Home » Modeling » Papyrus » Papyrus curious ATL behavior(How come my ATL transformation does not update my model)
Papyrus curious ATL behavior [message #850137] Thu, 19 April 2012 16:02 Go to next message
Platform (eclipse MDT + Papyrus + ATL);
Going through basic examples, I copy/paste ATL public2private.atl to
my basic model. Running it, does not seems to work, but when I
restart eclipse, the modification seems to proceeded (for the public =­­> private).
I do not see the new getter/setter appear in the diagram, however, the model
explorer shows that the get/set have been created in the class.
Q1 - Can I step in (debug) in an ATL transformation (seems to work in older version) ?
Q2 - What are the best techniques to debug and develop an ATL script ?
Q3 - How can I configure eclipse to automatically display all elements in a diagram ?
Thanks in advance, regards.
Merci.
Re: Papyrus curious ATL behavior [message #850290 is a reply to message #850137] Thu, 19 April 2012 19:53 Go to previous messageGo to next message
Q1 - I must precise that I already experimented with the ATL Debug perspective, but for a reason I do not know (from all versions of Papyrus MDT I tried), I cannot view the real value of any variables in the ATL script. The Variable View (x)= does only present Generic values or undefined element, like for instance:
self: transform1:ASMModule
rule1:
Type: Operation
metamodel: UML
and there is no presence of the variables in the rules (like rule1).
Thanks in advance.
Re: Papyrus curious ATL behavior [message #850633 is a reply to message #850290] Fri, 20 April 2012 03:31 Go to previous messageGo to next message
Hello Alain,
I guess the ATL transformation only works on the *.uml models (Semantic contents), which is not fully synchronized with the diagram (*.notation models). In Papyrus, all elements don't need to be represented graphically, so they are not automatically displayed in diagrams when they are created in the semantic model.
Currently, it is not possible in Papyrus. You could enrich the ATL transformation so that it can work on both the uml model and the notation one. This is not an easy solution, though.
You should probably refresh your workspace after running an ATL transformation. This is not always done automatically.
For your other questions, they are related to ATL much more than Papyrus, so you may try the Model-to-Model transformations forum.
Camille
Re: Papyrus curious ATL behavior [message #850983 is a reply to message #850633] Fri, 20 April 2012 10:26 Go to previous message
Thanks (Merci) Camille.
Previous Topic:First installation - Some errors in my Workspace Log ?
Next Topic:Cannot resize the Activity
Current Time: Fri Jul 25 04:15:34 EDT 2025
Powered by FUDForum. Page generated in 0.07944 seconds
