Home » Language IDEs » Java Development Tools (JDT) » ECLIPSE doesn't start UBUNTU 11.10(getting error 13 and tried several times)
icon9.gif  ECLIPSE doesn't start UBUNTU 11.10 [message #847386] Tue, 17 April 2012 04:54 Go to next message
Hi all,
after installing successfully eclipse on a win7 system i tried on a ubuntu 11.10 64bit but without success.
I tried a lot of solution found on google and forum but nothing seems to work Sad
I'm getting the error :
JVM terminated. Exit code=13
/usr/bin/java
-Dosgi.requiredJavaVersion=1.5
-XX:MaxPermSize=256m
-Xms40m
-Xmx512m
-jar /opt/eclipse//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
-os linux
-ws gtk
-arch x86_64
-showsplash
-launcher /opt/eclipse/eclipse
-name Eclipse
--launcher.library /opt/eclipse//plugins/org.eclipse.equinox.launcher.gtk.linux.x86_64_1.1.100.v20110505/eclipse_1407.so
-startup /opt/eclipse//plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar
--launcher.overrideVmargs
-exitdata 4b38011
-product org.eclipse.epp.package.jee.product
-vm /usr/lib/jvm/java-7-oracle
-vm /usr/bin/java
-vmargs
-Xms40m
-Xmx512m
from command line :
java -version
java version "1.6.0_31"
Java(TM) SE Runtime Environment (build 1.6.0_31-b04)
Java HotSpot(TM) Server VM (build 20.6-b01, mixed mode)
the tar i've downloaded is eclipse-SDK-3.7.2-linux-gtk-x86_64.tar.gz
ask me if you need more details and thanks in advance for help Smile
[Updated on: Tue, 17 April 2012 04:55] by Moderator
Re: ECLIPSE doesn't start UBUNTU 11.10 [message #847446 is a reply to message #847386] Tue, 17 April 2012 06:02 Go to previous message
You have a 32bit java but a 64bit eclipse.
Tom
Am 17.04.12 10:54, schrieb Theus Dark:
> Hi all,
> work :(
> /usr/bin/java
> -Xms40m
> -Xmx512m
> -os linux
> -ws gtk
> -arch x86_64
> -showsplash
> -name Eclipse
> --launcher.library
> -startup
> -exitdata 4b38011
> -vm /usr/bin/java
> -vmargs
> -Xms40m
> -Xmx512m
> from command line :
> java -version
> ask me if you need more details and thanks in advance for help :)
Previous Topic:Using Method Invocation Visitor
Next Topic:how to install a Annotation processor
Current Time: Sat Jul 26 01:11:00 EDT 2025
Powered by FUDForum. Page generated in 0.04032 seconds
