Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Resolving lists
| [Teneo] Resolving lists [message #84785] |
Thu, 24 May 2007 15:56  |
Originally posted by: irbull.cs.uvic.ca
Is there a way to tell Teneo not to resolve a list? I have two EObjects
(already loaded) and I would like to know if 1 is connected to another.
If I say
eObject1.eGet(reference).contains(eObject2) is loads the entire list of
connected eObjects. Really I want to say
eObject1.eGet(reference) -> get me all the ones you have without going
to the DB -> contains(eObject2).
Is this possible?
cheers,
ian
| Re: [Teneo] Resolving lists [message #84830 is a reply to message #84815] |
Fri, 25 May 2007 00:10   |
Ian, Ed,
Even basicList will do a load(). Teneo (Hibernate/jpox) does not know that the two objects belong
together until the eObject1.reference list is loaded. A persistable list currently either has all
its content loaded or nothing loaded. Hibernate has a 'very lazy' list concept which supports
certain operations without loading but that is not yet supported by Teneo.
Teneo automatically replaces all EList instances with a PersistableEList, this class offers an
isLoaded method to check if a collection has already been loaded.
So for now the approach can be: you can check if the eGet returns a PersistableEList, if not you can
do contains on the list, if yes (is a PersistableEList) then you can check if it is loaded, if not
then you do a hql/jdoql query to check the relation, if yes then you do contains on the
persistableelist.
This logic can be made generic by using efeature names when creating a Hql query, You can check the
innerclass HbDataStore.ReferenceTo which does something similar.
gr. Martin
Ed Merks wrote:
> Ian,
> Maybe you could do
> ((InternalEList)eObject1.eGet(reference)).basicList().contai ns(eObject2)
> which should do a contains test without resolving proxies and that might
> avoid Teneo resolving anything...
>> EObjects (already loaded) and I would like to know if 1 is connected
>> to another. If I say
>> of connected eObjects. Really I want to say
>> Is this possible?
>> cheers,
>> ian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: [Teneo] Resolving lists [message #84844 is a reply to message #84830] |
Fri, 25 May 2007 00:22   |
I don't know if this is proper, but I got it working by using the following:
Object refs = A.eGet(reference);
PersistentList list = (PersistentList) ((HibernatePersistableEList)
refs).getDelegate();
Object obj = list.getStoredSnapshot();
The stored snapshot seems to contain the list of currently loaded
references, so if A and B are loaded, and A is connected to B, then B
will be in this list.
cheers,
ian
Martin Taal wrote:
> Ian, Ed,
> that the two objects belong together until the eObject1.reference list
> is loaded. A persistable list currently either has all its content
> supports certain operations without loading but that is not yet
> supported by Teneo.
> PersistableEList, this class offers an isLoaded method to check if a
> PersistableEList, if not you can do contains on the list, if yes (is a
> PersistableEList) then you can check if it is loaded, if not then you do
> the persistableelist.
> Hql query, You can check the innerclass HbDataStore.ReferenceTo which
> gr. Martin
> Ed Merks wrote:
>> Ian,
>> Maybe you could do
>> might avoid Teneo resolving anything...
>>> going to the DB -> contains(eObject2).
>>> Is this possible?
>>> cheers,
>>> ian
| Re: [Teneo] Resolving lists [message #84874 is a reply to message #84844] |
Fri, 25 May 2007 00:37   |
I am not sure if it will work always, afaiu the snapshot is used by hibernate to detect dirty state
of the collection. So it contains the state at the start of the transaction.
For my curiosity, how does B even get into the collection of A?
gr. Martin
> following:
> cheers,
> ian
> Martin Taal wrote:
>> Ian, Ed,
>> which supports certain operations without loading but that is not yet
>> supported by Teneo.
>> contains on the persistableelist.
>> gr. Martin
>> Ed Merks wrote:
>>> Ian,
>>> Maybe you could do
>>>> Is this possible?
>>>> cheers,
>>>> ian
The Netherlands
| Re: [Teneo] Resolving lists [message #84889 is a reply to message #84874] |
Fri, 25 May 2007 01:43   |
I actually have a separate Lucene index of all my EObjects. So when I
do a query it is actually a lucene query. I have stored the UID and
table for each EObject in the lucene index file. So when the query
comes back, i get the table and UID (actually I get the MetaModel,
Database, Table, and UID).
1) I load the MetaModel
2) I load the Database
3) I select the Objects that match the UIDs from their table.
Now I have A and B, and I want to see if they are connected.
I am working on a general visualization tool for ECore. So ideally, I
can plug any ecore model (and instance data) into the tool to create
some views. Currently I am trying my work on a number of datasets and I
find Teneo a great way to persist a whole bunch of models/data.
cheers,
ian
> hibernate to detect dirty state of the collection. So it contains the
> gr. Martin
>> following:
>> cheers,
>> ian
>> Martin Taal wrote:
>>> Ian, Ed,
>>> list is loaded. A persistable list currently either has all its
>>> concept which supports certain operations without loading but that is
>>> a PersistableEList) then you can check if it is loaded, if not then
>>> a Hql query, You can check the innerclass HbDataStore.ReferenceTo
>>> gr. Martin
>>> Ed Merks wrote:
>>>> Ian,
>>>> Maybe you could do
>>>>> connected to another. If I say
>>>>> list of connected eObjects. Really I want to say
>>>>> Is this possible?
>>>>> cheers,
>>>>> ian
| Re: [Teneo] Resolving lists [message #84904 is a reply to message #84889] |
Fri, 25 May 2007 02:15   |
Interesting, some more questions from my side, how do you select the objects from the their table?
With table do you mean the eclass name?
gr. Martin
> cheers,
> ian
>> gr. Martin
>>> following:
>>> cheers,
>>> ian
>>> Martin Taal wrote:
>>>> Ian, Ed,
>>>> know that the two objects belong together until the
>>>> either has all its content loaded or nothing loaded. Hibernate has a
>>>> 'very lazy' list concept which supports certain operations without
>>>> gr. Martin
>>>> Ed Merks wrote:
>>>>> Ian,
>>>>> Maybe you could do
>>>>>> Is this possible?
>>>>>> cheers,
>>>>>> ian
The Netherlands
| Re: [Teneo] Resolving lists [message #85028 is a reply to message #84904] |
Fri, 25 May 2007 12:50   |
Yep, I am using the eclass name for the table name, and the auto
generated UID that Teneo gives every row. Then I use the following query
to get the EObjects back:
"from " + "classifier " + "where e_id = " + e_idResult
I do this for the results from my lucene query. This gives me back all
the EObjects that match my query.
Does this make sense? I am completely off my nut?
Ian
> objects from the their table? With table do you mean the eclass name?
> gr. Martin
>> I find Teneo a great way to persist a whole bunch of models/data.
>> cheers,
>> ian
>>> gr. Martin
>>>> following:
>>>> B will be in this list.
>>>> cheers,
>>>> ian
>>>> Martin Taal wrote:
>>>>> Ian, Ed,
>>>>> a 'very lazy' list concept which supports certain operations
>>>>> you do contains on the persistableelist.
>>>>> creating a Hql query, You can check the innerclass
>>>>> gr. Martin
>>>>> Ed Merks wrote:
>>>>>> Ian,
>>>>>> Maybe you could do
>>>>>>> Is this possible?
>>>>>>> cheers,
>>>>>>> ian
| Re: [Teneo] Resolving lists [message #85151 is a reply to message #84874] |
Sat, 26 May 2007 02:02  |
You're right Martin, It doesn't always work :(
I will try to create some creative HQL queries to solve this problem.
cheers,
ian
> gr. Martin
>> following:
>> cheers,
>> ian
>> Martin Taal wrote:
>>> Ian, Ed,
>>> gr. Martin
>>> Ed Merks wrote:
>>>> Ian,
>>>> Maybe you could do
>>>>> Is this possible?
>>>>> cheers,
>>>>> ian
| Re: [Teneo] Resolving lists [message #606784 is a reply to message #84785] |
Thu, 24 May 2007 16:51  |
Ian,
Maybe you could do
> Is this possible?
> cheers,
> ian
| Re: [Teneo] Resolving lists [message #606785 is a reply to message #84815] |
Ian, Ed,
persistableelist.
gr. Martin
Ed Merks wrote:
> Ian,
> Maybe you could do
>> Is this possible?
>> cheers,
>> ian
The Netherlands
| Re: [Teneo] Resolving lists [message #606786 is a reply to message #84830] |
cheers,
ian
Martin Taal wrote:
> Ian, Ed,
> supported by Teneo.
> gr. Martin
> Ed Merks wrote:
>> Ian,
>> Maybe you could do
>>> Is this possible?
>>> cheers,
>>> ian
| Re: [Teneo] Resolving lists [message #606788 is a reply to message #84844] |
gr. Martin
> following:
> cheers,
> ian
> Martin Taal wrote:
>> Ian, Ed,
>> supported by Teneo.
>> gr. Martin
>> Ed Merks wrote:
>>> Ian,
>>> Maybe you could do
>>>> Is this possible?
>>>> cheers,
>>>> ian
The Netherlands
| Re: [Teneo] Resolving lists [message #606789 is a reply to message #84874] |
cheers,
ian
> gr. Martin
>> following:
>> cheers,
>> ian
>> Martin Taal wrote:
>>> Ian, Ed,
>>> gr. Martin
>>> Ed Merks wrote:
>>>> Ian,
>>>> Maybe you could do
>>>>> Is this possible?
>>>>> cheers,
>>>>> ian
| Re: [Teneo] Resolving lists [message #606790 is a reply to message #84889] |
gr. Martin
> cheers,
> ian
>> gr. Martin
>>> following:
>>> cheers,
>>> ian
>>> Martin Taal wrote:
>>>> Ian, Ed,
>>>> gr. Martin
>>>> Ed Merks wrote:
>>>>> Ian,
>>>>> Maybe you could do
>>>>>> Is this possible?
>>>>>> cheers,
>>>>>> ian
The Netherlands
| Re: [Teneo] Resolving lists [message #606798 is a reply to message #84904] |
Ian
> gr. Martin
>> cheers,
>> ian
>>> gr. Martin
>>>> following:
>>>> cheers,
>>>> ian
>>>> Martin Taal wrote:
>>>>> Ian, Ed,
>>>>> gr. Martin
>>>>> Ed Merks wrote:
>>>>>> Ian,
>>>>>> Maybe you could do
>>>>>>> Is this possible?
>>>>>>> cheers,
>>>>>>> ian
| Re: [Teneo] Resolving lists [message #606806 is a reply to message #84874] |
cheers,
ian
> gr. Martin
>> following:
>> cheers,
>> ian
>> Martin Taal wrote:
>>> Ian, Ed,
>>> gr. Martin
>>> Ed Merks wrote:
>>>> Ian,
>>>> Maybe you could do
>>>>> Is this possible?
>>>>> cheers,
>>>>> ian
Current Time: Tue Oct 28 07:12:58 EDT 2025
Powered by FUDForum. Page generated in 1.07893 seconds
