Migration strategies [message #847761] |
Tue, 17 April 2012 12:22  |
Hi all,
I have been reading many articles about MWE2, Xtext, Xbase and Xtend2. Now I want to start migrating an existing RCP project based on EMF, GMF, Xpand, Xtend and oAW.
My problem is that I have a few difficulties when it comes to the right order of implementation.
I wanted to start with the generator as this is probably going to become the easiest part. Introducing Xtend seems to require an existing Xtext grammar though. Therefore defining the grammar by deriving it from the existing ecore metamodel should be the first step, right?
Although I have seen that it is possible to derive a grammar automatically, a manual reimplementation would be preferable, wouldn't it? Later the meta model is then generated from the Xtext grammar, so the current metamodels are going to be deleted then?
And where is the place for Xcore in this scenario? If I need a Xtext grammar, can Xcore still be of help? Or is this only intended for projects where Xtext is not involved on the application side?
Thanks in advance for your help!
Re: Migration strategies [message #1146532 is a reply to message #847879] |
Sun, 20 October 2013 03:51  |
Dear All,
I need your favor or suggestion regarding migrate the xtext version from 1.0.1 to 2.3.0 in custom application.
I followed all following process for migrate the xtext version.
1. Delete the old plug-ins and update the latest plug-ins in target platform.
2. Update the Plug-in Dependencies and Import Statements.
3. Introduction of the Qualified Name.
4. Changes in the index and in find references.
5. Rewritten Node Model.
6. AutoEditStrategy.
7. Other Noteworthy API Changes
To consider the above steps, I started the work with Eclipse-4.2, Which has a xtext-2.3.0 dependency. Successfully I completed the all above steps and removed the compilation error.
Problem: After that I start the testing and getting below error Messages:
[XtextLinkingDiagnostic: null:6 Couldn't resolve reference to Material 'MPS_RECUR'.,
XtextLinkingDiagnostic: null:9 Couldn't resolve reference to Cstic 'NUM_OF_ALLOC'.,
XtextLinkingDiagnostic: null:15 Couldn't resolve reference to Cstic 'INSTANCE_NUM'.,
XtextLinkingDiagnostic: null:14 Couldn't resolve reference to Class 'ALLOC'.]
FUDForum. Page generated in 0.05841 seconds
