Home » Archived » M2M (model-to-model transformation) » [ATL] Ecore metamodel EReference multiplicity -2
[ATL] Ecore metamodel EReference multiplicity -2 [message #84212] Tue, 10 June 2008 15:54 Go to next message
Originally posted by: amehmood.sophia.inria.fr
Hi All,
I have a simple problem. I have an Ecore metamodel with Upper Bound
multiplicity of an EReference as -2 (lower bound is 0). With this, i try
to map the ATL rules, But its not working.
But if I change the Upper Bound to -1 then it works!!! what to do? Is it
implemented in ATL or not? Is there any other way to do so?
Here is the code:
rule root {
from u : UML2!Model
to v : myML!DocumentRoot (component<-u.getCmpt(u)
rule component {
from u : UML2!Component
to v : myML!ComponentType(vendor<-'sophia.inria.fr',
library<-'myModel',
name<-u.name,
version<-'1.0')
waiting for the reply n thanks in advance,
-aamir-
Re: [ATL] Ecore metamodel EReference multiplicity -2 [message #84226 is a reply to message #84212] Tue, 10 June 2008 17:39 Go to previous messageGo to next message
--------------090607030707010804030105
Aamir,
Note that this corresponds to ETypedElement's
* A value indicating that there is an unspecified {@link
#getUpperBound upper bound}.
* @see #getUpperBound()
int UNSPECIFIED_MULTIPLICITY = -2;
Also note that isMany is computed by FeatureMapUtil.isMany because the
multiplicity depends on the multiplicity of the target feature.
Aamir wrote:
> Hi All,
> try to map the ATL rules, But its not working.
> it implemented in ATL or not? Is there any other way to do so?
> Here is the code:
> rule root {
> from u : UML2!Model
> rule component {
> library<-'myModel',
> name<-u.name,
> version<-'1.0')
> -aamir-
<html>
<head>
http-equiv="Content-Type">
</head>
Aamir,<br>
<br>
Note that this corresponds to ETypedElement's<br>
<blockquote>
Re: [ATL] Ecore metamodel EReference multiplicity -2 [message #84447 is a reply to message #84226] Thu, 12 June 2008 16:53 Go to previous message
As far as I have experimented, the multiplicity value of -2 causes a
strange effect in ATL that we can only create one instance/object for
that relation and this object can be user
created(myML!instancename...etc) or it can be a matching. but for more
than one it doesn't work.
so with this multiplicity value, we can have one instance for each type.
Lets see if someone opposes my observations...
thankx,
-aamir-
Ed Merks wrote:
> Aamir,
> Aamir wrote:
>> Hi All,
>> Here is the code:
>> rule root {
>> from u : UML2!Model
>> rule component {
>> library<-'myModel',
>> name<-u.name,
>> version<-'1.0')
>> -aamir-
Previous Topic:[ATL] Help with 'The side effect example'
Next Topic:UML Softwares
Current Time: Thu Jul 24 21:26:35 EDT 2025
Powered by FUDForum. Page generated in 0.08144 seconds
