Home » Eclipse Projects » Remote Application Platform (RAP) » theme variants not working on Text and Composite
theme variants not working on Text and Composite [message #84080] Tue, 22 April 2008 14:15 Go to next message
We are trying to use theming variants to change the background color of a ViewPart.
Theming is working, because when we change the value of the global (widget.background) background color in the
..properties file, we can see the result.
But if we set theming variant as
public void createPartControl(Composite parent){
// NOT WORKING
parent.setData(WidgetUtil.CUSTOM_VARIANT, "myvariant");
// NOT WORKING EITHER
Text text = new Text(parent, SWT.NONE);
text.setData(WidgetUtil.CUSTOM_VARIANT, "myvariant");
and we define, in .properties file
myvariant/widget.background: 227, 76, 21
myvariant/list.background: red
the result is of the same color as the default/global values.
using RAP-1.1.0-M3
Any help appreciated.
Patrick
Re: theme variants not working on Text and Composite [message #84169 is a reply to message #84080] Wed, 23 April 2008 03:20 Go to previous messageGo to next message
Originally posted by: rsternberg.innoopract.com
Hi Patrick,
it's right that in M3 theme variants do not work for some
widgets/theming keys. Composite is one of them, which is already fixed
in CVS HEAD and I'll also fix the Text bug right away. I'm sorry for the
inconvenience. We're currently working on the theming subsystem to make
it more flexible and I think it will stabilize in the next weeks.
Ralf
> a ViewPart.
> (widget.background) background color in the .properties file, we can see
> the result.
> // NOT WORKING
> using RAP-1.1.0-M3
> Patrick
Re: theme variants not working on Text and Composite [message #84350 is a reply to message #84169] Wed, 23 April 2008 17:16 Go to previous messageGo to next message
Hi Ralf,
Super!
I'll see if I can wrap my head around creating a target from CVS HEAD stuff.
Thanks for the good work!
Patrick
> Hi Patrick,
> Best regards,
> Ralf
Re: theme variants not working on Text and Composite [message #84364 is a reply to message #84350] Wed, 23 April 2008 17:21 Go to previous message
If you want to work the the latest and greatest stuff from CVS HEAD you
can just import them with the provided Team project set (See
eclipse.org/rap -> CVS). This allows you to compile the stuff against
the newer plugins.
Greets
Benny
> Hi Ralf,
> Super!
> stuff.
> Patrick
>> Hi Patrick,
>> the inconvenience. We're currently working on the theming subsystem to
>> make it more flexible and I think it will stabilize in the next weeks.
>> Best regards,
>> Ralf
Previous Topic:Wrong UI Thread
Next Topic:DateChooser
Current Time: Sun Aug 31 12:59:42 EDT 2025
Powered by FUDForum. Page generated in 0.05225 seconds
