Multi-user mysql database [message #836502] |
Wed, 04 April 2012 11:06  |
Hello Everybody!
I will using a multi-user mysql database for Jubula. I install an MySql community Server 64-bit successfully on my Server.
At next i will to establish a connection to Jubula. To achieve these goal, it's necessary in --> Window --> Preferences --> Test --> Database Connections ... to configure a database connection ... it's done.
The next point (--> Test --> Select Database...) i choose the configured database and enter the username and password.
After the dialog i get the following message:
Database: Connection... has encountered a problem.
Exception[EclipseLink-4003](Eclipse Persistence Service - 2.3.2.v20111125-r10461):
org.eclipse.persistence.exceptions.DatabaseException
Exception Description: Configuration error. Class [com.mysql.jdbc.Driver] not found.
As a consequence, the connection to Database failed!
Any ideas or hints what can be the problem?
Thanks!
FUDForum. Page generated in 0.04152 seconds
