Home » Eclipse Projects » Rich Client Platform (RCP) » Error when closing program cause of running job
Error when closing program cause of running job [message #840860] Tue, 10 April 2012 11:40 Go to next message
i have an eclipse rcp app that does some periodically (every 5 seconds) work in a child thread. After the work is done the thread executes a method to update the Status Line of the app to inidicate that the work is finished.
It looks like this:
	protected void updateStatusBar()
		 Display.getDefault().asyncExec(new Runnable() {
             public void run() {
                 PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().findView(MainView.ID).
                 getViewSite().getActionBars().getStatusLineManager().setMessage("work finished");
It runs fine. The problem i have is when i close my app i get a Null Pointer Exception with this error from time to time:
Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.progress.TaskBarProgressManager$2
Seems the program is deconstructing itself while the async job is running. So is there a way to get / wait for the running ui jobs, so that i can make sure the jobs are finsihed before the app is closed? Or a way to cancel them before the app "destroys" itself?
[Updated on: Tue, 10 April 2012 11:41] by Moderator
Re: Error when closing program cause of running job [message #841558 is a reply to message #840860] Wed, 11 April 2012 09:16 Go to previous message
Hi AmFreak,
Are you using threads or jobs? when using threads lookin
thread.setdaemon(true).
When using jobs: do not to loop the job every five seconds but submit a new
job after the first job has finished with a delay of five seconds. The job
should then only be submitted if the platform is not running
(platform.isworkbenchrunning() / iworkbench.isclosing())
Hope this helps,
Wim
> It looks like this:
> @Override
> public void run() {
finished");
> Quote:
> Seems the program is deconstruct itself while the async job is running. So
Previous Topic:Prompt user for an application to open a file with?
Next Topic:Output text in default editor
Current Time: Sun Jul 27 03:30:03 EDT 2025
Powered by FUDForum. Page generated in 0.03622 seconds
