Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] id column get value from sequence
[Teneo] id column get value from sequence [message #84540] Wed, 23 May 2007 04:38 Go to next message
Hi Martin,
when id column's generator set as native ,
I should make the id get value from some sequence , right?
Anthony
Re: [Teneo] id column get value from sequence [message #84548 is a reply to message #84540] Wed, 23 May 2007 05:45 Go to previous messageGo to next message
Hi Anthony,
Just setting these two annotations:
@Id
@GeneratedValue
results in a native id mapping in hbm.
Btw, it can be handy to use an edatatype for the id eattributes and then set the annotation on the
edatatype.
gr. Martin
Anthony wrote:
> Hi Martin,
> Anthony
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] id column get value from sequence [message #84556 is a reply to message #84548] Wed, 23 May 2007 05:56 Go to previous messageGo to next message
Martin,
I have db table already , so I cannot update schema in runtime.
I am using DB2 , I had set the primary key with Identity attribute.
Now it is OK.
1 questions need your help:
I create 1 Network object and 1 Label object,
then I add Label object into Network object,
then save().
stacktrace :
org.hibernate.StaleStateException: Batch update returned unexpected row
count from update [0]; actual row count: 0; expected: 1
at org.hibernate.jdbc.Expectations$BasicExpectation.checkBatche d
(Expectations.java:61)
at org.hibernate.jdbc.Expectations$BasicExpectation.verifyOutco me
(Expectations.java:46)
at org.hibernate.jdbc.NonBatchingBatcher.addToBatch
(NonBatchingBatcher.java:24)
at org.hibernate.persister.entity.AbstractEntityPersister.updat e
(AbstractEntityPersister.java:2403)
at org.hibernate.persister.entity.AbstractEntityPersister.updat eOrInsert
(AbstractEntityPersister.java:2307
a fragment of mapping file as below:
<class entity-name="LogisticsNetwork" abstract="false" lazy="false"
table="SNOW.T_NETWORK1">
<bag name="labels" lazy="false" cascade="all,delete-orphan">
<key update="true">
<column name="network_id" not-null="false"
unique="false"/>
</key>
<one-to-many entity-name="Label"/>
</bag>
</class>
<class entity-name="Label" abstract="false" lazy="false"
table="SNOW.T_LABEL">
<id name="id" type="int" column="label_id" >
<generator class="native"/>
</id>
<property name="name" lazy="false" insert="true"
update="true" not-null="true" unique="false" type="java.lang.String">
<column not-null="true" unique="true"
name="label_name"/>
</property>
<property name="typeValue" lazy="false" not-null="false"
insert="true" update="true" unique="false" type="int">
<column not-null="false" unique="false"
name="label_type"/>
</property>
</class>
How can I work around this?
Reagrds,
Anthony
Martin Taal <mtaal@elver.org> wrote in
news:f312gj$deh$1@build.eclipse.org:
> Hi Anthony,
> @Id
> @GeneratedValue
> then set the annotation on the edatatype.
> gr. Martin
> Anthony wrote:
>> Hi Martin,
>> Anthony
Re: [Teneo] id column get value from sequence [message #84560 is a reply to message #84556] Wed, 23 May 2007 06:13 Go to previous messageGo to next message
My guess is that it expects that either network or label already exist and it tries to update them
instead of doing an insert. Can you debug into hibernate and check which one is the cause?
gr. Martin
Anthony wrote:
> Martin,
> Now it is OK.
> then save().
> stacktrace :
> <key update="true">
> unique="false"/>
> </key>
> </bag>
> </class>
> </id>
> name="label_name"/>
> </property>
> name="label_type"/>
> </property>
> </class>
> Reagrds,
> Anthony
>> Hi Anthony,
>> @Id
>> @GeneratedValue
>> gr. Martin
>> Anthony wrote:
>>> Hi Martin,
>>> Anthony
The Netherlands
Re: [Teneo] id column get value from sequence [message #84566 is a reply to message #84560] Wed, 23 May 2007 07:25 Go to previous messageGo to next message
Martin,
In Hibernate ActionQueue's prepareActions() ,
the Label object is in collectionCreations ,but the
ExecutableAction's persister(is a OneToManyPersister)'s
sqlInsertRowString is "update ....."
and
sqlDeleteRowString also is "update..."
no "insert..." or "delete ..."
It seems some setting let hibernate think the Label should be exist in
table.
Anthony
> and it tries to update them instead of doing an insert. Can you debug
> gr. Martin
> Anthony wrote:
>> Martin,
>> attribute. Now it is OK.
>> then save().
>> stacktrace :
>> row count from update [0]; actual row count: 0; expected: 1
>> at
>> <key update="true">
>> unique="false"/>
>> </key>
>> </bag>
>> </class>
>> </id>
>> name="label_name"/>
>> </property>
>> name="label_type"/>
>> </property>
>> </class>
>> Reagrds,
>> Anthony
>>> Hi Anthony,
>>> @Id
>>> @GeneratedValue
>>> gr. Martin
>>> Anthony wrote:
>>>> Hi Martin,
>>>> Anthony
Re: [Teneo] id column get value from sequence [message #84572 is a reply to message #84566] Wed, 23 May 2007 11:02 Go to previous message
Anthony,
This can happen if the id of label has a non-null value (or a value which hibernate interprets as an
existing object). What is the id value of label?
gr. Martin
Anthony wrote:
> Martin,
> and
> table.
> Anthony
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> then save().
>>> stacktrace :
>>> at
>>> <key update="true">
>>> unique="false"/>
>>> </key>
>>> </bag>
>>> </class>
>>> </id>
>>> name="label_name"/>
>>> </property>
>>> name="label_type"/>
>>> </property>
>>> </class>
>>> Reagrds,
>>> Anthony
>>>> Hi Anthony,
>>>> @Id
>>>> @GeneratedValue
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Hi Martin,
>>>>> Anthony
The Netherlands
Re: [Teneo] id column get value from sequence [message #606769 is a reply to message #84540] Wed, 23 May 2007 05:45 Go to previous message
Hi Anthony,
@Id
@GeneratedValue
edatatype.
gr. Martin
Anthony wrote:
> Hi Martin,
> Anthony
The Netherlands
Re: [Teneo] id column get value from sequence [message #606770 is a reply to message #84548] Wed, 23 May 2007 05:56 Go to previous message
Martin,
Now it is OK.
then save().
stacktrace :
<key update="true">
unique="false"/>
</key>
</bag>
</class>
</id>
name="label_name"/>
</property>
name="label_type"/>
</property>
</class>
Reagrds,
Anthony
> Hi Anthony,
> @Id
> @GeneratedValue
> gr. Martin
> Anthony wrote:
>> Hi Martin,
>> Anthony
Re: [Teneo] id column get value from sequence [message #606771 is a reply to message #84556] Wed, 23 May 2007 06:13 Go to previous message
gr. Martin
Anthony wrote:
> Martin,
> Now it is OK.
> then save().
> stacktrace :
> <key update="true">
> unique="false"/>
> </key>
> </bag>
> </class>
> </id>
> name="label_name"/>
> </property>
> name="label_type"/>
> </property>
> </class>
> Reagrds,
> Anthony
>> Hi Anthony,
>> @Id
>> @GeneratedValue
>> gr. Martin
>> Anthony wrote:
>>> Hi Martin,
>>> Anthony
The Netherlands
Re: [Teneo] id column get value from sequence [message #606772 is a reply to message #84560] Wed, 23 May 2007 07:25 Go to previous message
Martin,
and
table.
Anthony
> gr. Martin
> Anthony wrote:
>> Martin,
>> then save().
>> stacktrace :
>> at
>> <key update="true">
>> unique="false"/>
>> </key>
>> </bag>
>> </class>
>> </id>
>> name="label_name"/>
>> </property>
>> name="label_type"/>
>> </property>
>> </class>
>> Reagrds,
>> Anthony
>>> Hi Anthony,
>>> @Id
>>> @GeneratedValue
>>> gr. Martin
>>> Anthony wrote:
>>>> Hi Martin,
>>>> Anthony
Re: [Teneo] id column get value from sequence [message #606773 is a reply to message #84566] Wed, 23 May 2007 11:02 Go to previous message
Anthony,
gr. Martin
Anthony wrote:
> Martin,
> and
> table.
> Anthony
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> then save().
>>> stacktrace :
>>> at
>>> <key update="true">
>>> unique="false"/>
>>> </key>
>>> </bag>
>>> </class>
>>> </id>
>>> name="label_name"/>
>>> </property>
>>> name="label_type"/>
>>> </property>
>>> </class>
>>> Reagrds,
>>> Anthony
>>>> Hi Anthony,
>>>> @Id
>>>> @GeneratedValue
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Hi Martin,
>>>>> Anthony
The Netherlands
Previous Topic:[Teneo] id column get value from sequence
Next Topic:[Teneo] how to get e_id?
Current Time: Thu Jul 24 21:55:33 EDT 2025
Powered by FUDForum. Page generated in 0.07548 seconds
