Home » Archived » Jubula » Unable to Export a Test Project(After the Refreshing Project dialog closes, no XML files are created)
Unable to Export a Test Project [message #833026] Fri, 30 March 2012 17:55 Go to next message
I've been through the forum and don't seem to see anyone else having this issues. So it seems there must be something I'm overlooking when performing an export. Upon completion of the refresh, no XML files are created and the console shows no events.
The closest forum thread I found is #735972, but it wasn't followed up and doesn't match our scenario either. -.org/forums/index.php/mv/msg/245808/735972/#msg_735972
Have tried "Is Reusable" on/off, and "Is Proteched" on/off.
Used Test->Export (renders no files, no error messages, but does refresh the database)
Used Test->Export All (renders only the four "unbound" modules (5.2))
Again, I suspect there's something I've missed in the documentation. If someone could point me down the right trail, they would have my appreciation.
Thank you in advance.
~Robert
Re: Unable to Export a Test Project [message #841325 is a reply to message #833026] Wed, 11 April 2012 02:54 Go to previous message
Hi Robert,
Is there anything in the log file when this happens? I remember occasionally having a problem with exporting that is described here. If it looks similar, feel free to comment on the bug report - more information on reproducing it would be very useful!
Otherwise, my suggestions would be to perhaps check permissions, disk space etc if the log doesn't provide any useful information.
Alex
Previous Topic:Executing tests with testexec - no scheme?
Next Topic:String manipulation on local variables
Current Time: Thu Jul 24 20:36:29 EDT 2025
Powered by FUDForum. Page generated in 0.04602 seconds
