Home » Eclipse Projects » Remote Application Platform (RAP) » Problems building a war file of my RAP application
Problems building a war file of my RAP application [message #83595] Sat, 19 April 2008 08:58 Go to next message
Originally posted by: sarek.nurfuerspam.de
Hi all,
I am just trying to build a war file of my first RAP application.
Following Elias' tutorial from
http://rapblog.innoopract.com/2007/12/rap-deployment-part-2- deploying-your.html
I adapted the ANT script from the org.eclipse.rap.demo.feature.
The problem is that the pde.exportFeatures task seems to have problems
finding the javax.servlet.* classes.
As suggested I used the Import Team Project Set wizard to get the
plugins needed for building the war file. My Workspace now has the
following projects:
META.rap (my project)
META.rap.war.feature (the adapted org.eclipse.rap.demo.feature)
org.eclipse.equinox.http.registry
org.eclipse.equinox.http.servlet
org.eclipse.equinox.http.servletbridge
org.eclipse.equinox.servletbridge
org.eclipse.equinox.servletbridge.feature
org.eclipse.update.configurator
javax.servlet
As you see, the javax.servlet part is available. Other plugins reference
this part as dependency and eclipse itself does not show any errors.
However, when I start the pde.exportFeatures task I find a logs.zip file
in the destination folder which contains the following errors:
in org.eclipse.equinox.http.registry_1.0.100.200804191334/@dot. bin.log:
> # 19.04.08 13:34:44 CEST
> # Eclipse Java Compiler 0.793_R33x, 3.3.2, Copyright IBM Corp 2000, 2008. All rights reserved.
> 1. ERROR in C:\Dokumente und Einstellungen\Sarek\Eigene Dateien\workspace\org.eclipse.equinox.http.registry\src\org\ eclipse\equinox\http\registry\internal\DefaultRegistryHttpCo ntext.java (at line 1)
> The type javax.servlet.http.HttpServletRequest cannot be resolved. It is indirectly referenced from required .class files
> 2. ERROR in C:\Dokumente und Einstellungen\Sarek\Eigene Dateien\workspace\org.eclipse.equinox.http.registry\src\org\ eclipse\equinox\http\registry\internal\DefaultRegistryHttpCo ntext.java (at line 1)
> The type javax.servlet.http.HttpServletResponse cannot be resolved. It is indirectly referenced from required .class files
> 3. ERROR in C:\Dokumente und Einstellungen\Sarek\Eigene Dateien\workspace\org.eclipse.equinox.http.registry\src\org\ eclipse\equinox\http\registry\internal\DefaultRegistryHttpCo ntext.java (at line 16)
> import javax.servlet.http.HttpServletRequest;
> The import javax.servlet.http.HttpServletRequest cannot be resolved
.... and masses more ...
The question is what must I do so that the javax.servlet classes CAN be
found and that the compile process does not fail?
I double and triple checked everything in my project settings. I can't
find the catch.
Can you guys help me?
Thanks in advance
Christian
To reply to this posting directly use the following address and
remove the 'NO-SPAM' part: Riedel.Christian.NO-SPAM@gmx.net
Re: Problems building a war file of my RAP application [message #83638 is a reply to message #83595] Sun, 20 April 2008 22:14 Go to previous messageGo to next message
Originally posted by: cheney_chen.i-len.com
That problem is that you didn't import the javax.servlet and
javax.servlet.http packages in your first RAP application.Please check the
MANIFEST.MF in your first RAP application include the javax.servlet and
javax.servlet.http import package.
Hope helps.
cheers,
Cheney
Christian Riedel wrote:
> Hi all,
> following projects:
> javax.servlet
>> # All rights reserved.
>> (at line 1)
>> ^ The type javax.servlet.http.HttpServletRequest cannot be resolved. It
>> is indirectly referenced from required .class files ---------- 2. ERROR
>> (at line 1)
>> ^ The type javax.servlet.http.HttpServletResponse cannot be resolved. It
>> is indirectly referenced from required .class files ---------- 3. ERROR
>> (at line 16) import javax.servlet.http.HttpServletRequest;
>> ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ The import
>> javax.servlet.http.HttpServletRequest cannot be resolved ----------
> find the catch.
> Thanks in advance
> Christian
Re: Problems building a war file of my RAP application [message #83683 is a reply to message #83638] Mon, 21 April 2008 00:50 Go to previous messageGo to next message
Hi Cheney,
thanks for this hint, but my first RAP application already does import
the javax.servlet and javax.servlet.http packages. So that does not seem
to be the problem.
However, yesterday I tried building the war using the current Eclipse
3.4 milestone release. Which did not produce the compile errors.
Here's how I created my test project:
- I used the org.eclipse.rap.demo project
- I included the org.eclipse.rap.demo.feature to my workspace from
:pserver:anonymous@dev.eclipse.org:/cvsroot/technology
- I added the servletBridge by importing the following team project set
via this link:
http://www.eclipse.org/equinox/server/downloads/servletbridg e-anon.psf
- I added the org.eclipse.update.configurator from my eclipse installation
- I adapted the ant script to have the right paths
No matter what I do, when I now start the ant task, I see the progress
indicator of the pdeExportFeatures task running ... and then, after some
time, have this logs.zip file in my destination dir.
I really cannot find what is going wrong there. After all it is the
unchanged examples I am trying it with.
Any more ideas?
TIA
Christian
Cheney schrieb:
> Hope helps.
> cheers,
> Cheney
>> Hi all,
>> following projects:
>> javax.servlet
>>> (at line 1)
>>> (at line 1)
>> find the catch.
>> Thanks in advance
>> Christian
Re: Problems building a war file of my RAP application [message #83742 is a reply to message #83683] Mon, 21 April 2008 04:05 Go to previous messageGo to next message
> Hi Cheney,
> to be the problem.
> via this link:
> Any more ideas?
> TIA
> Christian
> Cheney schrieb:
>> Hi,
>> Hope helps.
>> cheers,
>> Cheney
>>> Hi all,
>>> following projects:
>>> javax.servlet
>>>> 1. ERROR in C:Dokumente und EinstellungenSarekEigene
Dateienworkspaceorg.eclipse.equinox.http.registrysrcorgeclip seequinoxhttpregistryinternalDefaultRegistryHttpContext.java
>>>> (at line 1)
>>>> (at line 1)
>>> find the catch.
>>> Thanks in advance
>>> Christian
Hey Christian,
i had the same problem. After the step with the ../servletbridge-anon.psf,
you have to delete the javax.servlet project, because it comes to an
conflict with the pre-installed javax.servlet in the RAP target platform.
From now on you should have no problems with some logs.zip file in the
build directory, after running the webappBuilder.xml.
Greetings
Stefan R.
Re: Problems building a war file of my RAP application [message #83787 is a reply to message #83742] Mon, 21 April 2008 05:06 Go to previous messageGo to next message
Hi Stefan,
thanks a lot for your hint. After deleting the servlet 2_4 project from
the wokspace, I got rid of these compiler errors! Works like a charm now!
Christian
>> Hi Cheney,
>> seem to be the problem.
>> set via this link:
>> installation
>> some time, have this logs.zip file in my destination dir.
>> Any more ideas?
>> TIA
>> Christian
>> Cheney schrieb:
>>> Hi,
>>> check the
>>> Hope helps.
>>> cheers,
>>> Cheney
>>>> Hi all,
>>>> following projects:
>>>> javax.servlet
>>>> reference
>>>> file
>>>>> 2008.
>>>>> (at line 1)
>>>>> resolved. It
>>>>> ERROR
>>>>> (at line 1)
>>>>> resolved. It
>>>>> ERROR
>>>> find the catch.
>>>> Thanks in advance
>>>> Christian
> Hey Christian,
> ../servletbridge-anon.psf, you have to delete the javax.servlet project,
> because it comes to an conflict with the pre-installed javax.servlet in
> Greetings
> Stefan R.
Re: Problems building a war file of my RAP application [message #83992 is a reply to message #83787] Tue, 22 April 2008 09:55 Go to previous messageGo to next message
Hi, RAP Team,
I am seeing the same error when running:
The type javax.servlet.http.HttpServlet cannot be resolved. It is
and I also see that it goes away when I close the javax project. Can
you confirm that we should no longer have the javax project in the
workspace when exporting with webappBuilder.xml?
I also tried running webappBuilder.xml with all of the RAP and
servletbridge projects (including javax) from CVS, with no RAP target
platform at all, and I got the same error. Since there is no "conflict"
in this case between the CVS javax and the one in the target platform,
I'm not sure why this shouldn't work. Should we not be able to run
webappBuilder.xml in this way, with all projects from CVS and none from
the target platform?
Ryan
> Hi Stefan,
> Cheers,
> Christian
>>> Hi Cheney,
>>> import the javax.servlet and javax.servlet.http packages. So that
>>> does not seem to be the problem.
>>> set via this link:
>>> installation
>>> progress indicator of the pdeExportFeatures task running ... and
>>> then, after some time, have this logs.zip file in my destination dir.
>>> Any more ideas?
>>> TIA
>>> Christian
>>> Cheney schrieb:
>>>> Hi,
>>>> check the
>>>> Hope helps.
>>>> cheers,
>>>> Cheney
>>>>> Hi all,
>>>>> following projects:
>>>>> javax.servlet
>>>>> reference
>>>>> file
>>>>> in
>>>>>> 2000, 2008.
>>>>>> (at line 1)
>>>>>> resolved. It
>>>>>> ERROR
>>>>>> (at line 1)
>>>>>> resolved. It
>>>>>> ERROR
>>>>> CAN be
>>>>> find the catch.
>>>>> Thanks in advance
>>>>> Christian
>> Hey Christian,
>> project, because it comes to an conflict with the pre-installed
>> the build directory, after running the webappBuilder.xml.
>> Greetings
>> Stefan R.
Re: Problems building a war file of my RAP application [message #84005 is a reply to message #83992] Tue, 22 April 2008 09:58 Go to previous messageGo to next message
Also, if we need to close javax, would we also need to close the
following, which appear both in the set of servletbridge CVS projects
and in the RAP target platform?
org.eclipse.equinox.http.jetty
Ryan Donnelly wrote:
> Hi, RAP Team,
> Can you confirm that we should no longer have the javax project in the
> Ryan
>> Hi Stefan,
>> from the wokspace, I got rid of these compiler errors! Works like a
>> charm now!
>> Cheers,
>> Christian
>>>> Hi Cheney,
>>>> Eclipse 3.4 milestone release. Which did not produce the compile
>>>> errors.
>>>> set via this link:
>>>> installation
>>>> Any more ideas?
>>>> TIA
>>>> Christian
>>>> Cheney schrieb:
>>>>> Hi,
>>>>> check the
>>>>> and
>>>>> Hope helps.
>>>>> cheers,
>>>>> Cheney
>>>>>> Hi all,
>>>>>> problems
>>>>>> following projects:
>>>>>> javax.servlet
>>>>>> reference
>>>>>> logs.zip file
>>>>>> in
>>>>>>> 2000, 2008.
>>>>>>> (at line 1)
>>>>>>> resolved. It
>>>>>>> ERROR
>>>>>>> (at line 1)
>>>>>>> resolved. It
>>>>>>> ERROR
>>>>>> CAN be
>>>>>> can't
>>>>>> find the catch.
>>>>>> Thanks in advance
>>>>>> Christian
>>> Hey Christian,
>>> Greetings
>>> Stefan R.
Re: Problems building a war file of my RAP application [message #84020 is a reply to message #84005] Tue, 22 April 2008 10:14 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
I already have an action item for checking this. We'll keep you posted -
probably we will provide a new psf and have to update the docu a little
bit for the next milestone.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Ryan Donnelly [mailto:ryanrd1@gmail.com]
Bereitgestellt: Dienstag, 22. April 2008 15:58
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Problems building a war file of my RAP application
Betreff: Re: Problems building a war file of my RAP application
> Hi, RAP Team,
"conflict"
> from the target platform?
> Ryan
>> Hi Stefan,
>> charm now!
>> Cheers,
>> Christian
>>>> Hi Cheney,
>>>> errors.
>>>> set via this link:
>>>> psf
>>>> installation
dir.
>>>> Any more ideas?
>>>> TIA
>>>> Christian
>>>> Cheney schrieb:
>>>>> Hi,
>>>>> check the MANIFEST.MF in your first RAP application include the
>>>>> javax.servlet and javax.servlet.http import package.
>>>>> Hope helps.
>>>>> cheers,
>>>>> Cheney
>>>>>> Hi all,
>>> g-your.html
>>>>>> problems finding the javax.servlet.* classes.
>>>>>> the following projects:
>>>>>> javax.servlet
>>>>>> reference this part as dependency and eclipse itself does not
>>>>>> show any errors.
>>>>>> logs.zip file in the destination folder which contains the
>>>>>> following errors:
>>>>>> in
>>>>>>> 2000, 2008.
>>>>>>> (at line 1)
>>>>>>> ---------- 2.
>>>>>>> ERROR
>>>>>>> (at line 1)
>>>>>>> ---------- 3.
>>>>>>> ERROR
>>>>>> CAN be found and that the compile process does not fail?
>>>>>> can't find the catch.
>>>>>> Thanks in advance
>>>>>> Christian
>>> Hey Christian,
>>> Greetings
>>> Stefan R.
Re: Problems building a war file of my RAP application [message #84110 is a reply to message #84020] Tue, 22 April 2008 17:05 Go to previous messageGo to next message
Frank,
Thanks, if you could take a look at it soon that would be helpful. I
can no longer export even the calc example with the servletbridge
projects from CVS.
With 1.1M2 as the target platform, if javax is in the workspace i get
the error discussed below (and I can see it in logs.zip as well).
Without it, the PDE export completes without error but when I run it
(http://localhost:8080/calc/rap) I get an error "An entry point named
'default' does not exist". The only thing in .metadata/.log (there are
no other log files) is:
java.lang.NoClassDefFoundError:
org/eclipse/core/internal/runtime/auth/AuthorizationHandler
which I always get, even when it is working.
If I remove org.eclipse.equinox.http.registry and
org.eclipse.equinox.http.servlet from the workspace and export I still
get the same thing.
With 1.1M3, if javax is in the workspace i get the error discussed
below. Without it, the PDE export completes without error, but when I
run it, i get "The requested resource (ProxyServlet: /calc/rap) is not
available.". There is no .metadata/.log, but there is a log file
configuration/1208897299078.log. It only has:
Ryan
Frank Appel wrote:
> Ciao
> Frank
>> Hi, RAP Team,
> "conflict"
>> Thanks,
>> Ryan
>>> Hi Stefan,
>>> charm now!
>>> Cheers,
>>> Christian
>>>>> Hi Cheney,
>>>>> errors.
>>>>> set via this link:
>>>>> psf
>>>>> installation
> dir.
>>>>> Any more ideas?
>>>>> TIA
>>>>> Christian
>>>>> Cheney schrieb:
>>>>>> Hi,
>>>>>> Hope helps.
>>>>>> cheers,
>>>>>> Cheney
>>>>>>> Hi all,
>>>> g-your.html
>>>>>>> javax.servlet
>>>>>>> show any errors.
>>>>>>> following errors:
>>>>>>> in
>>>>>>>> 2000, 2008.
>>>>>>>> (at line 1)
>>>>>>>> ---------- 2.
>>>>>>>> ERROR
>>>>>>>> (at line 1)
>>>>>>>> ---------- 3.
>>>>>>>> ERROR
>>>>>>> Thanks in advance
>>>>>>> Christian
>>>> Hey Christian,
>>>> Greetings
>>>> Stefan R.
Re: Problems building a war file of my RAP application [message #84125 is a reply to message #84110] Tue, 22 April 2008 17:11 Go to previous messageGo to next message
This is with Eclipse 3.3.
> Frank,
> I can no longer export even the calc example with the servletbridge
> projects from CVS.
> get the error discussed below (and I can see it in logs.zip as well).
> get the same thing.
> Ryan
> Frank Appel wrote:
>> Hi,
>> Ciao
>> Frank
>>> Hi, RAP Team,
>> "conflict"
>>> Thanks,
>>> Ryan
>>>> Hi Stefan,
>>>> charm now!
>>>> Cheers,
>>>> Christian
>>>>>> Hi Cheney,
>>>>>> errors.
>>>>>> set via this link:
>>>>>> psf
>>>>>> installation
>> dir.
>>>>>> Any more ideas?
>>>>>> TIA
>>>>>> Christian
>>>>>> Cheney schrieb:
>>>>>>> Hi,
>>>>>>> Hope helps.
>>>>>>> cheers,
>>>>>>> Cheney
>>>>>>>> Hi all,
>>>>> g-your.html
>>>>>>>> javax.servlet
>>>>>>>> show any errors.
>>>>>>>> following errors:
>>>>>>>> in
>>>>>>>>> 2000, 2008.
>>>>>>>>> (at line 1)
>>>>>>>>> ---------- 2.
>>>>>>>>> ERROR
>>>>>>>>> (at line 1)
>>>>>>>>> ---------- 3.
>>>>>>>>> ERROR
>>>>>>>> Thanks in advance
>>>>>>>> Christian
>>>>> Hey Christian,
>>>>> Greetings
>>>>> Stefan R.
Re: Problems building a war file of my RAP application [message #84229 is a reply to message #84125] Wed, 23 April 2008 04:23 Go to previous messageGo to next message
>> Frank,
>> projects from CVS.
>> get the same thing.
>> Thanks,
>> Ryan
>> Frank Appel wrote:
>>> Hi,
>>> Ciao
>>> Frank
>>>> Hi, RAP Team,
>>> "conflict"
>>>> Thanks,
>>>> Ryan
>>>>> Hi Stefan,
>>>>> charm now!
>>>>> Cheers,
>>>>> Christian
>>>>>>> Hi Cheney,
>>>>>>> errors.
>>>>>>> set via this link:
>>>>>>> psf
>>>>>>> installation
>>> dir.
>>>>>>> Any more ideas?
>>>>>>> TIA
>>>>>>> Christian
>>>>>>> Cheney schrieb:
>>>>>>>> Hi,
>>>>>>>> Hope helps.
>>>>>>>> cheers,
>>>>>>>> Cheney
>>>>>>>>> Hi all,
>>>>>> g-your.html
>>>>>>>>> javax.servlet
>>>>>>>>> show any errors.
>>>>>>>>> following errors:
>>>>>>>>> in
>>>>>>>>>> 2000, 2008.
>>>>>>>>>> (at line 1)
>>>>>>>>>> ---------- 2.
>>>>>>>>>> ERROR
>>>>>>>>>> (at line 1)
>>>>>>>>>> ---------- 3.
>>>>>>>>>> ERROR
>>>>>>>>> Thanks in advance
>>>>>>>>> Christian
>>>>>> Hey Christian,
>>>>>> Greetings
>>>>>> Stefan R.
Hey Ryan,
I got the same problem with JBoss 4.0.2, but not with the RAP built-in APP
- Server Jetty. I changed the parameter of the *.Application entry point
in the plugin.xml in my project. The new value is "default" instead of
"view". Try this. When nothing happens, rename the id of the *.Application
entry point to *.default. But do not rename the class, which is needed. In
my case the whole thing worked, but i think it's transitional. So i hope a
better solution will arrive.
Greetings
Stefan R.
Re: Problems building a war file of my RAP application [message #84245 is a reply to message #84110] Wed, 23 April 2008 05:04 Go to previous messageGo to next message
Hi Ryan,
(full quote below)
Concerning your problem:
> available.".
For me it worked, if manually start org.eclipse.rap.ui from the OSGI
console. Before the command 'ss' shows that it is either resolved or
lazy (don't remember right now). When you issue a
It should become active.
After doing this the error with the ProxyServlet disappeared and calling
the app via yourhost/calc/rap should work - at least it worked for me.
HTH
Christian
Ryan Donnelly schrieb:
> Frank,
> projects from CVS.
> get the same thing.
> Ryan
> Frank Appel wrote:
>> Hi,
>> Ciao
>> Frank
>>> Hi, RAP Team,
>> "conflict"
>>> Thanks,
>>> Ryan
>>>> Hi Stefan,
>>>> charm now!
>>>> Cheers,
>>>> Christian
>>>>>> Hi Cheney,
>>>>>> errors.
>>>>>> set via this link:
>>>>>> psf
>>>>>> installation
>> dir.
>>>>>> Any more ideas?
>>>>>> TIA
>>>>>> Christian
>>>>>> Cheney schrieb:
>>>>>>> Hi,
>>>>>>> Hope helps.
>>>>>>> cheers,
>>>>>>> Cheney
>>>>>>>> Hi all,
>>>>> g-your.html
>>>>>>>> javax.servlet
>>>>>>>> show any errors.
>>>>>>>> following errors:
>>>>>>>> in
>>>>>>>>> 2000, 2008.
>>>>>>>>> (at line 1)
>>>>>>>>> ---------- 2.
>>>>>>>>> ERROR
>>>>>>>>> (at line 1)
>>>>>>>>> ---------- 3.
>>>>>>>>> ERROR
>>>>>>>> Thanks in advance
>>>>>>>> Christian
>>>>> Hey Christian,
>>>>> Greetings
>>>>> Stefan R.
Re: Problems building a war file of my RAP application [message #84494 is a reply to message #84245] Thu, 24 April 2008 07:25 Go to previous messageGo to next message
Thanks for the advice. I've filed a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=228650
> Hi Ryan,
> (full quote below)
>> available.".
> HTH
> Christian
>> Frank,
>> helpful. I can no longer export even the calc example with the
>> servletbridge projects from CVS.
>> are no other log files) is:
>> get the same thing.
>> Thanks,
>> Ryan
>> Frank Appel wrote:
>>> Hi,
>>> Ciao
>>> Frank
>>>> Hi, RAP Team,
>>> "conflict"
>>>> Thanks,
>>>> Ryan
>>>>> Hi Stefan,
>>>>> charm now!
>>>>> Cheers,
>>>>> Christian
>>>>>>> Hi Cheney,
>>>>>>> errors.
>>>>>>> set via this link:
>>>>>>> psf
>>>>>>> installation
>>> dir.
>>>>>>> Any more ideas?
>>>>>>> TIA
>>>>>>> Christian
>>>>>>> Cheney schrieb:
>>>>>>>> Hi,
>>>>>>>> Hope helps.
>>>>>>>> cheers,
>>>>>>>> Cheney
>>>>>>>>> Hi all,
>>>>>> g-your.html
>>>>>>>>> javax.servlet
>>>>>>>>> show any errors.
>>>>>>>>> following errors:
>>>>>>>>> in
>>>>>>>>>> 2000, 2008.
>>>>>>>>>> (at line 1)
>>>>>>>>>> ---------- 2.
>>>>>>>>>> ERROR
>>>>>>>>>> (at line 1)
>>>>>>>>>> ---------- 3.
>>>>>>>>>> ERROR
>>>>>>>>> Thanks in advance
>>>>>>>>> Christian
>>>>>> Hey Christian,
>>>>>> Greetings
>>>>>> Stefan R.
Re: Problems building a war file of my RAP application [message #84715 is a reply to message #84494] Fri, 25 April 2008 04:40 Go to previous messageGo to next message
the current deployment example seems to be somewhat outdated. We will
bring this up to date soon. If you are working with RAP M3 target there
should be no need to have the following projects opened in your
workspace:
javax.servlet
org.apache.commons.logging
org.mortbay.jetty
Having an additional javax.servlet project in the workspace seems indeed
to cause the build process to fail.
The current demo build feature uses org.eclipse.update.configurator.
Thanks to a hint of Jeff McAffer we can forget about this one. But it is
important to add org.eclipse.equinox.servletbridge.extensionbundle to
the config.ini's osgi.bundles list. Note that the latter bundle doesn't
exist in your deployment archive - it is created at runtime (that was
the reason we missed it...).
If you still want to use the update configurator bundle use @2:start.
Note also that the latest CVS-Head version comes with a RWT-Split -
RWT-host and RWT-q07-fragment. Don't use @start for the fragment!
Hope that helps.
Ciao
Frank
Bereitgestellt: Donnerstag, 24. April 2008 13:26
> Hi Ryan,
> (full quote below)
>> discussed below. Without it, the PDE export completes without error,
>> but when I run it, i get "The requested resource (ProxyServlet:
>> /calc/rap) is not available.".
> calling the app via yourhost/calc/rap should work - at least it worked
for me.
> HTH
> Christian
>> Frank,
>> still get the same thing.
>> /calc/rap) is not available.". There is no .metadata/.log, but there
>> is a log file configuration/1208897299078.log. It only has:
>> Thanks,
>> Ryan
>> Frank Appel wrote:
>>> Hi,
>>> posted - probably we will provide a new psf and have to update the
>>> docu a little bit for the next milestone.
>>> Ciao
>>> Frank
>>> Bereitgestellt: Dienstag, 22. April 2008 15:58 Bereitgestellt in:
>>> projects and in the RAP target platform?
>>>> Hi, RAP Team,
project.
>>>> the
>>>> target platform at all, and I got the same error. Since there is
>>>> no
>>> "conflict"
>>>> platform,
>>>> Thanks,
>>>> Ryan
>>>>> Hi Stefan,
>>>>> a charm now!
>>>>> Cheers,
>>>>> Christian
>>>>>>> Hi Cheney,
>>>>>>> that does not seem to be the problem.
>>>>>>> errors.
>>>>>>> from :pserver:anonymous@dev.eclipse.org:/cvsroot/technology
>>>>>>> project
>>>>>>> set via this link:
>>>>>>> psf
>>>>>>> installation
>>> dir.
>>>>>>> the
>>>>>>> Any more ideas?
>>>>>>> TIA
>>>>>>> Christian
>>>>>>> Cheney schrieb:
>>>>>>>> Hi,
>>>>>>>> application.Please check the MANIFEST.MF in your first RAP
>>>>>>>> application include the javax.servlet and javax.servlet.http
import package.
>>>>>>>> Hope helps.
>>>>>>>> cheers,
>>>>>>>> Cheney
>>>>>>>>> Hi all,
application.
>>>>>> yin
>>>>>> g-your.html
>>>>>>>>> the
>>>>>>>>> javax.servlet
>>>>>>>>> show any errors.
>>>>>>>>> following errors:
>>>>>>>>> in
>>>>>>>>>> 2000, 2008.
>>>>>> ino xhttpregistryinternalDefaultRegistryHttpContext.java
>>>>>>>>>> (at line 1)
>>>>>>>>>> files
>>>>>>>>>> ---------- 2.
>>>>>>>>>> ERROR
>>>>>>>>>> (at line 1)
>>>>>>>>>> files
>>>>>>>>>> ---------- 3.
>>>>>>>>>> ERROR
>>>>>>>>> classes CAN be found and that the compile process does not
fail?
>>>>>>>>> I can't find the catch.
>>>>>>>>> Thanks in advance
>>>>>>>>> Christian
>>>>>> Hey Christian,
>>>>>> in the build directory, after running the webappBuilder.xml.
>>>>>> Greetings
>>>>>> Stefan R.
Re: Problems building a war file of my RAP application [message #84835 is a reply to message #84715] Fri, 25 April 2008 05:55 Go to previous messageGo to next message
Hi Frank,
thanks for the explanation! I will try it asap - it all seemed a bit
confusing to me up to now. Hope this will change now.
Cheers
Christian
Frank Appel schrieb:
> workspace:
> javax.servlet
> org.mortbay.jetty
> Hope that helps.
> Ciao
> Frank
>> Hi Ryan,
>> (full quote below)
> for me.
>> HTH
>> Christian
>>> Frank,
>>> Thanks,
>>> Ryan
>>> Frank Appel wrote:
>>>> Hi,
>>>> Ciao
>>>> Frank
>>>>> Hi, RAP Team,
> project.
>>>>> the
>>>>> no
>>>> "conflict"
>>>>> platform,
>>>>> Thanks,
>>>>> Ryan
>>>>>> Hi Stefan,
>>>>>> a charm now!
>>>>>> Cheers,
>>>>>> Christian
>>>>>>>> Hi Cheney,
>>>>>>>> errors.
>>>>>>>> project
>>>>>>>> set via this link:
>>>>>>>> psf
>>>>>>>> installation
>>>> dir.
>>>>>>>> the
>>>>>>>> Any more ideas?
>>>>>>>> TIA
>>>>>>>> Christian
>>>>>>>> Cheney schrieb:
>>>>>>>>> Hi,
> import package.
>>>>>>>>> Hope helps.
>>>>>>>>> cheers,
>>>>>>>>> Cheney
>>>>>>>>>> Hi all,
> application.
>>>>>>> yin
>>>>>>> g-your.html
>>>>>>>>>> the
>>>>>>>>>> javax.servlet
>>>>>>>>>> show any errors.
>>>>>>>>>> following errors:
>>>>>>>>>> in
>>>>>>>>>>> 2000, 2008.
>>>>>>>>>>> (at line 1)
>>>>>>>>>>> files
>>>>>>>>>>> ---------- 2.
>>>>>>>>>>> ERROR
>>>>>>>>>>> (at line 1)
>>>>>>>>>>> files
>>>>>>>>>>> ---------- 3.
>>>>>>>>>>> ERROR
> fail?
>>>>>>>>>> Thanks in advance
>>>>>>>>>> Christian
>>>>>>> Hey Christian,
>>>>>>> Greetings
>>>>>>> Stefan R.
Re: Problems building a war file of my RAP application [message #84957 is a reply to message #84715] Fri, 25 April 2008 11:23 Go to previous messageGo to next message
Originally posted by: marius.matter.adesso.ch
Thanks for the help. After a long time of try and error, from know I can
build up the .war for tomcat.
Here a short discription what i've done perhaps it helps others:
Elias' tutorial is a great entrypoint and works fine for me till I updated
to M3 of Rap.
Now I have to change this points from the tutorial
1. Removed the projects like Frank Appel said in his post
2. Remove the org.eclipse.update.configurator from the feature
3. Compute Required Features/Plugin inside the feature at the dependency
tab(not shure this is necessary)
4. Then run the ConfigIniCreator, was not necessary in M1 but know it
seems to be necessary
5. Copy the output to config.ini
6. Add all plugins which are marked in the feature "Unpack the
plugin-archiv after installation" those where not includet from the
ConfigIniCreator to the config.ini
7. Add org.eclipse.equinox.servletbridge.extensionbundle to config.ini as
Frank Appel said
This works for me, but I not realy shure this is the proper way :-)
Marius
Re: Problems building a war file of my RAP application [message #91167 is a reply to message #84715] Mon, 02 June 2008 06:51 Go to previous messageGo to next message
Frank,
I just reproduced the same steps as indicated by you and am having a
problem as described below.
When i deploy the war file on to tomcat and invoke the URL, i get the
following error on the browser:
description The server encountered an internal error () that prevented it
from fulfilling this request.
exception
java.lang.IllegalArgumentException: An entry point named 'default' does
not exist.
org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:77)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:230)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:116)
java.lang.Thread.run(Unknown Source)
note The full stack trace of the root cause is available in the Apache
Tomcat/6.0.16 logs.
No logs under configuration directory, while the workspace directory under
work has a log which displays the following stacktrace:
!ENTRY org.eclipse.rap.demo 4 0 2008-06-02 16:10:44.152
!MESSAGE Could not register entry point
'org.eclipse.rap.demo.DemoWorkbench' with request startup parameter
'default'.
!STACK 0
java.lang.UnsupportedClassVersionError: Bad version number in .class file
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:165)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:554)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:524)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:455)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:443)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:423)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:368)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:444)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:313)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
at
org.eclipse.ui.internal.servlet.EngineConfigWrapper.register WorkbenchEntryPoint(EngineConfigWrapper.java:219)
at
org.eclipse.ui.internal.servlet.EngineConfigWrapper.<init>(EngineConfigWrapper.java:82)
at
org.eclipse.ui.internal.servlet.RequestHandler.init(RequestH andler.java:40)
at
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.init(ServletRegistration.java:64)
at
org.eclipse.equinox.http.servlet.internal.ProxyServlet.regis terServlet(ProxyServlet.java:142)
at
org.eclipse.equinox.http.servlet.internal.HttpServiceImpl.re gisterServlet(HttpServiceImpl.java:59)
at
org.eclipse.ui.internal.servlet.HttpServiceTracker.addingSer vice(HttpServiceTracker.java:41)
at
org.osgi.util.tracker.ServiceTracker$Tracked.trackAdding(Ser viceTracker.java:1064)
at
org.osgi.util.tracker.ServiceTracker$Tracked.trackInitialSer vices(ServiceTracker.java:926)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:330)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:274)
at
org.eclipse.ui.internal.WorkbenchPlugin$3.addingService(Work benchPlugin.java:1069)
at
at
at
org.eclipse.ui.internal.WorkbenchPlugin.start(WorkbenchPlugi n.java:1073)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:1009)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:1003)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:984)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
at
at
at
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:33)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:441)
at
at
at
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:139)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:980)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at
org.eclipse.equinox.http.registry.internal.HttpContextManage r.added(HttpContextManager.java:75)
at
org.eclipse.equinox.http.registry.internal.ExtensionPointTra cker.open(ExtensionPointTracker.java:75)
at
org.eclipse.equinox.http.registry.internal.HttpContextManage r.start(HttpContextManager.java:47)
at
org.eclipse.equinox.http.registry.internal.HttpRegistryManag er.start(HttpRegistryManager.java:84)
at
org.eclipse.equinox.http.registry.internal.HttpServiceTracke r.addingService(HttpServiceTracker.java:58)
at
at
org.osgi.util.tracker.ServiceTracker$Tracked.track(ServiceTr acker.java:1042)
at
org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged( ServiceTracker.java:967)
at
org.eclipse.osgi.framework.internal.core.FilteredServiceList ener.serviceChanged(FilteredServiceListener.java:91)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.d ispatchEvent(BundleContextImpl.java:1248)
at
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:211)
at
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEv entSynchronous(ListenerQueue.java:141)
at
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEventPrivileged(Framework.java:1563)
at
org.eclipse.osgi.framework.internal.core.Framework.publishSe rviceEvent(Framework.java:1538)
at
org.eclipse.osgi.framework.internal.core.ServiceRegistration Impl.register(ServiceRegistrationImpl.java:122)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.c reateServiceRegistration(BundleContextImpl.java:666)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:617)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.r egisterService(BundleContextImpl.java:685)
at
org.eclipse.equinox.http.servlet.internal.Activator.register HttpService(Activator.java:78)
at
org.eclipse.equinox.http.servlet.internal.Activator.addProxy Servlet(Activator.java:57)
at
org.eclipse.equinox.http.servlet.internal.ProxyServlet.init( ProxyServlet.java:39)
at
org.eclipse.equinox.servletbridge.BridgeServlet.registerServ letDelegate(BridgeServlet.java:226)
at
org.eclipse.equinox.http.servletbridge.internal.Activator.st art(Activator.java:25)
at
at
at
at
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:355)
at
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1074)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:616)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:299)
at
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:489)
at
at
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:321)
Do please help me find a solution.
Murali
Re: Problems building a war file of my RAP application [message #91180 is a reply to message #84957] Mon, 02 June 2008 06:53 Go to previous messageGo to next message
Frank,
Iam using eclipse 3.4 and RC2 target.
I followed the steps as described .
exception
not exist.
Tomcat/6.0.16 logs.
'default'.
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Murali
Re: Problems building a war file of my RAP application [message #91210 is a reply to message #91180] Mon, 02 June 2008 07:09 Go to previous messageGo to next message
> at
UnsupportedClassVersionError usually means that you compiled for a
higher Java language version than your VM can execute. Check your
compiler compliance level and JRE version.
Ralf
Re: Problems building a war file of my RAP application [message #91225 is a reply to message #91210] Mon, 02 June 2008 08:18 Go to previous message
The problem is now resolved and thanks for the information.
Murali
Previous Topic:Registering resources - ResourceRegistrationException
Next Topic:FileUpload compile error
Current Time: Sun Aug 31 01:06:33 EDT 2025
Powered by FUDForum. Page generated in 0.12039 seconds
