Home » Archived » Buckminster » Problem migrating from Buckminster 3.6 to 3.7(Different behaviour from 3.6 to 3.7)
Problem migrating from Buckminster 3.6 to 3.7 [message #829355] Mon, 26 March 2012 03:26 Go to next message
hi,
after switching to Eclipse and Buckminster 3.7 we found, that some of our cspex didn't work anymore.
in the following sample we generate a simple file named "generated.txt" in the project directory.
this file is also referenced in the build.properties of the project.
when invoking the buckminster action "bundle.jar" the generated file is packed (as expected) into the resulting jar file when using Buckminster 3.6.
when we do the same with Buckminster 3.7 the generated file is NOT included in the jar although it's available in the project directory.
the cspex:
<cspecExtension xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
	xmlns:bc="http://www.eclipse.org/buckminster/Common-1.0" xmlns="http://www.eclipse.org/buckminster/CSpec-1.0">
	<actions>
		<private name="clean.folder" actor="ant">
			<actorProperties>
				<property key="buildFile" value="build/make.ant" />
				<property key="targets" value="clean.folder" />
			</actorProperties>
			<properties>
				<property key="gen.file" value="generated.txt" />
			</properties>
		</private>
		<private name="tst.bundle" actor="ant">
			<actorProperties>
				<property key="targets" value="tst.bundle" />
			</actorProperties>
	        <products alias="gen.file" base="${buckminster.home}">
                        <path path="generated.txt"/>
                </products>
		<prerequisites>
			<attribute name="clean.folder" />
		</prerequisites>
		</private>
	</actions>
	<alterActions>
		<public name="bundle.jar">
			<alterPrerequisites>
				<attribute name="tst.bundle" />
			</alterPrerequisites>
		</public>
	</alterActions>
</cspecExtension>
build.properties with generated.txt:
source.. = src/java/
output.. = classes/
bin.includes = META-INF/,\
               generated.txt
a complete sample project is included in the attached archive.
thanks
jakob
[Updated on: Mon, 26 March 2012 03:27] by Moderator
Re: Problem migrating from Buckminster 3.6 to 3.7 [message #849409 is a reply to message #829355] Thu, 19 April 2012 01:49 Go to previous message
bump, no one ?
Previous Topic:Materialize from SVN branch
Next Topic:[solved] RCP Build fails
Current Time: Wed Jul 23 14:53:49 EDT 2025
Powered by FUDForum. Page generated in 0.20834 seconds
