Home » Archived » Lua Development Tools » Bad request 400 error
Bad request 400 error [message #844246] Fri, 13 April 2012 17:12 Go to next message
When attempting to get the remote debugger running on my project I'm getting a Http/1.1 400 Error Invalid Request (I figured this out by printing all the bytes in the read_packet function). I'm curious as to what would cause this. I'm using all the defaults (by passing in nil for host,port,idekey) 127.0.0.1, port 10000 and "idekey" and I haven't changed any of the settings (like port) in the Koneki debugger. I'm using local file path resolution with an absolute path to my lua files.
I am running locally on one machine so the default local address should be fine.
[Updated on: Fri, 13 April 2012 17:24] by Moderator
Re: Bad request 400 error [message #844259 is a reply to message #844246] Fri, 13 April 2012 17:30 Go to previous messageGo to next message
Hi Terrance,
You should try using a different port than 10000 ; it looks like the 400 error is returned by an existing server running on your machine, since I am pretty much sure this doesn't come from neither DLTK nor the LDT debugger.
If you try another port, don't forget to also change the setting in the IDE in "Preferences > Dynamic Languages > Debug"
Benjamin.
Re: Bad request 400 error [message #844280 is a reply to message #844259] Fri, 13 April 2012 17:56 Go to previous message
That's it thanks. I didn't think of trying a different port because this had previously been working on all default settings before. Perhaps there was something I wasn't running previously so that port wasn't in use. Not sure what would be taking that port from me now but I got it working anyway, thanks.
Previous Topic:Cannot create OMA-DM simulator
Next Topic:Some questions of LDT on MacOSX
Current Time: Sun Jul 27 18:14:23 EDT 2025
Powered by FUDForum. Page generated in 0.03474 seconds
