Home » Modeling » TMF (Xtext) » Need some help
icon5.gif  Need some help [message #840767] Tue, 10 April 2012 09:43 Go to next message
Hi all,
I am new into XTEXT and I am stuck completely. I got a DSL which definies simple
commands.
alias partner "org.free.project.partner"
create partner:aPartner CTPartner
call aPartner.setName("John Doe")
The package org.free.project.partner is a third-party library and contains a class ObjectFactory for creating instances of the classes in that package.
The second line should create an instance of CTPartner by using the ObjectFactory.
The third line calls the Method setName on the created instance.
Actually I am lost in all the jvmType-stuff. I managed to use jvmTypes but then I need to use a qualified name. I would prefer the above syntax. Defining an alias and then using the simple name of the class.
Second I would like to get a proposal of all methods of CTPartner when I type in aPartner and then hit CTRL+SPACE.
How can I manage that? I already checked some classes like the subclass of AbstractModelInferrer and the ProposalProvider but I have no clue where to start.
I spent the whole day searching for howtos and tutorials but I only got the typicall
ones like h**p://www.eclipse.org/Xtext/documentation/
Thanks a lot
Goran
Re: Need some help [message #841038 is a reply to message #840767] Tue, 10 April 2012 16:44 Go to previous messageGo to next message
Can you post your grammar?
- henrik
On 2012-10-04 15:43, Goran Marjanovic wrote:
> Hi all,
> definies simple
> commands.
> that package.
> ObjectFactory.
> where to start.
> the typicall
> Thanks a lot
> Goran
Re: Need some help [message #841281 is a reply to message #841038] Wed, 11 April 2012 01:40 Go to previous messageGo to next message
Hi Henrik,
this grammar does not recognize the Java class as the "javaType" is an ID.
grammar de.demo.scripting.editor.BiproScript with org.eclipse.xtext.xbase.Xbase
import "h**p://www.eclipse.org/xtext/common/JavaVMTypes" as jvmTypes
generate biproScript "h**p://www.demo.de/scripting/editor/BiproScript"
BiproModel:
	script+=AbstractCommand*;
AbstractCommand:
	SimpleCommand | ServiceCommand | ComplexCommand;
SimpleCommand:
	Alias | Create | Call;
Alias:
	'alias' name=ID packageName=STRING;
Create:
	'create' myAlias=[Alias] ':' name=ID javaType=ID;
Call:
	'call' myCreate=[Create] '.' callValue+=MethodName ('.' callValue+=MethodName)*;
MethodName:
	name=ID params=Method;
Method:
	{Method}'('(params+=JvmFormalParameter (',' params+=JvmFormalParameter)*)? ')';
If I use the following grammar for the Create-Command
Create:
	'create' myAlias=[Alias] ':' name=ID javaType=[jvmTypes::JvmType|QualifiedName];
I get all classes as a proposal but I need to use the full qualified name.
This is what I would like:
  • alias-command for imports
  • create-command with reference to an alias and the simplename. The proposal should be only the classes which belong to the package defined by the alias
  • when pressing CTRL+SPACE (or when pressing '.') the call-command should propose all methods of the object defined by create
I need a hint where and how to start. Maybe some starting classes and methods.
Thanks in advance!!!
Goran
[Updated on: Wed, 11 April 2012 01:41] by Moderator
Re: Need some help [message #841661 is a reply to message #841281] Wed, 11 April 2012 11:47 Go to previous messageGo to next message
> Create:
This looks like the right start. You now get a reference to a JvmType.
> by the alias
> methods.
The first step is to define the references to some particular type in
your grammar (like the JvmType, but there are many other types in the
jvmTypes package).
Secondly, you implement the Scoping that defines what is visible in a
particular location.
Suggest you start by reading up on how scoping works.
- henrik
Re: Need some help [message #841723 is a reply to message #841661] Wed, 11 April 2012 13:08 Go to previous messageGo to next message
Thanks....I will check the Scope API...
Goran
Re: Need some help [message #842547 is a reply to message #841723] Thu, 12 April 2012 07:54 Go to previous messageGo to next message
Well...2 out of 3. My alias import works fine and the Java-Objectlookup also. Here is how I've done it.
Import
One important thing is how the grammar is defined. My alias-command was definied like:
Alias:
I changed it to
Alias:
	'alias' name=ID importedNamespace=QualifiedNameWithWildCard
The most important thing was changing the name from packageName to importedNamespace. Now I can cross-reference to my Java-Objects.
Propose only the classes within the package
This was more tricky (at least for me). First I tried by scoping, but I did not get further as I didn't find how and where to start. But then I used my ProposalProvider in the following way:
	public void completeCreate_JavaType(EObject model, Assignment assignment, ContentAssistContext context, ICompletionProposalAcceptor acceptor) {
		super.lookupCrossReference(((CrossReference) assignment.getTerminal()), context, acceptor, new CreateFilter((Create) model));
The CreateFilter is an inner-class:
class CreateFilter implements Predicate<IEObjectDescription> {
		private QualifiedName packageQName;
		public CreateFilter(Create createModel) {
			String[] segments = createModel.getNamespace().getImportedNamespace().split("\\.");
			this.packageQName = QualifiedName.create(segments).skipLast(1);
		public boolean apply(IEObjectDescription input) {
			QualifiedName name = input.getQualifiedName();
			// skipLast to remove the wildcard
			return name.startsWith(packageQName);
This works for me. If I hit CTRL+SPACE in my create-command I only got the classes from the corresponding package proposed. For all newbies out there: I found this solution by a step-by-step debugging and reading the source code. It's hard but I succeeded. I don't know if there is a nicer way, but for me it works.
Now next thing is to get the method-names proposed.
Goran
[Updated on: Thu, 12 April 2012 07:56] by Moderator
Re: Need some help [message #843946 is a reply to message #842547] Fri, 13 April 2012 10:27 Go to previous messageGo to next message
well, I am not happy with this solution as the performance is bad. I tried to solve it with a ScopeProvider. Here is the code for filtering the classes depending on the package:
Create create = (Create) context;
IScope scope = super.getScope(context, reference);
String[] segments = create.getImports().getImportedNamespace().split("\\.");
QualifiedName packageQName = QualifiedName.create(segments).skipLast(1);
Iterable<IEObjectDescription> it = scope.getAllElements();
ArrayList<IEObjectDescription> list = new ArrayList<IEObjectDescription>();
for (IEObjectDescription descr : it) {
    if (descr.getQualifiedName().startsWith(packageQName)) {
        list.add(descr);
return new SimpleScope(list, false);
Now, while debugging, I can see that the super.getScope()-call returns a scope
where all classes are already fetched.
But the only way to get to the classes is by calling getAllAlements() which needs
a lot of time. Is there a faster way to get the classes?
Goran
Re: Need some help [message #844047 is a reply to message #843946] Fri, 13 April 2012 12:25 Go to previous messageGo to next message
Goran,
you could implement the IScope interface manually and delegate to the
super scope (which is populated lazily if you don't call
getAllElements). You own scope would basically look like this:
MyScope implements IScope {
MyScope(IScope delegate) { this.delegate = delegate }
public IEObjectDescription getSingleElement(QualifiedName name) {
if (name matches import criteria) {
return delegate.getSingleElement(name);
return IScope.NULLSCOPE;
public Iterable<IEObjectDescription> getElements(final QualifiedName
name) {
return delegate.getElements(name);
.. similar for the other methods ..
Sebastian
Am 13.04.12 16:27, schrieb Goran M.:
> String[] segments =
> list.add(descr);
> scope
> which needs
> Regards
> Goran
Re: Need some help [message #844051 is a reply to message #843946] Fri, 13 April 2012 12:25 Go to previous messageGo to next message
Goran,
name) {
Sebastian
> String[] segments =
> list.add(descr);
> scope
> which needs
> Regards
> Goran
Re: Need some help [message #845785 is a reply to message #844051] Sun, 15 April 2012 08:22 Go to previous messageGo to next message
Hi Sebastian,
thanks for your answer. I still got a little problem I tested with the following grammar (just the important parts):
Import:
    'import' name=ID importedNamespace=QualifiedNameWithWildCard;
QualifiedNameWithWildCard :
    QualifiedName  ('.' '*')?;
Entity:
    'entity' name=ValidID
        ('extends' aAlias=[Import] superType=JvmTypeReference)? '{'
        features+=Feature*
So if I define an entity like
import util java.util.*;
import sql java.sql.*;
entity test extends sql
If I hit CTRL+SPACE after sql, I got the whole java type list.
I debugged the methods and I got "sql" and "util" as QualifiedName which references the import but not the java-package.
Additionaly I am not sure if I do it the right way.
I have overwritten my XXXRuntimeModule:
public void configureIScopeProviderDelegate(Binder binder) {
		binder.bind(org.eclipse.xtext.scoping.IScopeProvider.class)
		.annotatedWith(Names.named(org.eclipse.xtext.scoping.impl.AbstractDeclarativeScopeProvider.NAMED_DELEGATE))
		.to(MyDslScopeProvider.class);
and my getScope-method of my IScope-implementingh class returns:
return new MyDslSope(super.getScope(....));
is that right?
Maybe I should check the globalScope as the import is accessible global....
Sorry about the questions, but I am still bloody damn new to the whole stuff...
Goran
Re: Need some help [message #845803 is a reply to message #845785] Sun, 15 April 2012 08:35 Go to previous messageGo to next message
Hi Goran,
trying to introduce aliases for imported namespaces is another story.
The JvmTypeReferences uses qualified names internally thus it's always
allowed to use the FQN of a class. The imports are handled by
ImportNormalizers which will introduce aliases for FQNs if a certain
import clause is present. You may want to dig into
ImportedNamespaceAwareLocalScopeProvider.internalGetImportedNamespaceResolvers(EObject,
boolean) to implement your alias semantic. Please not that it's usually
not necessary to have an attribute aAlias before a type reference.
Hope that helps,
Sebastian
Am 15.04.12 14:22, schrieb Goran M.:
> Hi Sebastian,
> Import:
> Entity:
> 'entity' name=ValidID ('extends' aAlias=[Import]
> features+=Feature*
> is that right?
> stuff...
> Regards
> Goran
Re: Need some help [message #845849 is a reply to message #845803] Sun, 15 April 2012 09:30 Go to previous message
Hi Sebastian,
Thanks for your reply. For me the alias should just filter the amount of proposes when hit CTRL+Space,
so that the returned list is smaller. I will try it with the ImportedNamespaceAwareLocalScopeProvider.internalGetImportedNamespaceResolvers...Thanks.
Goran
Previous Topic:C-Based Editor (Xtext or CDT)?
Next Topic:ImportedNamespaceAwareLocalScopeProvider should check the path
Current Time: Sun Jul 20 20:39:25 EDT 2025
Powered by FUDForum. Page generated in 0.04656 seconds
