Problem with debugging [message #836877] |
Wed, 04 April 2012 21:58  |
Hi all,
I have just started to getting familiar with eclipse CDT under MW 7. Before put this post I looked through the forum and I did not find the solution. The problem occure during debugging and the coment "No symbol table is loaded. Use the "file" command" is shown. This problem is not related to building and running process. Regarding to the additional information I am currently using GNU Debugger which is provided by Cygwin, by the way I was also debugging with MinGW GDB and the result was the same.
Moreover when I was creating a project I chose Empty Project, so my question is, do I have to constitute the makefile? I know that so called "Hello World C++ Project" automatically creates makefiile and makefile is destined for expanded project. I have used Microsoft Visual Studio before and there was no place for makefile.
OK, finaly my question is:
Does each empty eclipse project require makefile creation, if not what I do improper I get below mentioned message.
No symbol table is loaded. Use the "file" command.
[New Thread 2808.0xc44]
Thanks for any remarks.
FUDForum. Page generated in 0.04421 seconds
