>PeterNZ
 >>>Have a look under File - New - Other. It should then be under the Java
 >>>list. That's where I see it. Not sure how to get it on the menu directly.
 >>>Cheers,
 >>>Ian
| Re: No New-Visual Class Menu Item [message #85050 is a reply to message #85022] | Mon, 28 March 2005 02:40   |  |
 Hello Jeff,
 thank you fo ryour reply.
 hoenstly I wasn't sure if I installed the SDKor teh runtime. Iinstallfrom a
 Developers Magazine CD. So I re-installed everything. First I installed
 Eclipse SDK 3.0.1 (eclipse-platform-SDK-3.0.1-win32.zip), then the PDE Files
 (eclipse-PDE-3.0.1.zip) and then JDT (eclipse-JDT-3.0.1.zip). On top of this
 the VE files (VE-SDK-1.0.2.1.zip). And still the same problem.
 Just to make sure if I do the right thing. I started Eclipse, switched to
 Java Perspective and created a new Java Project with the default settings. I
 then create a package under the project using the Context Menu of the
 Project  "New - Package" in the Package Explorer Window. Next step is the
 context menu on the package and under "New ..."  I only have "Project",
 "Package", "Class", "Interface", "Source Folder", "Folder", "File", "JUnit
 Test Case" and "Other". Also under "Other" I do not have a Visual Class
 Entry.
 Thank you for your help with this.
 Peter
 "Jeff Myers" <myersj@gmail.com> wrote in message
 news:d27855$t70$1@news.eclipse.org...
 > Hi PeterNZ,
 > Do you have the PDE plug-ins installed?  I ask this because you said
 > you've installed JDT 3.0.1, which implies you installed the Eclipse
 > runtime + JDT, rather than the Eclipse SDK.  The VE does have a dependency
 > on PDE as well, but it's not listed on the requirements list because the
 > requirements specify that it should be installed on top of Eclipse SDK.
 > Hope this helps,
 >  - Jeff
 > PeterNZ wrote:
 >> Hi,
 >> I
 >> and
 >> Cheers
 >> PeterNZ
| Re: No New-Visual Class Menu Item [message #85079 is a reply to message #85050] | Mon, 28 March 2005 15:31  |  |
| Eclipse User  |  |  |  |  | Originally posted by: sgtcasey.IH8SPAMcableone.net
 On Mon, 28 Mar 2005 19:40:31 +1200, PeterNZ wrote:
 > Hello Jeff,
 > Entry.
 Hey Peter I had the exact same problem as you are talking about when I
 downloaded and installed VE manually.  So, I decided to just start over and
 delete the eclipse folder, unzip eclipse again and this time use Software
 Updates (under Help) to install VE.  Worked great after that and I was
 never able to figure out why it didn't work the first time.
 Now, if someone can just tell me how to change what Java code the VE
 generates when you add swing items to the JFrame.  :-)
 Dave
 You can talk about us, but you can't talk without us!
 US Army Signal Corps!!
 http://www.geocities.com/davidcasey98
 Remove IH8SPAM to reply by email!
| Re: No New-Visual Class Menu Item [message #606136 is a reply to message #84877] | Sat, 26 March 2005 20:07  |  |
| Eclipse User  |  |  |  |  | Peter NZ wrote: > Hi,
 > Cheers
 > PeterNZ
 Ian
| Re: No New-Visual Class Menu Item [message #606139 is a reply to message #84908] | Sat, 26 March 2005 20:11  |  |
 Thanks Ian for your quick reply. But no, sorry also under "Other" no Visual
 Cheers
 Peter
 "ian" <ian@amham.net> wrote in message news:d255r3$qg2$1@news.eclipse.org...
 > Peter NZ wrote:
 >> Hi,
 >> I
 >> and
 >> Cheers
 >> PeterNZ
 > Cheers,
 > Ian
| Re: No New-Visual Class Menu Item [message #606142 is a reply to message #84923] | Sat, 26 March 2005 20:36  |  |
| Eclipse User  |  |  |  |  | Click on the Other... option of the menu.
 > Cheers
 > Peter
 >>Peter NZ wrote:
 >>>Hi,
 >>>I
 >>>and
 >>>Cheers
 >>>PeterNZ
 >>Cheers,
 >>Ian
| Re: No New-Visual Class Menu Item [message #606144 is a reply to message #84923] | Sat, 26 March 2005 20:38  |  |
| Eclipse User  |  |  |  |  | Also have a look under Help About - Feature Details and verify that the VE is there.
 > Cheers
 > Peter
 >>Peter NZ wrote:
 >>>Hi,
 >>>I
 >>>and
 >>>Cheers
 >>>PeterNZ
 >>Cheers,
 >>Ian
| Re: No New-Visual Class Menu Item [message #606155 is a reply to message #84952] | Sun, 27 March 2005 02:09  |  |
 Cheers
 Peter
 > is there.
 >> Cheers
 >> Peter
 >>>Peter NZ wrote:
 >>>>Hi,
 >>>>FAQ. I
 >>>>and
 >>>>Cheers
 >>>>PeterNZ
 >>>Cheers,
 >>>Ian
| Re: No New-Visual Class Menu Item [message #606158 is a reply to message #84938] | Sun, 27 March 2005 14:42  |  |
 Yes, that's what I did. But no "Visual Class" under "Other" sorry!
 Cheers
 Peter
 "ian" <ian@amham.net> wrote in message news:d257ie$s6c$1@news.eclipse.org...
 >> Cheers
 >> Peter
 >>>Peter NZ wrote:
 >>>>Hi,
 >>>>FAQ. I
 >>>>and
 >>>>Cheers
 >>>>PeterNZ
 >>>Cheers,
 >>>Ian
| Re: No New-Visual Class Menu Item [message #606160 is a reply to message #84877] | Sun, 27 March 2005 15:01  |  |
| Eclipse User  |  |  |  |  | Hi PeterNZ,
 dependency on PDE as well, but it's not listed on the requirements list
 because the requirements specify that it should be installed on top of
 Eclipse SDK.
 Hope this helps,
 - Jeff
 PeterNZ wrote:
 > Cheers
 > PeterNZ
| Re: No New-Visual Class Menu Item [message #606164 is a reply to message #84938] | Sun, 27 March 2005 14:42  |  |
 Cheers
 Peter
 >> Cheers
 >> Peter
 >>>Peter NZ wrote:
 >>>>Hi,
 >>>>FAQ. I
 >>>>and
 >>>>Cheers
 >>>>PeterNZ
 >>>Cheers,
 >>>Ian
| Re: No New-Visual Class Menu Item [message #606167 is a reply to message #85022] | Mon, 28 March 2005 02:40  |  |
 Hello Jeff,
 Entry.
 Peter
 > Hi PeterNZ,
 > Hope this helps,
 >  - Jeff
 > PeterNZ wrote:
 >> Hi,
 >> I
 >> and
 >> Cheers
 >> PeterNZ
| Re: No New-Visual Class Menu Item [message #606174 is a reply to message #85050] | Mon, 28 March 2005 15:31  |  |
 > Hello Jeff,
 > Entry.
 Dave
 Current Time: Fri Oct 31 01:37:12 EDT 2025
 Powered by FUDForum . Page generated in 0.06380 seconds |
