Home » Language IDEs » Java Development Tools (JDT) » Reuse Java components (parser, auto completion, ...) for composite language
Reuse Java components (parser, auto completion, ...) for composite language [message #841499] Wed, 11 April 2012 07:49 Go to next message
I am developing a language which partially uses Java and some other languages. Now an important aspect is the tooling for the language. Is it possible to reuse some of the components already implemented in eclipse for java? That means, consider for example the following language:
public class MyClass {
   public void method(String table, String col, int val) {
      sql {
          INSERT INTO table (col) values (val);
The example shows a Java class with a method. This all is plain Java. Inside the method is a sql-Statement. I now liked to reuse all (or most of) the tooling support that Eclipse usually offers for Java. That means for example, if I am not in the context of sql { ... } auto completion etc. should still be supported.
Is this possible? If yes, what next steps should I do (which docs to read?)
Thanks in advance
P
Re: Reuse Java components (parser, auto completion, ...) for composite language [message #841561 is a reply to message #841499] Wed, 11 April 2012 09:23 Go to previous messageGo to next message
There has been some effort in to make JDT extensible, but is not complete. However, some are able to get the hold of it. Look at http://wiki.eclipse.org/Extending_JDT_For_Java_Like_Languages and the links there.
Re: Reuse Java components (parser, auto completion, ...) for composite language [message #841567 is a reply to message #841499] Wed, 11 April 2012 09:27 Go to previous messageGo to next message
XBase provides the foundation to embed java into your custom language.
I'd suggest you take a look at Xtext and Xbase (respectively their Xtend
language which is implemented on top of it - it even integrates into the
JDT-Debug stuff, ....)
Tom
Am 11.04.12 13:49, schrieb P N:
> Hello,
> sql {
> Thanks in advance
> P
Re: Reuse Java components (parser, auto completion, ...) for composite language [message #841674 is a reply to message #841567] Wed, 11 April 2012 12:08 Go to previous messageGo to next message
Thanks a lot, Satyam and Tom.
Re: Reuse Java components (parser, auto completion, ...) for composite language [message #843105 is a reply to message #841674] Thu, 12 April 2012 15:15 Go to previous message
In case Java is really the host language for most of your code, and only snippets of another language are embedded, you may want to re-use the JDT as-is, rather than through any indirections. In this case and if you are ready to get your hands dirty, you might find some inspiration in two of my blog posts:
- http://blog.objectteams.org/2010/02/ide-for-your-own-language-embedded-in-java-part-1/
- http://blog.objectteams.org/2010/02/ide-for-your-own-language-embedded-in-java-part-2/
cheers,
Stephan
Previous Topic:How to org.eclipse.core.resources.IResource -> org.eclipse.jdt.core.ICompilationUnit
Next Topic:Import jsf 2.0 netbeans project in to Eclipse IDE Helios
Current Time: Wed Jul 23 17:06:14 EDT 2025
Powered by FUDForum. Page generated in 0.03583 seconds
