Home » Eclipse Projects » Requirements Modeling Framework  » The import org.eclipse.rmf.reqif10 cannot be resolved
The import org.eclipse.rmf.reqif10 cannot be resolved [message #840031] Mon, 09 April 2012 11:30 Go to next message
after checking out the current develop branch, I'm getting the above error message several times, i.e. at a line containing
import org.eclipse.rmf.reqif10.ReqIF10Package;
I've made several hard resets to be sure of having the complete and correct branch, but with no success.
I'm lost...
Can you please tell me what I should do now?
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #840133 is a reply to message #840031] Mon, 09 April 2012 14:02 Go to previous messageGo to next message
Hello Kay,
My first guess is, that you are still using the old core, and failed to import the new core into your Eclipse workspace. While we did a lot of work on RMF, we are still not done with the cleanup.
To get things to work:
- Make sure that you import new projects from the repository into your workspace
- You need the following plugins from the core:
- org.eclipse.rmf.reqif10.model
- org.eclipse.rmf.serialization
- Also, the target platform definition moved to
org.eclipse.rmf.releng.target
- The product definition moved to
org.eclipse.rmf.releng.product
I think this should get you up and running for now. We plan on removing all the obsolete code soon.
Hope this helps,
- Michael
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #840538 is a reply to message #840133] Tue, 10 April 2012 03:56 Go to previous messageGo to next message
Hello Kay,
I made a mistake: You need
... instead of:
Also, I realized that there were still some 1.6 vs. 1.5 issues that I just checked in.
Best,
- Michael
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #842914 is a reply to message #840538] Thu, 12 April 2012 14:24 Go to previous messageGo to next message
Oops! My fault! I've had to import additional projects into my workspace...
Sorry for the noise and thanks again.
- Kay
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #842921 is a reply to message #840538] Thu, 12 April 2012 14:28 Go to previous messageGo to next message
Oops! My fault!
I've had to import the additional projects into my workspace...
- Kay
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #842934 is a reply to message #840538] Thu, 12 April 2012 14:24 Go to previous messageGo to next message
- Kay
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #842935 is a reply to message #840538] Thu, 12 April 2012 14:28 Go to previous message
Oops! My fault!
- Kay
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #842947 is a reply to message #840538] Thu, 12 April 2012 14:24 Go to previous message
- Kay
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #842948 is a reply to message #840538] Thu, 12 April 2012 14:28 Go to previous message
Oops! My fault!
- Kay
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #842963 is a reply to message #840538] Thu, 12 April 2012 14:24 Go to previous message
- Kay
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #842964 is a reply to message #840538] Thu, 12 April 2012 14:28 Go to previous message
Oops! My fault!
- Kay
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #842979 is a reply to message #840538] Thu, 12 April 2012 14:24 Go to previous message
- Kay
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #842980 is a reply to message #840538] Thu, 12 April 2012 14:28 Go to previous message
Oops! My fault!
- Kay
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #842999 is a reply to message #840538] Thu, 12 April 2012 14:24 Go to previous message
- Kay
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #843000 is a reply to message #840538] Thu, 12 April 2012 14:28 Go to previous message
Oops! My fault!
- Kay
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #843019 is a reply to message #840538] Thu, 12 April 2012 14:24 Go to previous message
- Kay
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #843020 is a reply to message #840538] Thu, 12 April 2012 14:28 Go to previous message
Oops! My fault!
- Kay
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #843043 is a reply to message #840538] Thu, 12 April 2012 14:24 Go to previous message
- Kay
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #843044 is a reply to message #840538] Thu, 12 April 2012 14:28 Go to previous message
Oops! My fault!
- Kay
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #843075 is a reply to message #840538] Thu, 12 April 2012 14:24 Go to previous message
- Kay
Re: The import org.eclipse.rmf.reqif10 cannot be resolved [message #843076 is a reply to message #840538] Thu, 12 April 2012 14:28 Go to previous message
Oops! My fault!
- Kay
Previous Topic:target and product in releng-projects
Next Topic:New ProR Integration Release Available (0.2.0)
Current Time: Thu Nov 06 07:52:20 EST 2025
Powered by FUDForum. Page generated in 0.06575 seconds
