Home » Eclipse Projects » Eclipse 4 » Zest integration
Zest integration [message #844731] Sat, 14 April 2012 05:36 Go to next message
Goodmorning at all.
I'm trying to include Zest packages in my e4 application.
When I try to add one of Zest Packages in my plugin.xml's dependencies I've got this error:
java.lang.RuntimeException: No application id has been found.
(Complete log is in the attachment)
I've seen that it could be caused by a missing dependence, but which one?
Does anyone know a solution?
Very thank you,
regards.
Re: Zest integration [message #845166 is a reply to message #844731] Sat, 14 April 2012 16:33 Go to previous messageGo to next message
Judging just from the error log it looks like you are missing the org.eclipse.zest.core dependency.
Also make sure it is included in your run configuration: Run -> Run configurations...->(your app's running config)-> plugins tab
Re: Zest integration [message #852030 is a reply to message #845166] Sat, 21 April 2012 11:47 Go to previous messageGo to next message
If you still have this issue, it would be great if you could file a bug against Zest with some details, so we can keep track of this.
Re: Zest integration [message #856008 is a reply to message #844731] Wed, 25 April 2012 05:38 Go to previous messageGo to next message
Thank you all, bug fixed.
But I don't know where I had to create my graph to see it in a part.
I've tryed in @PostConstruct method, but it doesn't work.
@PostConstruct
	public void createControls(Composite parent) {
		Graph g = new Graph(shell, SWT.NONE);
		GraphNode n = new GraphNode(g, SWT.NONE, "Paper");
		GraphNode n2 = new GraphNode(g, SWT.NONE, "Rock");
		GraphNode n3 = new GraphNode(g, SWT.NONE, "Scissors");
		new GraphConnection(g, SWT.NONE, n, n2);
		new GraphConnection(g, SWT.NONE, n2, n3);
		new GraphConnection(g, SWT.NONE, n3, n);
		g.setLayoutAlgorithm(new SpringLayoutAlgorithm(LayoutStyles.NO_LAYOUT_NODE_RESIZING), true);
Part is still empty. Suggestions?
Very thanks for your kind.
Re: Zest integration [message #856020 is a reply to message #856008] Wed, 25 April 2012 05:45 Go to previous messageGo to next message
Try
        @PostConstruct
	public void createControls(@Named(IServiceConstants.ACTIVE_SHELL) Shell shell)
Re: Zest integration [message #856466 is a reply to message #856008] Wed, 25 April 2012 13:35 Go to previous messageGo to next message
Tommaso De Sica wrote on Wed, 25 April 2012 05:38
@PostConstruct
Shouldn't that be
new Graph(parent ...)
(i.e., not shell).
Re: Zest integration [message #857065 is a reply to message #856466] Thu, 26 April 2012 04:06 Go to previous messageGo to next message
Brian de Alwis wrote on Wed, 25 April 2012 19:35
@PostConstruct
Shouldn't that be
(i.e., not shell).
It works. No other problems for the moment.
Thank you very much for help.
Re: Zest integration [message #904013 is a reply to message #857065] Mon, 27 August 2012 11:13 Go to previous messageGo to next message
Hello Tommaso,
so zest has gone e4 completely? do you need the 'compatibility layer' to do the zest e4 integration?
Johnny
Tommaso De Sica wrote on Thu, 26 April 2012 04:06
@PostConstruct
Shouldn't that be
(i.e., not shell).
Re: Zest integration [message #904073 is a reply to message #904013] Mon, 27 August 2012 13:43 Go to previous messageGo to next message
I only use basic components and features from Zest library, but they work perfectly on e4 without any addons.
If you want my code for an example, just contact me via PM.
[Updated on: Mon, 27 August 2012 13:44] by Moderator
Re: Zest integration [message #904099 is a reply to message #904073] Mon, 27 August 2012 14:44 Go to previous message
Thanks Tommaso! That would be great if I could take a look at how far you have gone with Zest, and learn stuffs from you. Unfortunately I don't think there's a PM feature on eclipse forum Sad
Can you instead shoot me an email at job.jieqin@gmail.com?
Johnny
Tommaso De Sica wrote on Mon, 27 August 2012 13:43
Previous Topic:Import existing jar file
Next Topic:Uninstalled Model Addon Show Error continuously.
Current Time: Fri Jul 25 06:18:02 EDT 2025
Powered by FUDForum. Page generated in 0.05938 seconds
