Home » Language IDEs » ServerTools (WTP) » Problem deploying web service to Tomcat 5.5
Problem deploying web service to Tomcat 5.5 [message #84045] Wed, 16 March 2005 05:13 Go to next message
Originally posted by: poulsenj.worldonline.dk
After successfully running the *** tutorial, I'm now trying to run the
'Bottom Up Web Services Tutorial'. The J2EE Web Project is created having
a Target Server Apache Tomcat 5.5 (which is the only server listed under
Preferences/Servers/Runtime)
When generating the Web Service and the wizard prompts for Service
Deployment Configuration, it defaults to Tomcat v5.0 Server (where does
this entry come from?). I press the 'Edit...' button and select Existing
Servers/Tomcat v5.5 Server@localhost. The wizard screen updates correctly,
but in the .log file I get the following stack trace (and nothing is
generated/deployed even if I press the Finish button)
!ENTRY org.eclipse.ui 4 4 2005-03-16 11:06:39.938
!MESSAGE Unhandled event loop exception
!ENTRY org.eclipse.ui 4 0 2005-03-16 11:06:39.948
!MESSAGE java.lang.NullPointerException
!STACK 0
at
org.eclipse.jst.ws.internal.consumption.ui.widgets.runtime.R untimeServerSelectionWidget.getStatus(RuntimeServerSelection Widget.java:228)
at
org.eclipse.jst.ws.internal.creation.ui.widgets.runtime.Serv erRuntimeSelectionWidget.getStatus(ServerRuntimeSelectionWid get.java:219)
at
org.eclipse.wst.command.internal.env.ui.widgets.SimpleWizard Page.validatePageToStatus(SimpleWizardPage.java:67)
at
org.eclipse.wst.command.internal.env.ui.widgets.SimpleWizard Page$StatusListener.handleEvent(SimpleWizardPage.java:137)
at
org.eclipse.jst.ws.internal.consumption.ui.widgets.runtime.R untimeServerSelectionWidget.handleEditButton(RuntimeServerSe lectionWidget.java:167)
at
org.eclipse.jst.ws.internal.consumption.ui.widgets.runtime.R untimeServerSelectionWidget$1.widgetSelected(RuntimeServerSe lectionWidget.java:94)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2908)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2541)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:718 )
at org.eclipse.jface.window.Window.open(Window.java:696)
at
org.eclipse.wst.command.internal.env.ui.widgets.popup.Dynami cPopupWizard.run(DynamicPopupWizard.java:123)
at
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:244)
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:557)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:507)
at
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:421)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1612)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1578)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:293)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:333)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:150)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:268 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:260)
at org.eclipse.core.launcher.Main.run(Main.java:887)
at org.eclipse.core.launcher.Main.main(Main.java:871)
Re: Problem deploying web service to Tomcat 5.5 [message #84171 is a reply to message #84045] Wed, 16 March 2005 08:49 Go to previous messageGo to next message
<snip>
Johannes,
Any chance you are going thru a Proxy server (probably at work). I was
getting these same errors when I was developing stuff at work as I had a
Proxy Server at work. Things worked fine at home as there was no Proxy
Server...
Proxy Server setting are located under Window > Preferences > Internet >
Proxy Settings...
hth,
adym
Re: Problem deploying web service to Tomcat 5.5 [message #84322 is a reply to message #84171] Wed, 16 March 2005 11:22 Go to previous messageGo to next message
I get the same error described in this posting (see eclipse.webtools news
entry posted
on 3/14/05) when trying to select a server other than Tomcat v5.0 from under
the edit
button of the Service Deployment Configuration page.
At least in my case there is no proxy server configured and all of my
testing is being done
on "localhost".
Gary
"adym" <alincoln@edgewater.com> wrote in message
news:d19dhd$l0p$1@www.eclipse.org...
having
correctly,
> <snip>
> Johannes,
> Server...
> Proxy Settings...
> hth,
> adym
Re: Problem deploying web service to Tomcat 5.5 [message #84426 is a reply to message #84322] Wed, 16 March 2005 15:09 Go to previous messageGo to next message
Hi Gary, Johannes,
I opened a Bugzilla for this issue.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=88238
Feel free to add comments or track this issue here. In the future, you
may open bugs by going to http://bugs.eclipse.org/bugs . You'll have to
register for an account, but its free! The Web service components are
jst.ws and wst.ws. Thanks.
Seng
> entry posted
> the edit
> on "localhost".
> Gary
> having
> correctly,
>><snip>
>>Johannes,
>>Server...
>>Proxy Settings...
>>hth,
>>adym
Re: Problem deploying web service to Tomcat 5.5 [message #86800 is a reply to message #84426] Thu, 24 March 2005 06:31 Go to previous messageGo to next message
is there any solution to this problem, or does the eclipse WTP only support
Tomcat 4.1?
thx
"Seng Phung-Lu" <sengpl@ca.ibm.com> schrieb im Newsbeitrag
news:d1a3qn$fvo$1@www.eclipse.org...
> Hi Gary, Johannes,
> Seng
>> news
>> entry posted
>> under
>> the edit
>> on "localhost".
>> Gary
>> having
>> correctly,
>>><snip>
>>>Johannes,
>>>Server...
>>>Proxy Settings...
>>>hth,
>>>adym
Re: Problem deploying web service to Tomcat 5.5 [message #86828 is a reply to message #86800] Thu, 24 March 2005 11:03 Go to previous message
I've tried Web services with Tomat 4.0, 4.1, 5.0, and Tomcat 3.2 is also
supported. Problem is Tomcat 5.5 requires JRE 5.0 by default, which
hasn't been tested with Web services.
Note: The initial fix may be to just tolerate the server selection for
Tomcat 5.x.
I hope that helps.
-seng
> Tomcat 4.1?
> thx
>>Hi Gary, Johannes,
>>Seng
>>>news
>>>entry posted
>>>under
>>>the edit
>>>on "localhost".
>>>Gary
>>>having
>>>correctly,
>>>><snip>
>>>>Johannes,
>>>>Server...
>>>>Proxy Settings...
>>>>hth,
>>>>adym
Previous Topic:debug
Next Topic:Potential Bug
Current Time: Tue Jul 22 00:56:02 EDT 2025
Powered by FUDForum. Page generated in 0.03310 seconds
