Re: Need some help [message #842547 is a reply to message #841723] |
Thu, 12 April 2012 07:54   |
Well...2 out of 3. My alias import works fine and the Java-Objectlookup also. Here is how I've done it.
Import
One important thing is how the grammar is defined. My alias-command was definied like:
Alias:
'alias' name=ID packageName=STRING
I changed it to
Alias:
'alias' name=ID importedNamespace=QualifiedNameWithWildCard
The most important thing was changing the name from packageName to importedNamespace. Now I can cross-reference to my Java-Objects.
Propose only the classes within the package
This was more tricky (at least for me). First I tried by scoping, but I did not get further as I didn't find how and where to start. But then I used my ProposalProvider in the following way:
public void completeCreate_JavaType(EObject model, Assignment assignment, ContentAssistContext context, ICompletionProposalAcceptor acceptor) {
super.lookupCrossReference(((CrossReference) assignment.getTerminal()), context, acceptor, new CreateFilter((Create) model));
The CreateFilter is an inner-class:
class CreateFilter implements Predicate<IEObjectDescription> {
private QualifiedName packageQName;
public CreateFilter(Create createModel) {
String[] segments = createModel.getNamespace().getImportedNamespace().split("\\.");
this.packageQName = QualifiedName.create(segments).skipLast(1);
public boolean apply(IEObjectDescription input) {
QualifiedName name = input.getQualifiedName();
// skipLast to remove the wildcard
return name.startsWith(packageQName);
This works for me. If I hit CTRL+SPACE in my create-command I only got the classes from the corresponding package proposed. For all newbies out there: I found this solution by a step-by-step debugging and reading the source code. It's hard but I succeeded. I don't know if there is a nicer way, but for me it works.
Now next thing is to get the method-names proposed.
Goran
[Updated on: Thu, 12 April 2012 07:56] by Moderator
Re: Need some help [message #844047 is a reply to message #843946] |
Fri, 13 April 2012 12:25   |
Goran,
you could implement the IScope interface manually and delegate to the
super scope (which is populated lazily if you don't call
getAllElements). You own scope would basically look like this:
MyScope implements IScope {
MyScope(IScope delegate) { this.delegate = delegate }
public IEObjectDescription getSingleElement(QualifiedName name) {
if (name matches import criteria) {
return delegate.getSingleElement(name);
return IScope.NULLSCOPE;
public Iterable<IEObjectDescription> getElements(final QualifiedName
name) {
return delegate.getElements(name);
.. similar for the other methods ..
Sebastian
Am 13.04.12 16:27, schrieb Goran M.:
> well, I am not happy with this solution as the performance is bad. I
> tried to solve it with a ScopeProvider. Here is the code for filtering
> the classes depending on the package:
> Create create = (Create) context;
> IScope scope = super.getScope(context, reference);
> String[] segments =
> create.getImports().getImportedNamespace().split("\\.");
> QualifiedName packageQName = QualifiedName.create(segments).skipLast(1);
> Iterable<IEObjectDescription> it = scope.getAllElements();
> ArrayList<IEObjectDescription> list = new ArrayList<IEObjectDescription>();
> for (IEObjectDescription descr : it) {
> if (descr.getQualifiedName().startsWith(packageQName)) {
> list.add(descr);
> return new SimpleScope(list, false);
> Now, while debugging, I can see that the super.getScope()-call returns a
> scope
> where all classes are already fetched.
> But the only way to get to the classes is by calling getAllAlements()
> which needs
> a lot of time. Is there a faster way to get the classes?
> Regards
> Goran
Re: Need some help [message #844051 is a reply to message #843946] |
Goran,
name) {
Sebastian
> String[] segments =
> list.add(descr);
> scope
> which needs
> Regards
> Goran
Re: Need some help [message #845849 is a reply to message #845803] |
Sun, 15 April 2012 09:30  |
Hi Sebastian,
Thanks for your reply. For me the alias should just filter the amount of proposes when hit CTRL+Space,
so that the returned list is smaller. I will try it with the ImportedNamespaceAwareLocalScopeProvider.internalGetImportedNamespaceResolvers...Thanks.
Goran
FUDForum. Page generated in 0.10365 seconds
