Home » Modeling » Graphiti » Search within a diagram
Search within a diagram [message #841936] Wed, 11 April 2012 17:47 Go to next message
Hi there,
I was wondering if anyone had experience with searching (for text) within a diagram?
In particular, I was wondering if it is more efficient to search on the diagram or the model files?
Are there methods to recenter the canvas and select the result of a search (in the simple case of a single result, for instance)?
Joe
Re: Search within a diagram [message #842369 is a reply to message #841936] Thu, 12 April 2012 04:26 Go to previous messageGo to next message
Hello Josef,
I had to do something like that some time ago. I´ve ended up by searching on the model files using this : http://wiki.eclipse.org/EMF_Search
To select the result of a searh in the diagram I guess I would take a look at setSelectionProvider method in IWorkbenchSite.
Joao
[Updated on: Thu, 12 April 2012 04:27] by Moderator
Re: Search within a diagram [message #843594 is a reply to message #841936] Fri, 13 April 2012 03:22 Go to previous messageGo to next message
I have no experience with searching, but I can suggest to use
DiagramEditor.selectPictogramElements(PE[]) for bringing the focus on the
search result.
Michael
Re: Search within a diagram [message #843978 is a reply to message #843594] Fri, 13 April 2012 11:05 Go to previous messageGo to next message
Thank you Joao and Michael, This looks to point me in the right direction.
Joe
Re: Search within a diagram [message #847608 is a reply to message #843594] Tue, 17 April 2012 09:28 Go to previous messageGo to next message
No Message Body
[Updated on: Tue, 17 April 2012 09:59] by Moderator
Re: Search within a diagram [message #850716 is a reply to message #847608] Fri, 20 April 2012 04:58 Go to previous message
Hm, an instant idea would be that the PE you pass is no longer valid (has
been reloaded as part of an editor refresh or reload)?
Michael
Previous Topic:Suggestion for 0.9 (sample/tutorial)
Next Topic:Read-Only Graphiti Diagrams
Current Time: Thu Jul 24 22:08:57 EDT 2025
Powered by FUDForum. Page generated in 0.08410 seconds
