Home » Eclipse Projects » Plugin Development Environment (PDE) » Missing executable from headless build
Missing executable from headless build [message #631900] Sun, 10 October 2010 04:24 Go to next message
I'm experimenting with the headless build of an RCP product and I'm a
bit lost on an issue with the executable generation. The export uses a
custom allElements.xml to set the top level feature and archive names,
with that customization pde doesn't generate the executable, while if I
remove the allElements.xml file and let pde do its defaults, then the
executable is created and packaged correctly.
I found that the issue seems related to a missing delta pack, however
delta pack is present (the product exports to multiple platforms, so I
am sure that it is present).
From the build output I see these lines:
[java] customAssembly:
[java] [eclipse.brand] Warning: Could not find executable to brand.
It seems a bug to me, or I'm missing something ?
Marco.
Re: Missing executable from headless build [message #632241 is a reply to message #631900] Tue, 12 October 2010 04:42 Go to previous messageGo to next message
Seems that the features need to include org.eclipse.equinox.executable
plugin for the executable to be generated. Can someone confirm that this
is the expected behaviour ?
Marco.
Re: Missing executable from headless build [message #840728 is a reply to message #632241] Tue, 10 April 2012 08:54 Go to previous messageGo to next message
Hello Marco,
I ran into the exact same problem.
In two year time, did you found a solution to it ?
Charles
Re: Missing executable from headless build [message #841408 is a reply to message #840728] Wed, 11 April 2012 04:57 Go to previous messageGo to next message
I don't think, none of my product build scripts are using the custom
allElements.xml script and the headless build works fine. I don't even
remember what I was trying to do at that time.
Maybe if you write what you are trying to do I (or someone else) may
suggest a solution.
It took me a while to realize that you were answering to one of my
posts, please quote some bits of the original message the next time.
Marco.
Re: Missing executable from headless build [message #841422 is a reply to message #841408] Wed, 11 April 2012 05:26 Go to previous messageGo to next message
Thank you for your quick answer.
I have the same output when I'm building my RCP application:
And I though that it was the root cause of my problem but it turned out that it was not.
Sorry about that. Very Happy
I guess that this warning is not worth the concern.
Charles Bonneau
[Updated on: Wed, 11 April 2012 05:26] by Moderator
Re: Missing executable from headless build [message #1748321 is a reply to message #632241] Tue, 22 November 2016 04:22 Go to previous message
Is it true ? I am also facing this issue.
What was the solution ?
I am building RCP project and exe is not created after ant headless build.
Previous Topic:Custom warnings
Next Topic:Parallel testing of Eclipse PDE Unit Tests
Current Time: Sat Jul 26 15:24:08 EDT 2025
Powered by FUDForum. Page generated in 0.27716 seconds
