"cannot be cast" error in Weblogic server 10.3.5 [message #832799] |
Fri, 30 March 2012 11:52  |
Hi there,
I have a simple query like this,
List<OrderSet> emps = em
.createNamedQuery("findDocSetByNameId")
.setParameter("nameID", this.orderNo)
.getResultList();
if (emps.size() == 0) {
throw createMsgStoreServiceException("Order is not in Message Stoer.");
OrderSet os = emps.get(0);
When I run as a java application (JUnit case), everything is fine. But when I run via a web service hosted in a WLS 10.3.5, (I think my EclipseLink version is 11) I got an exception the the highlighted line saying can not case between the same java class.
following is the exception. Any help will be appreciated!!
<S:Envelope xmlns:S="schemas.xmlsoap.org/soap/envelope/">
<S:Body>
<S:Fault xmlns:ns4="www.w3.org/2003/05/soap-envelope">
<faultcode>S:Server</faultcode>
<faultstring>msgstore.model.OrderSet cannot be cast to msgstore.model.OrderSet</faultstring>
<detail>
<ns2:exception xmlns:ns2="//jax-ws.dev.java.net/" class="java.lang.ClassCastException" note="To disable this feature, set com.sun.xml.ws.fault.SOAPFaultBuilder.disableCaptureStackTrace system property to false">
<message>msgstore.model.OrderSet cannot be cast to msgstore.model.OrderSet</message>
<ns2:stackTrace>
<ns2:frame class="msgstore.service.NumberPortingBSMsgStoreService_MsgStorePortImpl" file="NumberPortingBSMsgStoreService_MsgStorePortImpl.java" line="147" method="setOrderState" />
<ns2:frame class="sun.reflect.NativeMethodAccessorImpl" file="NativeMethodAccessorImpl.java" line="native" method="invoke0" />
<ns2:frame class="sun.reflect.NativeMethodAccessorImpl" file="NativeMethodAccessorImpl.java" line="39" method="invoke" />
<ns2:frame class="sun.reflect.DelegatingMethodAccessorImpl" file="DelegatingMethodAccessorImpl.java" line="25" method="invoke" />
<ns2:frame class="java.lang.reflect.Method" file="Method.java" line="597" method="invoke" />
<ns2:frame class="weblogic.wsee.jaxws.WLSInstanceResolver$WLSInvoker" file="WLSInstanceResolver.java" line="92" method="invoke" />
<ns2:frame class="weblogic.wsee.jaxws.WLSInstanceResolver$WLSInvoker" file="WLSInstanceResolver.java" line="74" method="invoke" />
<ns2:frame class="com.sun.xml.ws.server.InvokerTube$2" file="InvokerTube.java" line="151" method="invoke" />
<ns2:frame class="com.sun.xml.ws.server.sei.EndpointMethodHandlerImpl" file="EndpointMethodHandlerImpl.java" line="268" method="invoke" />
<ns2:frame class="com.sun.xml.ws.server.sei.SEIInvokerTube" file="SEIInvokerTube.java" line="100" method="processRequest" />
<ns2:frame class="com.sun.xml.ws.api.pipe.Fiber" file="Fiber.java" line="866" method="__doRun" />
<ns2:frame class="com.sun.xml.ws.api.pipe.Fiber" file="Fiber.java" line="815" method="_doRun" />
<ns2:frame class="com.sun.xml.ws.api.pipe.Fiber" file="Fiber.java" line="778" method="doRun" />
<ns2:frame class="com.sun.xml.ws.api.pipe.Fiber" file="Fiber.java" line="680" method="runSync" />
<ns2:frame class="com.sun.xml.ws.server.WSEndpointImpl$2" file="WSEndpointImpl.java" line="403" method="process" />
<ns2:frame class="com.sun.xml.ws.transport.http.HttpAdapter$HttpToolkit" file="HttpAdapter.java" line="532" method="handle" />
<ns2:frame class="com.sun.xml.ws.transport.http.HttpAdapter" file="HttpAdapter.java" line="253" method="handle" />
<ns2:frame class="com.sun.xml.ws.transport.http.servlet.ServletAdapter" file="ServletAdapter.java" line="140" method="handle" />
<ns2:frame class="weblogic.wsee.jaxws.WLSServletAdapter" file="WLSServletAdapter.java" line="171" method="handle" />
<ns2:frame class="weblogic.wsee.jaxws.HttpServletAdapter$AuthorizedInvoke" file="HttpServletAdapter.java" line="708" method="run" />
<ns2:frame class="weblogic.security.acl.internal.AuthenticatedSubject" file="AuthenticatedSubject.java" line="363" method="doAs" />
<ns2:frame class="weblogic.security.service.SecurityManager" file="SecurityManager.java" line="146" method="runAs" />
<ns2:frame class="weblogic.wsee.util.ServerSecurityHelper" file="ServerSecurityHelper.java" line="103" method="authenticatedInvoke" />
<ns2:frame class="weblogic.wsee.jaxws.HttpServletAdapter$3" file="HttpServletAdapter.java" line="311" method="run" />
<ns2:frame class="weblogic.wsee.jaxws.HttpServletAdapter" file="HttpServletAdapter.java" line="336" method="post" />
<ns2:frame class="weblogic.wsee.jaxws.JAXWSServlet" file="JAXWSServlet.java" line="95" method="doRequest" />
<ns2:frame class="weblogic.servlet.http.AbstractAsyncServlet" file="AbstractAsyncServlet.java" line="99" method="service" />
<ns2:frame class="javax.servlet.http.HttpServlet" file="HttpServlet.java" line="820" method="service" />
<ns2:frame class="weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction" file="StubSecurityHelper.java" line="227" method="run" />
<ns2:frame class="weblogic.servlet.internal.StubSecurityHelper" file="StubSecurityHelper.java" line="125" method="invokeServlet" />
<ns2:frame class="weblogic.servlet.internal.ServletStubImpl" file="ServletStubImpl.java" line="300" method="execute" />
<ns2:frame class="weblogic.servlet.internal.TailFilter" file="TailFilter.java" line="26" method="doFilter" />
<ns2:frame class="weblogic.servlet.internal.FilterChainImpl" file="FilterChainImpl.java" line="56" method="doFilter" />
<ns2:frame class="oracle.security.jps.ee.http.JpsAbsFilter$1" file="JpsAbsFilter.java" line="111" method="run" />
<ns2:frame class="java.security.AccessController" file="AccessController.java" line="native" method="doPrivileged" />
<ns2:frame class="oracle.security.jps.util.JpsSubject" file="JpsSubject.java" line="313" method="doAsPrivileged" />
<ns2:frame class="oracle.security.jps.ee.util.JpsPlatformUtil" file="JpsPlatformUtil.java" line="413" method="runJaasMode" />
<ns2:frame class="oracle.security.jps.ee.http.JpsAbsFilter" file="JpsAbsFilter.java" line="94" method="runJaasMode" />
<ns2:frame class="oracle.security.jps.ee.http.JpsAbsFilter" file="JpsAbsFilter.java" line="161" method="doFilter" />
<ns2:frame class="oracle.security.jps.ee.http.JpsFilter" file="JpsFilter.java" line="71" method="doFilter" />
<ns2:frame class="oracle.dms.servlet.DMSServletFilter" file="DMSServletFilter.java" line="136" method="doFilter" />
<ns2:frame class="weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction" file="WebAppServletContext.java" line="3715" method="wrapRun" />
<ns2:frame class="weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction" file="WebAppServletContext.java" line="3681" method="run" />
<ns2:frame class="weblogic.security.acl.internal.AuthenticatedSubject" file="AuthenticatedSubject.java" line="321" method="doAs" />
<ns2:frame class="weblogic.security.service.SecurityManager" file="SecurityManager.java" line="120" method="runAs" />
<ns2:frame class="weblogic.servlet.internal.WebAppServletContext" file="WebAppServletContext.java" line="2277" method="securedExecute" />
<ns2:frame class="weblogic.servlet.internal.WebAppServletContext" file="WebAppServletContext.java" line="2183" method="execute" />
<ns2:frame class="weblogic.servlet.internal.ServletRequestImpl" file="ServletRequestImpl.java" line="1454" method="run" />
<ns2:frame class="weblogic.work.ExecuteThread" file="ExecuteThread.java" line="209" method="execute" />
<ns2:frame class="weblogic.work.ExecuteThread" file="ExecuteThread.java" line="178" method="run" />
</ns2:stackTrace>
</ns2:exception>
</detail>
</S:Fault>
</S:Body>
</S:Envelope>
FUDForum. Page generated in 0.07004 seconds
