Home » Language IDEs » Java Development Tools (JDT) » get rid of -Djava.endorsed.dirs="/opt/local/share/java/tomcat6/endorsed"(java wtp spring @Autowired)
get rid of -Djava.endorsed.dirs="/opt/local/share/java/tomcat6/endorsed" [message #834899] Mon, 02 April 2012 10:35 Go to next message
Hi, I read on stackoverflow.com that -Djava.endorsed.dirs="/opt/local/share/java/tomcat6/endorsed" causes spring loading to fail during tomcat6 startup with wtp plugin. But when I delete it from tomcat6 launch configuration next time I open it again it's still there, so what's happening?
a snippet from web.xml
<listener>
  <listener-class>org.springframework.web.context.ContextLoaderListener</listener-class>
</listener>
which causes:
16:31:49,941 ERROR ContextLoader:313 - Context initialization failed
java.lang.ExceptionInInitializerError
	at org.springframework.context.support.AbstractRefreshableApplicationContext.createBeanFactory(AbstractRefreshableApplicationContext.java:195)
	at org.springframework.context.support.AbstractRefreshableApplicationContext.refreshBeanFactory(AbstractRefreshableApplicationContext.java:128)
	at org.springframework.context.support.AbstractApplicationContext.obtainFreshBeanFactory(AbstractApplicationContext.java:522)
	at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:436)
	at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:385)
	at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:284)
	at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:111)
	at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4205)
	at org.apache.catalina.core.StandardContext.start(StandardContext.java:4704)
	at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053)
	at org.apache.catalina.core.StandardHost.start(StandardHost.java:840)
	at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:463)
	at org.apache.catalina.core.StandardService.start(StandardService.java:525)
	at org.apache.catalina.core.StandardServer.start(StandardServer.java:754)
	at org.apache.catalina.startup.Catalina.start(Catalina.java:595)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
	at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
	at org.springframework.beans.factory.support.DefaultListableBeanFactory.<clinit>(DefaultListableBeanFactory.java:106)
	... 22 more
02.04.2012 16:31:49 org.apache.catalina.core.StandardContext listenerStart
SCHWERWIEGEND: Exception sending context initialized event to listener instance of class org.springframework.web.context.ContextLoaderListener
	... 22 more
02.04.2012 16:31:49 org.apache.catalina.core.StandardContext start
SCHWERWIEGEND: Error listenerStart
SCHWERWIEGEND: Context [/docadmin] startup failed due to previous errors
02.04.2012 16:31:49 org.apache.catalina.core.ApplicationContext log
INFO: Closing Spring root WebApplicationContext
02.04.2012 16:31:49 org.apache.catalina.core.StandardContext listenerStop
SCHWERWIEGEND: Exception sending context destroyed event to listener instance of class org.springframework.web.context.ContextLoaderListener
java.lang.IllegalStateException: BeanFactory not initialized or already closed - call 'refresh' before accessing beans via the ApplicationContext
	at org.springframework.context.support.AbstractRefreshableApplicationContext.getBeanFactory(AbstractRefreshableApplicationContext.java:172)
	at org.springframework.context.support.AbstractApplicationContext.destroyBeans(AbstractApplicationContext.java:1066)
	at org.springframework.context.support.AbstractApplicationContext.doClose(AbstractApplicationContext.java:1040)
	at org.springframework.context.support.AbstractApplicationContext.close(AbstractApplicationContext.java:988)
	at org.springframework.web.context.ContextLoader.closeWebApplicationContext(ContextLoader.java:556)
	at org.springframework.web.context.ContextLoaderListener.contextDestroyed(ContextLoaderListener.java:142)
	at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4244)
	at org.apache.catalina.core.StandardContext.stop(StandardContext.java:4879)
	at org.apache.catalina.core.StandardContext.start(StandardContext.java:4749)
16:31:49,955  WARN XmlWebApplicationContext:1028 - Exception thrown from ApplicationListener handling ContextClosedEvent
java.lang.IllegalStateException: ApplicationEventMulticaster not initialized - call 'refresh' before multicasting events via the context: Root WebApplicationContext: startup date [Mon Apr 02 16:31:49 CEST 2012]; root of context hierarchy
	at org.springframework.context.support.AbstractApplicationContext.getApplicationEventMulticaster(AbstractApplicationContext.java:337)
	at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:324)
	at org.springframework.context.support.AbstractApplicationContext.doClose(AbstractApplicationContext.java:1025)
16:31:49,956  WARN XmlWebApplicationContext:1036 - Exception thrown from LifecycleProcessor on context close
java.lang.IllegalStateException: LifecycleProcessor not initialized - call 'refresh' before invoking lifecycle methods via the context: Root WebApplicationContext: startup date [Mon Apr 02 16:31:49 CEST 2012]; root of context hierarchy
	at org.springframework.context.support.AbstractApplicationContext.getLifecycleProcessor(AbstractApplicationContext.java:350)
	at org.springframework.context.support.AbstractApplicationContext.doClose(AbstractApplicationContext.java:1033)
You can download project from sourceforge.net it's name is docadmin
Re: get rid of -Djava.endorsed.dirs=&quot;/opt/local/share/java/tomcat6/endorsed&quot; [message #834915 is a reply to message #834899] Mon, 02 April 2012 10:48 Go to previous messageGo to next message
You might want to ask this in the WTP forum rather than the JDT one
(which is meant for the Java Development Tools and not issues running
things using Java), or just followup on StackOverflow.
You can't usually directly edit the launch configuration used by WTP's
Server Tools, though--being able to do so usually means you have an
alternate means of launching the server with which it's not involved
(e.g. Sysdeo). Is this something you've modified by opening the editor
for your server instance from the Servers View?
Nitin Dahyabhai
Eclipse WTP Source Editing and JSDT
IBM Rational
Re: get rid of -Djava.endorsed.dirs=&quot;/opt/local/share/java/tomcat6/endorsed&quot; [message #835024 is a reply to message #834915] Mon, 02 April 2012 13:49 Go to previous messageGo to next message
Yes, I opened the editor in the server's view by clicking "Open launch configuration". By the way it's an existing tomcat installation.
[Updated on: Mon, 02 April 2012 14:28] by Moderator
Re: get rid of -Djava.endorsed.dirs=&quot;/opt/local/share/java/tomcat6/endorsed&quot; [message #835170 is a reply to message #835024] Mon, 02 April 2012 18:02 Go to previous messageGo to next message
I'm dealing with an identical error. If you figure out the solution, please post. I will do the same.
Thanks!
Re: get rid of -Djava.endorsed.dirs="/opt/local/share/java/tomcat6/endorsed" [message #846564 is a reply to message #834899] Mon, 16 April 2012 03:10 Go to previous messageGo to next message
At the moment I debug with an ant build file and eclipse's external tools.
sourceforge.net/p/docadmin/code/HEAD/tree/trunk/build.xml
Re: get rid of -Djava.endorsed.dirs="/opt/local/share/java/tomcat6/endorsed" [message #846686 is a reply to message #846564] Mon, 16 April 2012 13:32 Go to previous message
Sorry for the delay in posts. My wife had a baby so I was out last week.
I made an interesting discovery regarding this error: It seems to be more related to the Tomcat instance than anything else.
I got annoyed at it and just deployed to production (not the best practice, I know) but it ran on production! Now the question is, what is different.
So far I've verified that:
1. the same JRE and JDK are installed on production and my test environment (1.6.31 in this case).
2. Same Tomcat configurations (in my case I just copied the tomcat directory from production)
3. All Endorsed jars are same version (again, copied)
I don't know if it will help you, but this has certainly boiled down the list of possibilities for me.
Previous Topic:problem with eclipse installation
Next Topic:Create a new xml file from java code
Current Time: Sat Jul 26 19:19:03 EDT 2025
Powered by FUDForum. Page generated in 0.04270 seconds
