Home » Modeling » M2T (model-to-text transformation) » [Xpand] Dynamic position of generated text
[Xpand] Dynamic position of generated text [message #843658] Fri, 13 April 2012 04:46 Go to next message
Hi all,
Please take a look at my problem. Let's consider that we have 3 very simple templates in Xpand: class, variable and method.
«DEFINE class FOR X»
public class MyClass {
	«EXPAND variableDec»
	«EXPAND method»
«ENDDEFINE»
«DEFINE variable FOR X»
	int a = 0;
	int b = 0;
	int c = 0;
«ENDDEFINE»
«DEFINE method FOR X»
	public static String methodA() {
		«EXPAND variable»
«ENDDEFINE»
The output shall be:
	int a = 0;
	int b = 0;
	int c = 0;
	int a = 0;
	int b = 0;
	int c = 0;
So I wonder that do we have any way to make the text generated right at the place where EXPAND statement is placed. Specifically, if we update the template variable as:
int a = 0;
int b = 0;
int c = 0;
«ENDDEFINE»
And the calling of variable template in other templates:
	«EXPAND method»
«ENDDEFINE»
	«EXPAND variable»
«ENDDEFINE»
Then the expected text is generated as:
	int a = 0;
	int b = 0;
	int c = 0;
		int a = 0;
		int b = 0;
		int c = 0;
Hope that everyone could understand my situation. Thanks for any help!
Re: [Xpand] Dynamic position of generated text [message #843704 is a reply to message #843658] Fri, 13 April 2012 05:31 Go to previous messageGo to next message
Hi actually do not understand the problem can you make clear what is
NOT working
Re: [Xpand] Dynamic position of generated text [message #843730 is a reply to message #843704] Fri, 13 April 2012 06:07 Go to previous messageGo to next message
Hi Christian,
Of course it is always working. The point here is that I have a "common" template just like the above sample:
	int a = 0;
	int b = 0;
	int c = 0;
«ENDDEFINE»
This template shall be called from the others such as:
	«EXPAND variable»
«ENDDEFINE»
--> The output here is OK:
	int a = 0;
	int b = 0;
	int c = 0;
However, due to this template is common, so there is another usecase like this:
		«EXPAND variable»
«ENDDEFINE»
The code is actually generated as:
	int a = 0;
	int b = 0;
	int c = 0;
But expected as:
	int a = 0;
	int b = 0;
	int c = 0;
		int a = 0;
		int b = 0;
		int c = 0;
How do you think?
[Updated on: Fri, 13 April 2012 06:08] by Moderator
Re: [Xpand] Dynamic position of generated text [message #843749 is a reply to message #843730] Fri, 13 April 2012 06:27 Go to previous messageGo to next message
Still confusing what you mean. Are you talking about the indention?
Re: [Xpand] Dynamic position of generated text [message #843753 is a reply to message #843749] Fri, 13 April 2012 06:34 Go to previous messageGo to next message
Yes, that is it. About the indention.
How to dynamically change it?
Re: [Xpand] Dynamic position of generated text [message #843759 is a reply to message #843753] Fri, 13 April 2012 06:38 Go to previous messageGo to next message
Use a post processor/ beautifier
Re: [Xpand] Dynamic position of generated text [message #843763 is a reply to message #843759] Fri, 13 April 2012 06:46 Go to previous messageGo to next message
I already got a beautifer (to remove some empty lines, replace some characters...), but could you please be more precise on this usecase?
Re: [Xpand] Dynamic position of generated text [message #843767 is a reply to message #843763] Fri, 13 April 2012 06:49 Go to previous messageGo to next message
Did you read the docs?
Re: [Xpand] Dynamic position of generated text [message #843768 is a reply to message #843767] Fri, 13 April 2012 06:52 Go to previous message
Ah thanks Christian, I got an idea and try to implement in my current beautifer.
Previous Topic:Invoking Acceleo template from java app
Next Topic:[Acceleo] Class not found in invoke()
Current Time: Sun Jul 27 08:14:33 EDT 2025
Powered by FUDForum. Page generated in 0.04567 seconds
