Home » Eclipse Projects » Rich Client Platform (RCP) » JasperWave 0.9.5: external style templates, JasperReports Server, JavaBean data source(Multi platform RCP application)
JasperWave 0.9.5: external style templates, JasperReports Server, JavaBean data source [message #847733] Tue, 17 April 2012 11:49
JasperWave Report Designer 0.9.5 is now publicly available in our milestone stream.
Noteworthy items in this release include:
External Style Templates
Ability to work with existing style templates or create new ones from within the designer
Read for JasperReports styles in JasperWave for more details
JasperReports Server Integration
In this release, we added all that is necessary for full functional work with the JasperReports Server:
- support of Input Controls: LOVs, queries, validation, dynamic prompt dialog, localization
- loading of external resources: Image, Style Template
- support of Resource Bundles: reading/previewing/using
- repository element properties
A brand new wizard that simplifies significantly the process of setting up the data source and
makes the using of JavaBean data source as easy as possible.
Read JasperReports JavaBean data source in JasperWave for more details
Custom Java classes
There are a lot of places where JasperReports allows to use custom Java classes - fields, variables, parameters, expressions, etc.
We applied the new approach for loading of required classes, you never face the ClassNotFound issue during design time.
Classpath preferences might be updated at any time and chages will be dynamicly applied.
With respect,
JasperWave team
Previous Topic:Logback configuration
Next Topic:Delete command
Current Time: Fri Jul 18 23:16:48 EDT 2025
Powered by FUDForum. Page generated in 0.05410 seconds
