Home » Language IDEs » Java Development Tools (JDT) » Setter ==> this.name = name;
Setter ==> this.name = name; [message #83781] Thu, 07 August 2003 09:26 Go to next message
Originally posted by: opicasso.videotron.ca
On eclipse 2.0 I had the following "Generate setter..." behaviour:
field:
private String name;
generated setter:
public void setName(String name)
this.name = name;
With eclipse 2.1, with the same field I get:
generated setter:
public void setName(String string)
name = string;
I prefere the old way of generating setters.
Is it possible to do this in eclipse 2.1 and how?
<code>
</code>
Re: Setter ==> this.name = name; [message #83868 is a reply to message #83781] Thu, 07 August 2003 15:13 Go to previous messageGo to next message
Originally posted by: pdrolet.mac.com
I initially agreed with you but now that I use Checkclipse, it complains
that this is not a good programming style because this "name" hides the
other "name" property... So I would prefer a simple "s"....
Patrice
Oscar Picasso wrote:
> field:
> generated setter:
> this.name = name;
> generated setter:
> name = string;
> <code>
> Thanks
> </code>
Re: Setter ==> this.name = name; [message #84014 is a reply to message #83781] Fri, 08 August 2003 05:52 Go to previous messageGo to next message
This 2.1 behaviour has already be fixed in the 3.0 (it's the same as in
2.0 again). Unfortunatly there's no way to have this in 2.1.
Martin
> field:
> generated setter:
> this.name = name;
> generated setter:
> name = string;
> <code>
> Thanks
> </code>
Re: Setter ==> this.name = name; [message #84118 is a reply to message #84014] Fri, 08 August 2003 09:29 Go to previous messageGo to next message
> Martin
>> Hi,
>> field:
>> generated setter:
>> this.name = name;
>> generated setter:
>> name = string;
>> <code>
>> Thanks
>> </code>
Is this configurable in 3.0? I'm running I20030703, and I'm still
seeing the old (stupid) style...
Re: Setter ==> this.name = name; [message #84537 is a reply to message #84118] Mon, 11 August 2003 10:11 Go to previous messageGo to next message
I just tried and it's in there: private int fLength ->
public int getLength() {
return fLength;
public void setLength(int length) {
fLength= length;
I also think it was in there 0703. Please try again or file a bug report
with reproducable steps.
Martin
>> in 2.0 again). Unfortunatly there's no way to have this in 2.1.
>> Martin
>>> Hi,
>>> field:
>>> generated setter:
>>> this.name = name;
>>> generated setter:
>>> name = string;
>>> <code>
>>> Thanks
>>> </code>
Re: Setter ==> this.name = name; [message #84867 is a reply to message #84537] Tue, 12 August 2003 10:59 Go to previous messageGo to next message
Ah. I think I confused myself. It think I was doing "Create Method
getLength", not actually doing set-getter. OTOH, I think this would
make an excellent enhancment to 'create method' logic (recognizing
getter/setter signatures and just making the method do the right thing)
David
> return fLength;
> fLength= length;
> Thanks
> Martin
>>> Martin
>>>> Hi,
>>>> field:
>>>> generated setter:
>>>> this.name = name;
>>>> generated setter:
>>>> name = string;
>>>> <code>
>>>> Thanks
>>>> </code>
Re: Setter ==> this.name = name; [message #85227 is a reply to message #84867] Wed, 13 August 2003 04:34 Go to previous message
Good idea, please file a bug report so it does not get lost.
> David
>> return fLength;
>> fLength= length;
>> report with reproducable steps.
>> Thanks
>> Martin
>>>> Martin
>>>>> Hi,
>>>>> field:
>>>>> generated setter:
>>>>> this.name = name;
>>>>> generated setter:
>>>>> name = string;
>>>>> <code>
>>>>> Thanks
>>>>> </code>
Previous Topic:Repost: Message-Box: No user-editable completed tasks to delete
Next Topic:Extending javafamily JSP example plug-in to also support SQLJ files
Current Time: Wed Jul 23 10:09:29 EDT 2025
Powered by FUDForum. Page generated in 0.39552 seconds
