Home » Language IDEs » C / C++ IDE (CDT) » Expressions not always updating
Expressions not always updating [message #821578] Thu, 15 March 2012 10:55 Go to next message
I have several Watch Expressions that I am following through a debug session. However, I noticed that some of the expressions were not updating as they should have in the code. I confirmed this by doing a command line gdb session (which is the same debugger that I am using in CDT: gdb/mi).
All I was following were simple indices in nested for loops, just like below:
for ( int i = 0; i<num_rows; i++ )
<code>
for ( int j = 0; j < 4; j++ )
<code>
"i" and "j" were not updating properly in the Expressions view.
I am running eclipse Galileo with CDT Version 6.0.0.200909110608 in a Linux environment. Any idea why the above occurs? Does a later version of CDT solve the problem?
Re: Expressions not always updating [message #822139 is a reply to message #821578] Fri, 16 March 2012 04:07 Go to previous messageGo to next message
I did not experience the problems you mentioned with Galileo. Do you have any compiler optimization turned on?
Re: Expressions not always updating [message #822498 is a reply to message #822139] Fri, 16 March 2012 14:18 Go to previous messageGo to next message
Yes, there are some optimizer options set for the gcc compiler in the Makefile.
Re: Expressions not always updating [message #825860 is a reply to message #822498] Wed, 21 March 2012 06:50 Go to previous messageGo to next message
Aero Engineer wrote on Fri, 16 March 2012 19:18
If optimization is turned you will get funny results during debug. Because the compiler might rearrange your code and omit some variables. I guess the second loop in your example with constant length of 4 will be completely replaced in the optimized code.
Re: Expressions not always updating [message #836613 is a reply to message #825860] Wed, 04 April 2012 13:52 Go to previous messageGo to next message
Thanks for your answer. I just now got back to working on this issue.
Re: Expressions not always updating [message #836829 is a reply to message #836613] Wed, 04 April 2012 20:40 Go to previous messageGo to next message
Very Happy
Re: Expressions not always updating [message #836830 is a reply to message #836829] Wed, 04 April 2012 20:40 Go to previous messageGo to next message
Surprised
Re: Expressions not always updating [message #836831 is a reply to message #836830] Wed, 04 April 2012 20:40 Go to previous messageGo to next message
hytdfhtrshtr
Re: Expressions not always updating [message #836832 is a reply to message #836831] Wed, 04 April 2012 20:43 Go to previous messageGo to next message
rewarfretgtretg
Re: Expressions not always updating [message #836833 is a reply to message #836832] Wed, 04 April 2012 20:43 Go to previous messageGo to next message
agree
Re: Expressions not always updating [message #836834 is a reply to message #836833] Wed, 04 April 2012 20:43 Go to previous messageGo to next message
great
Re: Expressions not always updating [message #836837 is a reply to message #836834] Wed, 04 April 2012 20:44 Go to previous messageGo to next message
more than words
Re: Expressions not always updating [message #836838 is a reply to message #836837] Wed, 04 April 2012 20:44 Go to previous messageGo to next message
more than words
Re: Expressions not always updating [message #836839 is a reply to message #836838] Wed, 04 April 2012 20:44 Go to previous messageGo to next message
Thanks for your post
Re: Expressions not always updating [message #836840 is a reply to message #836839] Wed, 04 April 2012 20:45 Go to previous messageGo to next message
Great idea!
Re: Expressions not always updating [message #836844 is a reply to message #836840] Wed, 04 April 2012 20:50 Go to previous messageGo to next message
thanks a lot
Re: Expressions not always updating [message #836847 is a reply to message #836844] Wed, 04 April 2012 20:55 Go to previous message
excellent
Previous Topic:How to get rid of old compilers "include paths not found" warnings?
Next Topic:syntax error after including class definition
Current Time: Mon Jul 21 04:25:12 EDT 2025
Powered by FUDForum. Page generated in 0.55399 seconds
