Home » Eclipse Projects » EclipseLink » ClassDescriptor.getTable() NULL
ClassDescriptor.getTable() NULL [message #846662] Mon, 16 April 2012 10:53 Go to next message
Hi All,
Below is strucuturefor single table inheritance
@Table(name = "REL_PROVIDERS")
@DiscriminatorValue("INPR")
@Cacheable(false) // If not leads to recursion in TLG
public class IndividualProviderDomain extends IndividualProviderPersistable
@MappedSuperclass
public abstract class IndividualProviderPersistable extends ProviderDomain implements IndividualProvider, DynamicLanguageAware
@Entity
@Configurable
@Inheritance(strategy = InheritanceType.SINGLE_TABLE)
@DiscriminatorColumn(name = "SUBTYPE", discriminatorType = DiscriminatorType.STRING, length = 20)
public class ProviderDomain extends ProviderPersistable
@MappedSuperclass
public abstract class ProviderPersistable implements Provider, DynamicFieldDynamicLanguageAware
In session customizing phase when I grab a class descriptor on IndividualProviderDomain and call getTableName() on it I get NULL.
I debugged the EntityProcessor.processTableAndInheritance() and found that
if (hasInheritance() || ! rootDescriptor.usesSingleTableInheritanceStrategy()) {
processTable();
is never hit
hasInteritance() >>> false as I have not put @Inheritance on IndividualProviderDomain (Is it required????) and
rootDescriptor (ProviderDomain).usesSingleTableInheritanceStrategy() == true
so the processTable is never hit and no meta data for table.
Also I have observed if I have put the IndividuaProvdier on GridCache, TLG code goes in to recursion, which composing entity, I am not sure, whether these as related issue.
Looking for suggestions
Gaurav Malhotra
Oracle NL
[Updated on: Mon, 16 April 2012 10:57] by Moderator
Re: ClassDescriptor.getTable() NULL [message #846663 is a reply to message #846662] Mon, 16 April 2012 10:56 Go to previous messageGo to next message
I am using eclipselink 2.3.2.
Re: ClassDescriptor.getTable() NULL [message #846675 is a reply to message #846663] Mon, 16 April 2012 11:59 Go to previous messageGo to next message
A @MappedSuperclass cannot extend an @Entity, only the other way around.
Change IndividualProviderPersistable to be an @Entity.
Re: ClassDescriptor.getTable() NULL [message #846784 is a reply to message #846675] Mon, 16 April 2012 14:52 Go to previous messageGo to next message
Everthing worked fine in the deployed env/integration tests... search/insert/update/delete
I was wondering what is reason behind this? @MappedSupperClass cannot extend an entity?
[Updated on: Tue, 17 April 2012 04:03] by Moderator
Re: ClassDescriptor.getTable() NULL [message #847375 is a reply to message #846784] Tue, 17 April 2012 04:38 Go to previous messageGo to next message
Adding @Entity on the IndividualProviderPersistable has the same affect
@Entity
Re: ClassDescriptor.getTable() NULL [message #847392 is a reply to message #847375] Tue, 17 April 2012 04:58 Go to previous message
Interestingly adding adding @Inheritance made it work
@Entity
@Configurable
public class IndividualProviderDomain extends IndividualProviderPersistable {
@Autowired
private transient GenericCoherencePofWriter genericCoherencePofWriter;
@Autowired
private transient GenericCoherencePofReader genericCoherencePofReader;
Seems to me the following check in EntityAccessor is not covering all the scenarios
processTable();
[Updated on: Tue, 17 April 2012 08:01] by Moderator
Previous Topic:Default strategy for PostgreSQL
Next Topic:serialUID mismatch on remote EJB call
Current Time: Wed Jul 23 13:23:02 EDT 2025
Powered by FUDForum. Page generated in 0.04770 seconds
