Home » Eclipse Projects » GEF » collapse/expand nested container problem
collapse/expand nested container problem [message #83042] Tue, 10 June 2003 14:26 Go to next message
Originally posted by: jwoods.journee.com
I'm in the process of creating a nested container that will contain other
nodes with routes between those nodes. I'm trying to give this container
the ability to be shown in either an expanded or collapsed state (with the
contained nodes and routes visible or not visible).
Currently I can change the container's figure to not show the children when
"collapsed", but the routes between those children are still being shown
(nor are they updated as the container is moved/resized).
What should I be doing to make the routes disappear when the container is in
the "collapsed" state?
- Jason
Re: collapse/expand nested container problem [message #83287 is a reply to message #83042] Wed, 11 June 2003 11:16 Go to previous messageGo to next message
How are you preventing the children from showing up when the parent is
collapsed? One way to do this is to return only the visible children in your
edit part's getModelChildren() method. When you collapse the parent, the child
edit parts will be removed and their connections should also be removed. When
you expand it, the child edit parts should be re-added and (I think) the
connections will also be re-added.
Eric
> - Jason
Re: collapse/expand nested container problem [message #83509 is a reply to message #83287] Wed, 11 June 2003 17:08 Go to previous messageGo to next message
Excellent! I was just redoing the figure inside the container's
refreshVisuals() to get rid of the child edit part's figures. Calling
refreshChildren() and having it not returning the children when in the
"collapsed" state got rid of the routes. It's obvious now that you've
mentioned it...
- Jason
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:bc7h3p$ufl$1@rogue.oti.com...
your
child
When
> Eric
other
container
the
when
is in
> > Thanks,
> > - Jason
Re: collapse/expand nested container problem [message #83872 is a reply to message #83509] Sun, 15 June 2003 14:17 Go to previous messageGo to next message
This might be problematic if you have connection from the children to nodes
outside the container.
"Jason Woods" <jwoods@journee.com> wrote in message
news:bc863e$k8e$1@rogue.oti.com...
> mentioned it...
> - Jason
> your
the
> child
> When
> > Eric
> other
> container
> the
> when
shown
> is in
> > > Thanks,
> > > - Jason
Re: collapse/expand nested container problem [message #83948 is a reply to message #83872] Mon, 16 June 2003 08:42 Go to previous message
That's OK - I explicitly disallow that (it's not meaningfull to my
application).
- Jason
"Randy Hudson" <none@us.ibm.com> wrote in message
news:bcid78$n47$1@rogue.oti.com...
nodes
> > mentioned it...
> > Thanks,
> > - Jason
in
> > your
> the
> > child
removed.
> > When
the
> > > Eric
> > other
> > container
(with
> > the
children
> > when
> shown
container
> > is in
> > > > Thanks,
> > > > - Jason
Previous Topic:Multiple ConnectionLayers
Next Topic:Moving EditPart effect on other EditParts
Current Time: Tue Jul 22 02:52:23 EDT 2025
Powered by FUDForum. Page generated in 0.28371 seconds
