Home » Eclipse Projects » Eclipse 4 » Injecting a BundleContext
Injecting a BundleContext [message #835963] Tue, 03 April 2012 18:40 Go to next message
Hi folks,
does Eclipse 4.2 support having the current BudleContext injected ? Example:
MyClass.java:
@Inject
public void foo(BundleContext context) {
context.doSomething();
The above snippet would be nicer than FrameworkUtil.getBundle(MyClass.class).getBundleContext() -- however it does not seem to work.
Thanks for the input,
Elias.
Re: Injecting a BundleContext [message #840782 is a reply to message #835963] Tue, 10 April 2012 09:59 Go to previous messageGo to next message
No there are 2 solutions:
a) you convince Oleg that
1) IContextFunction gets class that requests an injected value
(need to see if I've already filed a bug for it because i wanted
to have this informations in other areas)
2) The DI-Engine knows how to deal with BundleContext magically
itself
b) You make up your own annotation (@BundleContext) and register it
using DS (i have code in my EclipseCon slides [1]) which would make
your code look like this.
MyClass.java:
@Inject
public void foo(@BundleContext BundleContext context) {
Tom
[1]http://tomsondev.bestsolution.at/2012/03/28/slides-from-eclipsecon-talks/
Am 04.04.12 00:40, schrieb Elias Volanakis:
> Hi folks,
> Example:
> MyClass.java:
> @Inject
> Elias.
Re: Injecting a BundleContext [message #841278 is a reply to message #840782] Wed, 11 April 2012 01:35 Go to previous message
Tom Schindl wrote on Tue, 10 April 2012 09:59
MyClass.java:
@Inject
What about a @Util annotation like this:
@Inject
public void foo(@Util BundleContext context) {
@Inject
public void foo(@Util Bundle bundle) {
bundle.doSomething();
Previous Topic:Split application model
Next Topic:Interative Tool key in a MacOS ?
Current Time: Sat Jul 26 18:52:03 EDT 2025
Powered by FUDForum. Page generated in 0.08741 seconds
