Home » Language IDEs » Java Development Tools (JDT) » Create a new xml file from java code
Create a new xml file from java code [message #846090] Sun, 15 April 2012 15:01 Go to next message
I like to parse the java code with jdt and then write by code some xml or other file. Im am using this code:
IPackageFragment ppp = xfragmentRoot.createPackageFragment(gen.packageName, false, null);
ppp.createCompilationUnit(gen.name, gen.content.toString(), true, null);
If I try to create a xml file (i.e. gen.name = "abc.xml"), the this exception is throw:
Caused by: Java Model Exception: Java Model Status [Invalid name specified: abc.xml]
at org.eclipse.jdt.internal.core.JavaModelOperation.runOperation(JavaModelOperation.java:784)
at org.eclipse.jdt.internal.core.PackageFragment.createCompilationUnit(PackageFragment.java:145)
How can I write a xml (or other extensions)?
Thanks in advance for help!
Re: Create a new xml file from java code [message #846100 is a reply to message #846090] Sun, 15 April 2012 15:16 Go to previous messageGo to next message
Compilation Units are for Java source files, only.
Hence .xml is not accepted as the extension.
For other files use types below org.eclipse.core.resources.IResource.
Starting from an IPackageFragment you may want to do s.t. like
  IFolder packageFolder = pkg.getResource();
  IFile file = packageFolder.getFile(new Path(...));
  file.create(..);
HTH,
Stephan
Re: Create a new xml file from java code [message #846803 is a reply to message #846100] Mon, 16 April 2012 15:18 Go to previous message
Work! Many thanks!
Previous Topic:get rid of -Djava.endorsed.dirs="/opt/local/share/java/tomcat6/endorsed"
Next Topic:Using Method Invocation Visitor
Current Time: Wed Jul 23 06:46:33 EDT 2025
Powered by FUDForum. Page generated in 0.03909 seconds
