Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Performance Profiling
[Acceleo] Performance Profiling [message #847652] |
Tue, 17 April 2012 10:21  |
We have created a M2T transformation in Acceleo which is fairly simpel and straightforward but has unacceptable scalability issues. Are there any means to profile the performance of Acceleo code? Has anybody experienced performance issues with Acceleo before?
Re: [Acceleo] Performance Profiling [message #848901 is a reply to message #847656] |
Wed, 18 April 2012 13:35   |
I am using Acceleo version 3.2.1.
It is rather difficult to post anonymized code without a lot of effort. But I can give a few statistics on the size of some instances of the model that needs transforming. The transformation requires information from 5 related ecore models and consists of about 90 lines of Acceleo code. There are several loops which go through a large number of objects. This cannot be avoided as all objects need to be translated to a textual representation. For our killer case, there are 8000 objects of a class T. Moreover, there are 129 objects of a class SG, which together encapsulate about 14000 objects of a class B. There are furthermore about 100000 objects of a class C, which are encapsulated in either the one root object or one of the 129 SG objects. Finally, there are an (estimated) 250000 objects of a class P. All of this needs to be translated to text where all objects need to be visited at least once and the P objects twice (this can't be avoided to produce the correct text). The tree-editor does not have too much difficulty with opening this killer case and browsing through it.
The size of the example above makes the transformation take 2.5 hours, while our current implementation in C++ basically does the same transformation to text in about 1 second (including all file operations). The Acceleo code is nearly a 100% re-syntaxed verion of the original C++ code, with one exception for objects of class C. This requires some scoping which is realised with a select on an OrderedSet to find those C objects that have a reference to a specific P object within the same scope. To me the difference between 2.5h versus 1s is unexplanable for the given similarity in code. So, any help is welcome...
What exactly do you mean with 'launch with THE profiler activated'? Which profiler? What does it profile? We would like to see some statistics on how much time is spent on the execution of each of the different templates in our Acceleo code.
[Updated on: Wed, 18 April 2012 13:38] by Moderator
Re: [Acceleo] Performance Profiling [message #849730 is a reply to message #849550] |
Thu, 19 April 2012 08:01   |
Bart,
You might be interested in Ed's last point : Acceleo caches the result of query evaluations. If you can pinpoint specific expressions in your templates that are (or could be) extremely costly/executed so many times that it hurts, you should extract these expressions into Acceleo queries to avoid re-evaluation.
Since your models and templates are confidential, you might be interested in contacting info@obeo.fr to discuss the possibility of signing an NDA with us so that we can help you with the profiling and enhancing of your templates? These use case would also be beneficial to us since it would help us in determining the bottlenecks in Acceleo itself.
Ed,
Edward Willink wrote on Thu, 19 April 2012 04:41
Eclipse OCL supports evaluation of individual queries and has no caching
to improve reuse of partial results. (The Impact Analyzer provides
caches for re-evaluation.)
Avoiding re-evaluation is a user/consumer responsibility, so a user can
use let-variables.
In my experience, the main problem with Acceleo and OCL is their eager need to create new Collections every time something is called : set->select(expression)->filter(EClass)->collect(name) will cause the creation of at least four separate colleciton : a first when creating the initial "set" (IIRC, even a call to "package.eClassifiers" will return a new list instead of the "BasicEList" returned by a property call to "eClassifiers), a second for the select, a third for the filter, and finally a fourth for the collect. For Sets/LinkedSets, these creations are extremely costly. Using guava in the implementation would be extremely beneficial, but that's something I haven't gotten to try yet.
There is a pending patch for QVTo from JPL that gives massive
improvements in compilation time by caching all the meta-model lookups
that are otherwise repeated needlessly. (The OCL to Java generator
creates a flat meta-model representation that could be enabled to give
similar compilation time benefits with the new pivot model.)
I don't think QVTo is relevant here?
Acceleo provides query evaluation caches to ensure that queries are not
re-evaluated needlessly.
The user problem seems to be small templates and large data, so I wonder
whether the query caches are malfunctioning, or whether uncached derived
features are in use that could benefit from use of cached Acceleo queries.
Indeed, this is a potential improvement axis that can be explored.
Laurent Goubet
Obeo
Re: [Acceleo] Performance Profiling [message #850849 is a reply to message #849730] |
Fri, 20 April 2012 07:35   |
On 19/04/2012 13:01, Laurent Goubet wrote:
> Ed,
The polymorphic Value collections in the new pivot evaluator are
partially mutable which allows an in-place update for an iterate.
Associated iterator variables also have mutable values avoiding the need
for unregistration and reregistration of iterator variable bindings on
every iteration step.
A relatively simple optimisation
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=339783) would allow
in-place update for the last access to any collection giving a massive
reduction in collection churning. This is of only moderate priority for
me in the current interpreter. It will be much more useful as part of
the OCL to Java code generator.
If guava collections are more efficient, then switching to them as the
base implementation should be very easy too.
However I'm not yet confident enough in the basic naive OCL to Java code
generator to start optimising.
Ed Willink
Re: [Acceleo] Performance Profiling [message #857324 is a reply to message #856328] |
Thu, 26 April 2012 09:01   |
Ronald,
postGenerate() still unloads all models in its latest version. We just can't let everything sleep in memory when we don't need it anymore.
We do advise users to use a single "entry point" template instead of multiple "main" (see C.14 of the Best Practices guide.
Bart,
Did you try profiling your generation to pinpoint the problematic expressions? As is the case with Java, it is difficult (if not useless) to try and optimize something without a profiler.
[for (Object: Class| SetOfC.Attribute->asOrderedSet())]
[let x : OrderedSet(ClassC) = SetOfC->select(Attribute = Object)]
GenerateCommonOutputStringsFor(x)
[for (y: ClassC | x)]
GenerateSpecificOutputStringsFor(y)
[/for]
[/let]
[/for]
Iterate on all attribute values of a set of "C", then find the set of "C" that have this possible value and print something?
Taking into account the numbers you gave us before (100 000 'C'), that's quite a number of iteration over a big collection (not to mention that creating an OrderedSet is also costly (asOrderedSet) if you do it often) : suppose you have 10 possible values for "Attribute" : you'll have a first iteration over 100 000 elements to find them, then 10 more iterations over these elements to find back those that match this attribute value... And finally a new iteration over these "matching" classes to output "GenerateSpecificOutputString..." Whatever the language, more than a million iterations is bound to take time.
For a need such as this one, Acceleo/OCL don't offer good alternative to what you have (or so I think). The best I can think of is to use a Java service to find the lists you need. Something like this :
public Collection<List<ClassC>> orderByAttributeValue(Set<ClassC> setOfC) {
Map<ClassC, List<ClassC>> result = new HashMap<ClassC, List<ClassC>>(10);
for (ClassC candidate : setOfC) {
ClassC attribute = candidate.getAttribute();
List<ClassC> list = result.get(attribute);
if (list == null) {
list = new ArrayList<ClassC>(10000);
result.put(attribute, list);
list.add(candidate);
return result.values();
Which only does a single iteration over your "setOfC" and which you could then use like this :
[for (x : Sequence(ClassC) | setOfC.orderByAttributeValue())]
[/for]
[/for]
this should only iterate twice over the full set (once in the java service, a second time by iterating over each of the subsequences).
Once again, these are optimization you should only make after profiling, to make sure your optimizing the correct expressions.
Laurent Goubet
Obeo
[Updated on: Thu, 26 April 2012 09:04] by Moderator
Re: [Acceleo] Performance Profiling [message #857345 is a reply to message #857324] |
Thu, 26 April 2012 09:19   |
is almost certainly inefficient.
->asOrderedSet()
probably requires a total copy from the source collection into a
LinkedHashSet which is a linked list so has link objects and might do
linear duplicate detection. Since your ordering is not determinate
anyway, asSet() will be better. Similarly doing select on what I think
must be an OrderedSet to avoid a compilation error may also involve
linear rather than hashed access.
Don't use OrderedSet unless both uniqueness and ordering are relevant.
Ed Willink
On 26/04/2012 14:02, Laurent Goubet wrote:
> Ronald,
> http://www.obeonetwork.com/page/acceleo-best-practices guide.
> Bart,
> Quote:
>> [/for]
>> [/let]
>> [/for]
> time.
> Quote:
>> setOfC) {
>> List<ClassC>>(10);
>> if (list == null) {
> Quote:
>> [/for]
>> [/for]
> Laurent Goubet
> Obeo
Re: [Acceleo] Performance Profiling [message #869032 is a reply to message #857345] |
Wed, 02 May 2012 17:49   |
Thanks to all for the interesting answers.
Here are some responses:
@Ronald: The number of times the given 'complex' piece of Acceleo code is invoked is for our killer case study 131 times. There are three entry points for this piece of code and for our killer case there are only two entry points that are actually used.
@Laurent: The described behavior is indeed basically what we want: For a set 'C', find all elements that have the same Attribute and for each possible unique Attribute, print something for all 'C's that have that Attribute. The 'C' sets that go into an invocation have for our killer case at maximum about 650 'C's in most invocations. The number of possible values for Attribute is for our killer case (by coincidence) the same 650.
We have not yet been able to do proper profiling of the Acceleo code, but we were able to profile the Java implementation. Here we found one problem: the referencing between two particular models in different files. There are however more inter-file references for large(r) numbers of objects but for some unclear reason there was only a problem between two particular files and not between any of the others.
Now, we have done some tests with a completely different model and different transformation etc. Here, we don't have references between files as everything is in one file (so this test rules that out as a possible problem). We have 25000 object and performing the transformation (which is more complex than the ones discussed in this topic so far) also takes hours instead of the expected seconds/few minutes. The experiments we have done for this transformation shows that having more than about 5000 objects gives run times over 30min, which is again far beyond what we expected. 5000 objects is 'small' compared to the real-life models that we have to handle. Our killer case will at some point also go through this transformation and will have 25000+ objects...
The proposed kind of optimizations are far beyond our Acceleo skills But they could be a good idea if the problem is really located in this part of the code. If I completely comment the 'complex' piece of code out, things do get better but not as substantial as we expect (it's still 30+ min).
We slowly start to believe that there might be a deeper underlying problem (somewhere in the EMF core) but we still need to further investigate things.
@Ed: I don't really understand why using ->asOrderedSet would require creating copies. I mean, there is no specification of what the order should be and hence any ordering is a good one, also the one that happened to be the case for the retrieved set / collection. So, I just see a cast and that's it. But apparently I am missing something here? Anyway, I agree that we don't need any particular ordering. Unfortunately, changing ->asOrderedSet into ->asSet does not help any bit in improving the performance...
[Updated on: Wed, 02 May 2012 17:56] by Moderator
Re: [Acceleo] Performance Profiling [message #869299 is a reply to message #869032] |
Thu, 03 May 2012 03:45   |
Bart,
We're basically shooting in the dark here. Wild guesses are probably not going to help you much (I'd wager it'll do the oppposite).
We have used Acceleo for large models to make transformations that sound much more complex that what you describe here, though your models are in the same "large" range as ours. We did not encounter such huge performance drawbacks as what you're describing here, thus I truly believe that there are ways to improve your transformation, and most likely one or two "big" bottlenecks that should be improved.
However as I already mentionned, as long as you can't provide us with profiling results or the (or "one of" the) problematic OCL/Acceleo expressions, we can only provide you with general information that may or may not be related to the true issue. We can help with Acceleo, OCL, EMF or your own code if that's where the enhancements must be made, but we need the profiling results to be able to do anything at all. It might sound like I'm just insisting, but concluding an NDA with Obeo is a good trade-off for that : it does not compel you to paying anything or subscribing to any commercial offer, it only allows you to provide us with private information by making sure we won't divulge it to any third party. At least it would allow us to quickly pinpoint the exact bottleneck and provide you with workarounds and/or enhancements.
As for Ed's mention of the problem with "asOrderedSet" : both "asSet" and "asOrderedSet" ("asSequence" and "asBag" too for that matter) work by creating a whole new collection as a copy of the input. In terms of Java, calling the OCL "collection->asOrderedSet()" is the equivalent of "new LinkedHashSet(collection)" which iterates over the whole input collection (even if it is already a linked hash set), computes the has of every entry, checks if the new set already contains it, adds it if not ... which is why it is costly. "asSet" is the equivalent of Java's "new HashSet(collection)" which is a little less costly, but still too much.
Laurent Goubet
Obeo
Re: [Acceleo] Performance Profiling [message #869333 is a reply to message #869299] |
Thu, 03 May 2012 04:40   |
Echoing Laurent's comment; we can't help when you don't let us.
From, the limited information, I strongly suspect that it is either an
OCL limitation or an EMF access issue aggravated by the Acceleo context
and your usage.
That you report no change from asOrderedSet makes me think that the
problem is localised in a very small area, which should show up through
straightforward Java profiling with eg VirtualVM.
That your problems have an at least 650 by 650 dimension indicates that
it will be very sensitive to accidental quadratic, or worse, rather than
linear behaviour.
Partition your program so that you measure:
Load time
Transform time
Save time
ReLoad time
ReTransform time
ReSave time
and see how these vary between your current model and one one tenth of
the size.
Ed Willink
On 03/05/2012 08:45, Laurent Goubet wrote:
> Bart,
> enhancements.
> much.
> Laurent Goubet
> Obeo
Re: [Acceleo] Performance Profiling [message #870933 is a reply to message #870916] |
Thu, 10 May 2012 05:39   |
Seems rather unlikely so rather interesting and a very useful repro, but
to avoid pursuing blind alleys, can you post your launch configurations...
If you go to the "Common" tab of the Launch Configuration editor you can
specify a shared file, typically at the root or .settings or .launches
folder of your project.
Then we can just run e.g. 6-level launch, or 5-level launch and be sure
that we're replicating your scenario.
Ed Willink
On 10/05/2012 10:07, Jack Sleuters wrote:
> Hi, I'm a colleague of Bart Theelen and noticed the following Acceleo behavior which could be related to the performance issue:
> I created a template file which has the following calling structure:
> Step 1: Main calls template 1
> Step 2: Template 1 calls template 2
> Step 3: Template 2 calls template 3
> Step 4: Template 3 calls template 4
> Step 5: Template 4 calls template 5
> Step 6: Template 5 calls template 6
> Now, when I generate an input instance model with a large number of objects that will be processed in template 6 then the performance problem appears.
> When I change Template 5 to incorporate the contents of template 6, and effectively changing the calling depth to 5 (Step 6 is no longer performed) the performance is again up to an acceptable level!
> I created a sample ecore model and a Acceleo template file for that and attached it. It contains:
> "AcceleoScaling" project -> "Model": contains the ecore model used
> "AcceleoTest" project contains:
> • the "test.acceleotest" input file with 20000 "Records"
> • "generate.mtl", the Acceleo template file used
> Input file consisting of 20000 objects to be processed in Step 6, leaving the calling depth of 6 (Step 6 is executed) this results in a generation time of 34s.
> Changing the calling depth to 5 (as described above) results in a generation time of 3s including the loading of the input file.
> I don't know it this is only appearing in my eclipse environment but it might help in tracing the performance problem. B.t.w. I'm using Acceleo version 3.3.0M7
> Kind regards,
> Jack
Re: [Acceleo] Performance Profiling [message #873189 is a reply to message #871560] |
Thu, 17 May 2012 12:43   |
Hi Jack
Your original description was misleading, implying that there were five
levels of recursion and that a sixth was costly.
Your problem is actually very simple.
In the fast case, a for loop appends 20000 contributions directly; there
are tens of template invocations.
In the slow case, a for loop appends 20000 contributions via nested
call; there are 20000 + tens of template invocations.
So on my modest laptop, time in ms:
5 level
main 0.0
pre 1.841
post 4.914
6 level
main 0.0
pre 1.95
post 80.636
i.e 2.0 s to start and load
3.0 s to append directly
75.0 s for 20000 extra template invocations, so 3.7ms/template invocation
This is disappointing, but not unsurprising, since Acceleo is
interpreted and a template invocation is a complex activity.
In Kepler, the direct OCL 2 Java code generator may be in place and
exploited by Acceleo offering massive opportunities for improvement.
Ed Willink
On 14/05/2012 13:21, Jack Sleuters wrote:
> To rule out that my eclipse environment introduces this behaviour, I
> also tested on a colleague's Pc with eclipse configuration. The result
> was the same. At template depth of 6 the generation takes 34s. At
> template depth of 5 the generation takes about 1s.
> Did anyone try my test projects already and experience the same
> behaviour?
> Kind regards,
> Jack
Re: [Acceleo] Performance Profiling [message #876252 is a reply to message #876224] |
Thu, 24 May 2012 04:30   |
I recommend trying 3.3RC1 and some forceful refreshes, cleans and
rebuilds. Hopefully the problem is already fixed; I find 3.3 much better
now; I couldn't use 3.2 at all.
If the problem persists, any repro or VisualVM performance information
could be useful.
When things go really slow, it can be worth checking with Wireshark that
there is no untoward Ethernet traffic.
I know that the Acceleo team are pretty busy at present preparing the
Juno release. Getting a fix for this in Juno would be really good, but
probably needs help from you to make the problem as easily reproducible
as possible. Ideally a simplified template as part of a zipped project
with clear how to launch instructions; again ideally, a saved launch
config in the project.
Ed Willink
On 24/05/2012 08:28, Thomas Buchmann wrote:
> I appologize if this is not the proper thread, but i'm also facing
> massive performance issues since the update to Acceleo 3.2.1.
> Everything was fine with Acceleo 3.2.0, so maybe some performance
> glitches are not only related to bad template design?
> An Example: With Acceleo 3.2.0, a model with approx. 300 Classes has
> been generated in less than 10 seconds. With Acceleo 3.2.1 the
> transformation is running since more than 10 minutes now and it is not
> finished as i'm typing these lines. Please note that there was no
> change in the templates!
> Kind regards,
> Thomas
Re: [Acceleo] Performance Profiling [message #876366 is a reply to message #876353] |
Thu, 24 May 2012 09:07   |
Try increasing the number of open/closed projects, installed modeling
projects.
There a number of 'helpful' modeling applications that endeavour to
discover models and model elements so that you can access them easily.
These can scale very badly. Be suspicious of at least MWE, Xtext,
EMF-Index, Modisco, Acceleo.
If direct profiling doesn't help, try putting in a few
System.currentTime's to see which phase is going slow.
Try using a Java application rather than plugin launch.
If you're happy to use Acceleo 3.3.0RC1 then are you using Eclipse
4.2RC1? It seems like you're seeing something that we really want to fix.
Ed Willink
On 24/05/2012 13:44, Thomas Buchmann wrote:
> Hi Ed,
> i'm stuck. I upgraded to Acceleo 3.3.0RC1 as suggested. But the performance issues still remain. I setup a launch configuration with profiling support enabled. However, the profiling result looks fine (see attached screenshot). Nevertheless, it took 57s to complete the M2T transformation... At least i think the problem is not within the templates... But where could it be?
Re: [Acceleo] Performance Profiling [message #876446 is a reply to message #876385] |
Thu, 24 May 2012 11:52   |
If you experience the same speed ration in a nested Eclipse, I suggest
instrumenting ResourceSetImpl.loadResource with some println's to see
what resources are loaded. The problem is almost certainly something
that loads everything.
Ed Willink
On 24/05/2012 14:49, Thomas Buchmann wrote:
> Edward Willink wrote on Thu, 24 May 2012 09:07
>> projects.
> Thanks a lot for the hint Ed. I created a launch configuration for my
> toolset with only minimal requirements (Modisco & Acceleo are included
> though) and everything works fine now!! Now i'm trying to figure out,
> which plugin causes the explosion of the runtime complexity.
Current Time: Wed Jul 23 06:03:38 EDT 2025
Powered by FUDForum. Page generated in 0.13543 seconds
