Re: Failed to activate Greenpages Sample in Virgo 3.0.2 [message #846610 is a reply to message #844477] |
Mon, 16 April 2012 04:29   |
Glad it's kind of working for you now. But I'm not sure what went wrong for you and I'd like to understand. I downloaded Greenpages 2.4.0.RELEASE.zip, unzipped it, built it with mvn package, and then looked inside the generated PAR file at the JPA bundle. javax.persistence is included in the import-package header:
Manifest-Version: 1.0
Bundle-Classpath: .
Built-By: glynnormington
Tool: Bundlor 1.0.0.RELEASE
Bundle-Name: GreenPages JPA
Created-By: Apache Maven
Import-Bundle: com.springsource.org.eclipse.persistence;version="[1.0.
0, 1.0.0]",com.springsource.org.eclipse.persistence.jpa;version="[1.0
.0, 1.0.0]"
Bundle-Vendor: SpringSource Inc.
Bundle-Version: 2.4.0
Build-Jdk: 1.6.0_29
Bundle-ManifestVersion: 2
Import-Package: greenpages;version="[2.4, 2.5)",javax.persistence;vers
ion="[1.0.0, 1.0.0]",javax.sql;version="0",org.apache.commons.dbcp;ve
rsion="[1.2.2.osgi, 1.2.2.osgi]",org.springframework.beans.factory.an
notation;version="[3.0, 3.1)",org.springframework.context.weaving;ver
sion="[3.0, 3.1)",org.springframework.core.io;version="[3.0, 3.1)",or
g.springframework.dao.annotation;version="[3.0, 3.1)",org.springframe
work.orm.jpa;version="[3.0, 3.1)",org.springframework.orm.jpa.vendor;
version="[3.0, 3.1)",org.springframework.stereotype;version="[3.0, 3.
1)",org.springframework.transaction.annotation;version="[3.0, 3.1)",o
rg.springframework.transaction.aspectj;version="[3.0, 3.1)"
Bundle-SymbolicName: greenpages.jpa
Archiver-Version: Plexus Archiver
Did you try using Greenpages 2.4.0.RELEASE (before you started building it yourself from the git repo)?
Re: Failed to activate Greenpages Sample in Virgo 3.0.2 [message #848613 is a reply to message #846610] |
Wed, 18 April 2012 08:09   |
Well ... I downloaded the version flagged with 2.5.0 from here -> git.eclipse.org/c/virgo/org.eclipse.virgo.sample-greenpages.git/snapshot/org.eclipse.virgo.sample-greenpages-master.zip
and this Zip has the following content in the JPA Manifest after invoking Maven:
Built-By: daniel.sxxxxx
Tool: Bundlor 1.1.0.M04
Created-By: Apache Maven 3.0.4
Import-Bundle: com.springsource.org.eclipse.persistence;version="",com.springsource.org.eclipse.persistence.jpa;version=""
Build-Jdk: 1.6.0_31
Bundle-Version: 2.5.0
Import-Package: greenpages;version="[2.5, 2.6)",javax.sql;version="0",
org.apache.commons.dbcp;version="[1.2.2.osgi, 1.2.2.osgi]",org.spring
framework.context.weaving;version="[3.0, 3.5)",org.springframework.da
o.annotation;version="[3.0, 3.5)",org.springframework.orm.jpa;version
="[3.0, 3.5)",org.springframework.orm.jpa.vendor;version="[3.0, 3.5)"
,org.springframework.transaction.aspectj;version="[3.0, 3.5)"
Re: Failed to activate Greenpages Sample in Virgo 3.0.2 [message #849509 is a reply to message #848868] |
Thu, 19 April 2012 03:58  |
Thanks Daniel. Then perhaps you've simply missed the steps committers would normally take to build the git repo using ant (see the build tab of the Virgo wiki for details) and then take the resultant Greenpages zip and do a maven build as per the Greenpages guide. Hope that solves the problem!!
[Updated on: Thu, 19 April 2012 03:58] by Moderator
FUDForum. Page generated in 0.05599 seconds
