Table inside a Grid (pagination problem) [message #840510] |
Tue, 10 April 2012 03:10  |
Hi all,
I've built a Grid with for example 20 x 15 cells, which exactly fits into a single page. Now I put a Table (or another Grid, doesn't matter) inside one Cell, which contains a lot of data.
When I run and render this design via API, I get the following result (see attachment), which is obviously wrong, because every two pages there is just a tiny piece of the Cell (therefore I painted it green, to show it's still the same Cell).
When I render the design via the BIRT Eclise Plugin instead, it shows the right solution in the "Preview"-Window and even when exporting it there to PDF.
Any suggestions? Am I missing some "CSS"-like Statements? I really don't know where the difference is.
Thanks for your help!
- Chris
Attachment: report.pdf
(Size: 6.29KB, Downloaded 356 times)
Re: Table inside a Grid (pagination problem) [message #840869 is a reply to message #840510] |
Tue, 10 April 2012 11:48   |
Chris
Can you post the design you used? What version of BIRT are you using?
Jason
On 4/10/2012 3:10 AM, Chris K wrote:
> Hi all,
> - Chris
FUDForum. Page generated in 1.03832 seconds
