Home » Language IDEs » PHP Development Tools (PDT) » Break points are not breaking
Break points are not breaking [message #84120] Thu, 20 November 2008 12:28 Go to next message
Originally posted by: mansour.own.net
I have been trying to install Zend debugger with PDT for few days, and
No where to go but to ask someone here. I am running gentoo 64 with
eclipse 3.4. However, I still can not get the break points to stop when
debugging php files. I don't know what other information is required,
however, here's my /etc/php/apache2-php5/ext-active/zend.ini
[Zend]
zend_extension_ts=/usr/lib64/php5/lib/php/extensions/no-debu g-zts-20060613/ZendDebugger.so
zend_debugger.allow_hosts=127.0.0.1, 192.168.1.100
zend_debugger.expose_remotely=always
I have setup apache2 to server from USERDIR. I can the pages when I
debug from eclipse, but no break points are stopping.
In eclipse> prefrences > PHP > zend debugger settings:
debug port: 10000
client/host IP: 192.168.1.100,127.0.0.1
PHP > php executables:
One executable /usr/lib64/php5/bin/php
php inifile: /etc/php/apache2-php5/php.ini
php debugger: Zend Debugger
PHP > PHP servers:
url that points to the document root of this server:
http://localhost/~mansour
Path mapping- on the server: /
Path mapping - in workspace /my-php-project
If there's any missing info please ask.
Thank you.
Re: Break points are not breaking [message #84134 is a reply to message #84120] Thu, 20 November 2008 14:49 Go to previous messageGo to next message
Originally posted by: michael.zend.com
"Mansour" <mansour@own.net> wrote in message
news:gg46pj$444$1@build.eclipse.org...
<skipped>
> PHP > PHP servers:
This must be a full path on the server, not an URL path. Where is your
document root located?
If it's /var/www, for example, the path should be /var/www/your_project.
Re: Break points are not breaking [message #84148 is a reply to message #84134] Thu, 20 November 2008 15:21 Go to previous messageGo to next message
> <skipped>
>> PHP > PHP servers:
What do u mean ? I have my project in /home/mansour/public_html as I
don't have write access to /var/www/. Do I need to modify this access ?
Further more, I found that the command php -m is not showing Zend
debugger installed. I have posted already to the zend forum and waiting
for response. I will see how things will go, and then will move from
there, as this has to be fixed before I continue to set it up with eclipse.
Re: Break points are not breaking [message #84162 is a reply to message #84134] Thu, 20 November 2008 15:23 Go to previous messageGo to next message
> <skipped>
>> PHP > PHP servers:
Re: Break points are not breaking [message #84178 is a reply to message #84134] Thu, 20 November 2008 15:24 Go to previous messageGo to next message
> <skipped>
>> PHP > PHP servers:
Re: Break points are not breaking [message #84607 is a reply to message #84178] Sun, 23 November 2008 13:20 Go to previous messageGo to next message
Originally posted by: mansour.alakeel.gmail.com
Ok, I have reinstalled xdebug, and gave up on Zend.
I am using gentoo 64. Now, with xdebug things seems to be better as I
can debug a script but not a web page. Here's my configuration. Apache
supports user directory, so I have access to /home/mansour/public_html.
In fact I created a workspace for eclipse in /home/mansour/public_html.
So basically, this is my document root. I have created a test project,
called Project. And for the PDT:
xdebug is the default debugger at port 9000, Under the executable
section, I have only one executable:
path: /usr/lib64/php5/bin/php
debugger: xdebug
URL pointing to doc root for this server: http://localhost/~mansour
Path mapping:
/home/mansour/public_html --> /
/home/mansour/public_html/Project --> /Project (in WorkSpace)
When I click "debug as web page" on the index.php which is in the root
directory of the project, It shows
"http://localhost/~mansour/Project/index.php" which is the correct URL.
However, launching sits there showing that it's at 19% for ever, and
waiting for xDebug session.
Further more I can not find any logs or messages, which makes the issue
little bit frustrating.
I will appreciate any help to get this resolved.
>> <skipped>
>>> PHP > PHP servers:
Re: Break points are not breaking [message #84610 is a reply to message #84607] Sun, 23 November 2008 20:08 Go to previous messageGo to next message
Probably because you have it set to break at first line. Check to see if
you can step through the debugger.
> debugger: xdebug
> Path mapping:
Re: Break points are not breaking [message #84618 is a reply to message #84610] Sun, 23 November 2008 20:32 Go to previous messageGo to next message
I unchecked the "Break at first line" option, and tried, but still no
progress.
>> debugger: xdebug
>> Path mapping:
>> URL. However, launching sits there showing that it's at 19% for ever,
>> and waiting for xDebug session.
>> issue little bit frustrating.
Re: Break points are not breaking [message #84624 is a reply to message #84607] Sun, 23 November 2008 22:22 Go to previous messageGo to next message
Mansour,
When debugging I have seen this occur when I have not setup my "PHP Web
Page" server settings properly within Eclipse Debug Configuration. The
19% is when Eclipse has done everything it can to start a debug session
and is waiting to hear back from Xdebug. Eclipse starts the session up
but won't actually do anything more until a filepath / line number
matches with what the path mappings have for the page settings.
From your notes I don't see you ever going in and checking the PHP
server configuration within the Debug Configuration. If you click on the
down arrow beside the debug icon you will see a option to open up the
Debug Configurations. Within there under "PHP Web Page" check what
settings are for your site. Main thing to check is the PHP Server
setting within the server tab. If it is set to "Default PHP Web Server"
then that is the one for localhost. Use the configure button and make
sure the path mapping settings are correct. They have to be absolute
paths so the path on server should have something like
"home/mansour/public_html/Project" and the path in workspace should just
be a selection of that project.
Once that is all setup then you should be able to debug your page. Have
it so that it IS breaking at the first line so that you are able to make
sure that it is starting a debug session. Once you have that confirmed
then you can remove the "break at first line" and setup other breakpoints.
Shawn Clark
> debugger: xdebug
> Path mapping:
>>> <skipped>
>>>> PHP > PHP servers:
>>> your document root located?
>> eclipse.
Re: Break points are not breaking [message #84654 is a reply to message #84624] Mon, 24 November 2008 12:25 Go to previous messageGo to next message
Shawn,Thank you.
I have tried everything, and nothing seems to be working for me. I
understand that the mapping has to be absolute, and that's what I have.
Here's screenshots for my config:
http://img152.imageshack.us/img152/9427/screenshot1en0.png
http://img219.imageshack.us/img219/1281/screenshot2bj5.png
Do you have any advice ?
Shawn Clark wrote:
> Mansour,
> Shawn Clark
Re: Break points are not breaking [message #84665 is a reply to message #84654] Mon, 24 November 2008 12:50 Go to previous messageGo to next message
Given that eclipse is showing 19% implies to me that xdebug cannot contact your PDT setup or xdebug
doesn't load or attempt to initiate a session.
so it would be worth doing the following
1. write a little script that runs phpinfo() and invoke it from your browser. That will tell you if
xdebug is loaded on your server and what the settings are (suggest you post it here too along with
your php.ini entries for xdebug).
2. generate an xdebug log by adding an entry
xdebug.remote_log=c:\xdebug.log
(replace c:\xdebug.log with something appropriate for your system and operation system).
and post the log.
3. check the ports match 9000 on your server with 9000 on your PDT system and ensure that no
firewall is blocking that port.
I think you can probably delete the path mapping entry you have specified, if necessary in your case
PDT should work it out automatically.
Dave Kelsey
Mansour wrote:
> Shawn,Thank you.
> Shawn Clark wrote:
>> Mansour,
>> Web Page" server settings properly within Eclipse Debug Configuration.
>> The 19% is when Eclipse has done everything it can to start a debug
>> session and is waiting to hear back from Xdebug. Eclipse starts the
>> session up but won't actually do anything more until a filepath / line
>> number matches with what the path mappings have for the page settings.
>> the down arrow beside the debug icon you will see a option to open up
>> the Debug Configurations. Within there under "PHP Web Page" check what
>> Server" then that is the one for localhost. Use the configure button
>> and make sure the path mapping settings are correct. They have to be
>> absolute paths so the path on server should have something like
>> just be a selection of that project.
>> Have it so that it IS breaking at the first line so that you are able
>> to make sure that it is starting a debug session. Once you have that
>> confirmed then you can remove the "break at first line" and setup
>> other breakpoints.
>> Shawn Clark
Re: Break points are not breaking [message #84707 is a reply to message #84665] Mon, 24 November 2008 14:28 Go to previous message
It''s working now. Here's the modification I did to xdebug.ini:
mars ext # diff xdebug.ini xdebug.ini.defualt
2c2
< xdebug.auto_trace="1"
> xdebug.auto_trace="0"
29c29
< xdebug.profiler_enable="1"
> xdebug.profiler_enable="0"
33c33
< xdebug.profiler_append="1"
> xdebug.profiler_append="0"
35c35
< xdebug.remote_enable="true"
> xdebug.remote_enable="0"
41c41
< xdebug.remote_log="/var/log/apache2/xdebug.log"
> xdebug.remote_log=""
I don't know exactly which option got it to work, however I can debug
now web pages. The log file is not showing anything, but that's fine.
The file xdebug.ini.default is a back up copy of the default values when
you install Xdebug through gentoo portage.
I removed the server mapping as well like Dave suggested.
Thank you all. I really appreciate everyones help.
> contact your PDT setup or xdebug doesn't load or attempt to initiate a
> session.
> browser. That will tell you if xdebug is loaded on your server and what
> the settings are (suggest you post it here too along with your php.ini
> operation system).
> and post the log.
> system and ensure that no firewall is blocking that port.
> specified, if necessary in your case PDT should work it out automatically.
> Dave Kelsey
> Mansour wrote:
>> Shawn,Thank you.
>> Shawn Clark wrote:
>>> Mansour,
>>> Configuration. The 19% is when Eclipse has done everything it can to
>>> start a debug session and is waiting to hear back from Xdebug.
>>> Eclipse starts the session up but won't actually do anything more
>>> until a filepath / line number matches with what the path mappings
>>> what settings are for your site. Main thing to check is the PHP
>>> Server setting within the server tab. If it is set to "Default PHP
>>> Web Server" then that is the one for localhost. Use the configure
>>> button and make sure the path mapping settings are correct. They have
>>> to be absolute paths so the path on server should have something like
>>> other breakpoints.
>>> Shawn Clark
Previous Topic:Templates not working on PDT 2.0
Next Topic:Why there's no all-in-one package for M2
Current Time: Tue Sep 16 00:31:02 EDT 2025
Powered by FUDForum. Page generated in 0.27681 seconds
