Home » Modeling » TMF (Xtext) » reference(problem reference)
reference [message #842427] Thu, 12 April 2012 05:33 Go to next message
Salt guys let me know how I can refer Hadu my object (myclass) will place you one example:
model:
query = query;
query:
'SELECT' dbobject;
dbobject:
list = [jvmTypes:: jvmTypes list my items]
In pretica I wish that with ctrl-space appeared to me a list of my items to choose from.
Thanks in advance Rolling Eyes
Re: reference [message #842865 is a reply to message #842427] Thu, 12 April 2012 13:32 Go to previous messageGo to next message
i am not quite sure what you want to do. can you share a sample model?
~Christian
Re: reference [message #843664 is a reply to message #842865] Fri, 13 April 2012 04:52 Go to previous messageGo to next message
Hi Christian
The thing I need is that when I use ctrl-space my rule Name consists of a list of names (string) including an order choosing. The list must be external to the grammar seen that with my editor, I can connect to several db, so this list will be different every time. I give the idea with this example:
I connect to the db Gianluca:
Model:
query = query;
Query:
'SELECT' dbobject;
Dbobject:
list = [:: jvmTypes jvmTypes list my items]
in this case, when I'm going to use the editor
by ctrl-space will I display the list of db table
Gianluca then choosing a:
as {
Name
Age
Work
once you press enter on the job I will have "SELECT job"
I connect to the db Christian:
Model:
query = query;
Query:
'SELECT' dbobject;
Dbobject:
Chrisrian certainly with elements other than those of db
Gianluca including choosing a
as {
People
Employees
Salary
once you press enter on People I "SELECT People"
In other words I want the rule dbobject have to fill a container with shakes or objects outside the grammar.
Can I do this? or is there a method to return a list java? Reading the tutorial that I did not understand a lot ....
Thanks in advance.
Re: reference [message #843700 is a reply to message #843664] Fri, 13 April 2012 05:25 Go to previous messageGo to next message
And what does that have to do with jvmtypes? And do you want to have
real cross references or simply edit support?
Re: reference [message #843708 is a reply to message #843700] Fri, 13 April 2012 05:44 Go to previous messageGo to next message
you will excuse me, I know we say that instead of jvmTypes there is
list = [listTables]
list table should be a dynamic container in which to inject each time different squeezes that are no more than names tables forming part of a Db ..
I hope I was clear ......!!
I'm sorry again.
Re: reference [message #843717 is a reply to message #843708] Fri, 13 April 2012 05:47 Go to previous messageGo to next message
OK but do you really want to have a cross ref or just content assist?
Re: reference [message #843722 is a reply to message #843717] Fri, 13 April 2012 05:59 Go to previous message
Ok I will see the contents!
Previous Topic:Can I open a Xtext editor for a element tree contained in another model?
Next Topic:Re: Creating common interface
Current Time: Sun Jul 27 04:41:44 EDT 2025
Powered by FUDForum. Page generated in 0.03386 seconds
