Home » Eclipse Projects » Remote Application Platform (RAP) » rap 1m3 - problem after cleaning browser internals
rap 1m3 - problem after cleaning browser internals [message #83947] Tue, 22 April 2008 07:11 Go to next message
Originally posted by: dpryadkin.rocketsoftware.com
Hi there
Accidentally I've cleaned all of the browser internal files (cookies,
sessions, etc). And got strange behavior as a result. The application
shows itself and then immediately falls with exceptions in rwt lifecycle.
I've tried to trace these down and found out that UIThread#switchThread
throws its exception. I could not go any further as it is a property of
servlets.
Then I scratched my head and tried the same on rap.demo. Got this
behavior too.
I've managed to get things back by trying different browsers and reboots.
Re: rap 1m3 - problem after cleaning browser internals [message #83962 is a reply to message #83947] Tue, 22 April 2008 07:50 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
that sounds strange:( Could you post the Exception along with its
strack trace.
Rüdiger
Dmitry wrote:
> Hi there
> servlets.
> behavior too.
Re: rap 1m3 - problem after cleaning browser internals [message #83977 is a reply to message #83962] Tue, 22 April 2008 08:28 Go to previous messageGo to next message
--------------020604040603000800080105
> that sounds strange:( Could you post the Exception along with its strack
> trace.
Sure that's no problem.
I'm willing to pass the following steps:
1. I've made a workspace from scratch, imported rap.demo into it.
2. Opera 9.27 says this, after the application got shown in a little time:
"The server session timed out.
Please click here to restart the session."
The exception trace is in the attachment (yes it's so huge).
3. Internet Explorer 7 works right, after I re-run jetty and close Opera.
4. Firefox 2.0.0.13 behaves like Opera, after I re-run jetty and close IE7.
I shall say that every browser was ok until I managed to clear their
settings.
5. Run IE7 again, clear its settings. Re-run jetty. Now IE7 says the
same as Opera did. And at the moment none of the mentioned browsers do
actually work. Then run Firefox. No luck again.
6. Close eclipse. Wait for a while. Run IE7 - works! Run firefox -
doesn't work.
(that's enough)
Reboot doesn't always help. Probably I broke the platform itself. Or
maybe eclipse/jetty. Don't know. Didn't changed anything there.
Dmitry Pryadkin
Content-Type: application/x-zip-compressed;
name="trace.zip"
Content-Disposition: inline;
filename="trace.zip"
UEsDBBQAAAAIAJ2QljhCgKH1tAgAAJJuAAAJACQAdHJhY2UudHh0CgAgAAAA AAABABgAk1v2
FHGkyAGTW/YUcaTIAZNb9hRxpMgB7Vzfj+I4En6+keZ/yK1aJ/ZhDAk/u6XV ielGO+h651qd
7m3d08gkBXja2DnHgea/vyR2IIADYZi9XY380pCK/VWlXPlcLrvxPNTqIK/V Gjju4Kbl3nTa
DhcztOBCTvAafQUp1ygGsaQgka8+P2EWUhDOPP98/84f/T56HN04TYGjpoCY JyKAppzDAuLm
HUxxQmVzRcIZyLgZz4FStMBvk0RKzhBfgkBkgWdw47x/9xUvMaKYzdDnhNIH TpgEMXoLIJKE
s/fv/oZlbh8ElEQxILGSKG/DMEWUTCFYBxTQJ7mgjxBHnMXwIkh6HwWUxzCi qU1Mjqe+xEJC
2DA0zEy46V23fr5E2yr7qETv9DoG9LiMrt2FQhJHFK9fiUR36uv97VDB+4Hg lH7EwpdrCo3S
7VxJ+7r7HZTck4nAgkB8gO+51/VdpDs/S0IrcPNbyve9U7hZPJIA0H2Kf5vh +0qgA/OWsymZ
JQIESh9vq+l0c/VgLe+7GvAEi/QBJfxbRV0SPeAZ1DWmdzIOC1s+Cr5Kv/uJ WMIaUY7Dxq4o
x3O99rcBCmBhehEIEkkT8OkXxowbp7g7EhN4171wRDYNtbjK/dpJg9oPU4WD gwDi+Mo9oag3
uFDRVYXcX7MAhbze47ZPxsT2TX58eTqmUps71h0bJ5orOjQR1UXqa6ltm0j4 rEGOa3m3UzuY
dPffMMMzEFcaJiNILIN5SeFuQ62ndVIPsBlhuQ/vgMIMS0Ahf+CxbJRFindM b1xCdm3OcoJH
+G8Csdx3yZ5YvcUFr2ZXbxuEuZQR+pT+8bWgwCjLlFED05STaiKMvymcAnRj pwZ4hBmJpcBZ
GoFU4qJNbJhaVFPacW0Pgr+tC5sjwTMSGFKC48bOHTVgrsnHZ+AXfjqE7vX/ eE+r1HBjWQEB
ogjfggOKO6miKr2bTnoG7pc9fzwX5TRMu6kRbewKFbl4g9pYOlhD/cI19uTa tf1z8faM23kl
eibrNuN0y5mEN1kglEUqhLptk6fq9+8MvGP91dgYhqt4Qa5PaGcQ5O9TGaEk zlEG3qlnKJqr
x/icmm8Euh70zgIyW9M2jW8O4vPgNcsnYwlsM6zb/o29+yqUdya3Ai7Jkt2n uQAcQqg9qm3a
k6qZqmuyqQTywDm9yv6oSyQS1tje0aGWz3d/2oKPML3gIwwHkizhx1v0xRm+ 1la99jMqOXdZ
dktJquSOB0mubH9t5g4uXGCqbP8Qt31OqpZjIHiDIJFZRsA2pOydTHvNGR8K OJOEJbCR7GR6
xfrtW9FjChCZECuX0oUXtaM0QnGVd+63TNl1QhCOIkoClW+8cPE6ARbMh+GS xFwgWAKT95xH
44wUDm5rWjCtlMtJ2qZfxgijAnILpx+v7ZpWvJVAz+MDBK9vCjgzQiAASxiy 8DFhG+k+Yrtf
4bUHiuWUi8XzuAKo1EDPkcY8H0cohAVHd+mffdvSB9wVayqvH1YjJsU6Z7Ii sdkgH95Sk9fJ
okPVK1EAG+K2fQahlbtfPY/V9JFlC1mVKbUym1MOVbhur5RqKhYvTULP7JXx FXP8fIr4E+ef
tJXkAoxFx/2X2n952sw+N86YLTEloSPzp3LUwt7MBmlHBEJw0ci+FSt8UyBX tjaSRVXrrvGt
K/PSS/6pO+oLxUr9U5SmWwdzCF7V910A18SyZQAdO1kJ7CNPWBg3Comebasi fhuTusP97TAv
D2YDsAtV3NHZrGnRYpz18qDI5jw/+6JmPBzeYYkbG4my8rIi6pWLQv47icnh HO11a1ur/P4k
AHIoLq6GlB4I0TLXcyhXhGrydj1teTErqkTumGahs3IN7fkDD52uBJezDYVS yje0QGP9FTOO
c3i2a3nW8qzlWcuzlmf/0jzbvZBn3X6TBJzFzeKZvkzUhhiakamlUUujlkYt jVoarU2jc6BR
QZ32eJE9XmSPF9njRfZ4kT1edIF6e7zIHi+yx4vs8SJ7vMgeL7LHi44fL/pu 6zgppa2A2QqY
rYDZCpitgNVhTq+jmXOaUNoEyTl1e80YL+ELhMSSqSVTS6aWTH9IMn3/7u+j z0+P/zk48pkQ
tCpOdTodx3Mywv3Q6nzwvA3ton67kwL8NvL94a8j50HwCYVF7PAgSISA0FnN gTmELfkrYTMn
4CE4U8EXTkST2QfCbpyfjqn9CaXg/tPw9l9Oy7Lv0a7ZG8Nj2Onca5li+esU B5B2ZyFfpb3z
j3xLpqEvFAsYWXun73B7KHsH5lCuD7L3DYjGc8+62xyL8FZZtndH+7X+WWzd b5LE6yOIPddU
ZzoGqIvLLTNed1D71LnqduXlL6kRrN8yFamyUAiSWPIF+pg+3JiFmeu5QPGc r17mhEJjV169
sXPsOYMjTrs2TU+GKNsc7y4F217dtLZZV9e7jjLVLwqAgAvIWkuyAOTjKTwm jGn+LF3qs/R1
LTDFkrbCrQ+i46e3j9HvnKr6bl3htk2+cFvGKvQfHS/7kaLrQdcmNjkHoGcK MrM//HkiQ75i
RXlvAlMu4A5iKfj6YLBObp1utwTimHDmZ2c2x4uIZvkapgk8s0mWaTYO7qth 6NfewjwAWNaA
v3w/LpVgodGP7594l+/T5IuEotx/XJlbe3v0++w09i/2pN1ptDuNdqfR7jTa nUa702h3Gu1O
44+701jvH5wkkRSQ/gmDycz+c5Mto9syui2j/5BldMtptjhti9O2OG2L07Y4 bYvTtjhti9O2
OG2L07Y4bYvTtjhti9O2OG2L0/+/4jSO/sl4gIM5/OJ6rcGg1+23uv1e9x9q bfFFj/0X1Vv8
UmOWfx7f4uw//IPX3Rl195cSxjSbsagvsYRS9edpDk6sclgn/8kvh8QOnvBE OpI7E3ASlUaj
b83F88R1mAEeT8g972RiU6lDwIIvoSwu4qoq+z/nR0C3/i14d0J58FoIi5nx sJlSdW1a1J45
lBtKqGygQt9Yi/v+2ZNxUWqTJ5s82eTJJk82ebLJU+fn/wFQSwECGQAUAAAA CACdkJY4QoCh
9bQIAACSbgAACQAAAAAAAAAAACAAAAAAAAAAdHJhY2UudHh0UEsFBgAAAAAB AAEANwAAAP8I
AAAAAA==
--------------020604040603000800080105--
Re: rap 1m3 - problem after cleaning browser internals [message #84035 is a reply to message #83977] Tue, 22 April 2008 10:44 Go to previous messageGo to next message
Hi Dmitry,
with which version of RAP are you working with?
Rüdiger
Dmitry wrote:
> Hi
>> strack trace.
> settings.
> doesn't work.
> (that's enough)
> Regards,
> Dmitry Pryadkin
Re: rap 1m3 - problem after cleaning browser internals [message #84139 is a reply to message #84035] Wed, 23 April 2008 01:24 Go to previous messageGo to next message
Hello Rüdiger
I'm using rap_1.1.0.20080407-1124 that is 1M3.
Still not sure what was that. Can't get opera and firefox back to work.
Sometimes these browsers prompt me that multiple browser instances or
multi-tabs aren't supported. Although I don't use multi-tabs and have
only the one instance running. Anyways, it seems that IE works.
Anyone tried cleaning the browser cache?
Rüdiger Herrmann shrieb:
> Hi Dmitry,
> Cheers,
> Rüdiger
Re: rap 1m3 - problem after cleaning browser internals [message #84200 is a reply to message #84139] Wed, 23 April 2008 04:08 Go to previous messageGo to next message
Hi Dimitry,
I played around a bit with RAP from CVS HEAD but cannot reproduce
what you describe. Neither with IE, nor with FF, nor with Safari.
Just a wild guess: did you disable cookies in those browsers that do
not work?
Rüdiger
Dmitry wrote:
> Hello Rüdiger
> Thanks
>> Hi Dmitry,
>> Cheers,
>> Rüdiger
Re: rap 1m3 - problem after cleaning browser internals [message #84865 is a reply to message #84139] Fri, 25 April 2008 06:41 Go to previous message
Originally posted by: jkrause.innoopract.com
Hi Dmitry,
Are you sure that the address you typed in the browser did NOT have a /
(slash) at the end. The problem you describe is a known problem when you
append something other than ? (question mark) to the URL.
Jochen
Dmitry wrote:
> Hello Rüdiger
> Thanks
>> Hi Dmitry,
>> Cheers,
>> Rüdiger
Previous Topic:You guys are on to it
Next Topic:Wrong UI Thread
Current Time: Sun Aug 31 01:03:25 EDT 2025
Powered by FUDForum. Page generated in 0.13410 seconds
