Home » Eclipse Projects » P2 » p2.mirror and site.xm
p2.mirror and site.xm [message #660503] Fri, 18 March 2011 12:59 Go to next message
hi,
we are providing an update site that contains both site.xml and p2
artifacts stuff ( artifatcs.jar and contents.jar ), so our update site
can be cunsumed by any eclipse versions.
this is working well, but facing a little problem.
when trying to mirror this update site using p2.mirror and eclipse 3.6 ,
it seems the site.xml is fetched first and p2 recreates metadata from
it. as a results, i get some artifact.reference pointing to original
update site.
if i remove the site.xml, p2 gets correctly the metadata.
my question is : does p2 looks for a site.xml before doing anything ?
how do i tell p2.mirror not using site.xml in its miror process ?
Stéphane Bouchet, OBEO
Re: p2.mirror and site.xm [message #841549 is a reply to message #660503] Wed, 11 April 2012 09:03 Go to previous messageGo to next message
Hey Stéphane,
Did you find any solution for this issue?
We are facing the same problem trying to install artifacts located on a mirrored repository that references the original location.
Gonzague
Re: p2.mirror and site.xm [message #848393 is a reply to message #841549] Wed, 18 April 2012 03:22 Go to previous message
hi gonzague,
nope, i didn't find any solution for now, but i might look at the
p2.index file
http://wiki.eclipse.org/Equinox/p2/p2_index
Le 11/04/2012 15:03, Gonzague Reydet a écrit :
> Hey Stéphane,
> Cheers,
> Gonzague
Previous Topic:issue to generate some plugins in P2 format with a headless build.
Next Topic:Configure a p2 update repository programmatically
Current Time: Sat Jul 26 07:57:47 EDT 2025
Powered by FUDForum. Page generated in 0.07586 seconds
