Home » Modeling » OCL » allInstances, unrecognized variable
allInstances, unrecognized variable [message #834755] Mon, 02 April 2012 07:00 Go to next message
I have created an Invariant which works fine except using the allInstances Construct:
createInvariant("self.allInstances.var < 10");
The error is:
org.eclipse.ocl.SemanticException: Unrecognized variable: (allInstances)
Does anybody know why it's wrong?
In the Eclipse OCL Tutorial I read something about an extent Map. Do I have to use this?
Thank's!
Re: allInstances, unrecognized variable [message #834826 is a reply to message #834755] Mon, 02 April 2012 08:55 Go to previous messageGo to next message
allInstances is a type operation, so you should do
self.oclType().allInstances()
which might work with the new pivot-based OCL for which oclType() is
defined.
For the Ecore-based OCL you will need the explivit type:
MyType.allInstances()
In general allInstances() should be avoided wherever possible since it
involves a total search of an implementation-specific domain. Most uses
of allInstances() can be eliminated by placing the OCL in a more
suitable context.
Ed Willink
On 02/04/2012 12:00, fv fv wrote:
> The error is:
> have to use this?
> Thank's!
Re: allInstances, unrecognized variable [message #834916 is a reply to message #834826] Mon, 02 April 2012 10:51 Go to previous messageGo to next message
thank's for your reply.
I tried self.oclType().allInstances() but it produces the error:
org.eclipse.ocl.SemanticException: Cannot find operation (oclType()) for the type (MyClass)
It seems that only your second proposal remains but I don't understand it. For what does MyType stands?
Can you give me an example?
Sorry, I'm totally new to this.
Thank's
Re: allInstances, unrecognized variable [message #835055 is a reply to message #834916] Mon, 02 April 2012 14:39 Go to previous messageGo to next message
I wrote that oclType() is not implemented for the old Ecore-based
Eclipse OCL; you need the new experimental Pivot-based version in the
examples plugins. org.eclipse.ocl.SemanticException shows that you are
using the old code.
MyType is the known type of self, which from the error message appears
to be "MyClass".
Ed Willink
On 02/04/2012 15:51, fv fv wrote:
> Thank's
Re: allInstances, unrecognized variable [message #835700 is a reply to message #835055] Tue, 03 April 2012 11:09 Go to previous messageGo to next message
I've tried "MyClass.allInstances.var < 10", but the same error comes.
Are there other possibilities besides using the pivot version?
Another question appeared when reading the OCL Tutorial.
I have tried to use the library example project. It created the three projects:
org.eclipse.emf.examples.library
org.eclipse.emf.examples.library.edit
org.eclipse.emf.examples.library.editor
Then I created the following java class to parse an OCL Query as it is described in the tutorial (I should mention I used UMLEnvironmentFactory instead of the EcoreEnvironmentFactory because eclipse always told me that EcoreEnvironmentFactory cannot be resolved to a variable!?):
	import org.eclipse.emf.ecore.EClassifier;
	import org.eclipse.emf.ecore.EObject;
	import org.eclipse.emf.examples.extlibrary.EXTLibraryPackage;
	import org.eclipse.ocl.expressions.OCLExpression;
	import org.eclipse.uml2.uml.CallOperationAction;
	import org.eclipse.uml2.uml.Class;
	import org.eclipse.uml2.uml.Classifier;
	import org.eclipse.uml2.uml.Constraint;
	import org.eclipse.uml2.uml.EnumerationLiteral;
	import org.eclipse.uml2.uml.Operation;
	import org.eclipse.uml2.uml.Package;
	import org.eclipse.uml2.uml.Parameter;
	import org.eclipse.uml2.uml.Property;
	import org.eclipse.uml2.uml.SendSignalAction;
	import org.eclipse.uml2.uml.State;
	import org.eclipse.ocl.OCL;
	import org.eclipse.ocl.ParserException;
	import org.eclipse.ocl.helper.OCLHelper;
	import org.eclipse.ocl.uml.UMLEnvironmentFactory;
	public class LibTest {
		boolean valid;
		OCLExpression<EClassifier> query = null;
		public void parseOCLExpr() {
			 OCL<Package, Classifier, Operation, Property, EnumerationLiteral, Parameter, State, CallOperationAction, SendSignalAction, Constraint, Class, EObject> ocl;
			 UMLEnvironmentFactory umlEnv = new UMLEnvironmentFactory();
			 ocl = OCL.newInstance(umlEnv);
		    // create an OCL helper object
		    OCLHelper helper = ocl.createOCLHelper();
		    try {
		    // set the OCL context classifier
		    helper.setContext(EXTLibraryPackage.Literals.WRITER);
		   query = helper.createQuery("self.books->collect(b : Book | b.category)->asSet()");
		    // record success
		    valid = true;
		} catch (ParserException e) {
		    // record failure to parse
		    valid = false;
		    System.err.println(e.getLocalizedMessage());
		    e.printStackTrace();
			LibTest a = new LibTest();
			a.parseOCLExpr();
But I just get the following exception:
Exception in thread "main" java.lang.NoClassDefFoundError: lpg/runtime/RuleAction
	at java.lang.ClassLoader.defineClass1(Native Method)
	at java.lang.ClassLoader.defineClassCond(Unknown Source)
	at java.lang.ClassLoader.defineClass(Unknown Source)
	at java.security.SecureClassLoader.defineClass(Unknown Source)
	at java.net.URLClassLoader.defineClass(Unknown Source)
	at java.net.URLClassLoader.access$000(Unknown Source)
	at java.net.URLClassLoader$1.run(Unknown Source)
	at java.net.URLClassLoader.findClass(Unknown Source)
	at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
	at LibTest.parseOCLExpr(LibTest.java:35)
	at LibTest.main(LibTest.java:61)
Caused by: java.lang.ClassNotFoundException: lpg.runtime.RuleAction
	... 14 more
The reason for this seems to be the line:
Does anybody know what I did wrong?
Thank's.
[Updated on: Tue, 03 April 2012 11:15] by Moderator
Re: allInstances, unrecognized variable [message #835766 is a reply to message #835700] Tue, 03 April 2012 12:38 Go to previous messageGo to next message
Comments below
On 03/04/2012 16:09, fv fv wrote:
Read the earlier comments and use allInstances().
The, I've no idea what .var < 10 is supposed to do since .var is an
implicit collect and so returns a collection that cannot be compared
with an integer.
> projects:
> described in the tutorial:
> boolean valid;
> try {
> query =
> // record success
> valid = true;
> valid = false;
> public static void main(String[] args) {
> a.parseOCLExpr();
> at java.security.AccessController.doPrivileged(Native Method)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> ... 14 more
It looks as if lpg.runtime is missing, which is because you are using a
Java application rather than an Eclipse plugin project, which I
recommend since it has a MANIFEST that sorts nearly all the classpath
problems out. If you use Jav projects you have to solve all these
problems yourself. Fix the classpath.
Ed Willink
Re: allInstances, unrecognized variable [message #840595 is a reply to message #835766] Tue, 10 April 2012 05:28 Go to previous messageGo to next message
now, both the query and the library example works Smile
My next step is to create a Syntax Tree of an OCL Expression.
I read the article: www.eclipse.org/articles/printable.php?file=Article-HowToProcessOCLAbstractSyntaxTrees/index.html
In this article the OCLAstView is mentioned.
I extracted OCLASTView_1.0.0.jar and copied OCLASTView.jar in the plugins folder. Now I have the OCL Ast View as it is depicted in the tutorial.
I thought I just have to select an invariant in an ecore file and the OCL Ast View is updated (as it looks like in figure 1 in the tutorial). But nothing happens.
How do I have to use the View?
Re: allInstances, unrecognized variable [message #840596 is a reply to message #835766] Tue, 10 April 2012 05:28 Go to previous messageGo to next message
No Message Body
[Updated on: Tue, 10 April 2012 05:29] by Moderator
Re: allInstances, unrecognized variable [message #840630 is a reply to message #840595] Tue, 10 April 2012 06:05 Go to previous messageGo to next message
That article was written in 2007 and led to the MDT/OCL Tools project
proposal which failed to progress past the creation review. That article
should not be linked to from current Eclipse OCL Documentation.
The main MDT/OCL project now provides many of the tools envisaged by the
proposed project:
- editors
- code generator
The new Xtext-based editors have an Outline view.
The article predates Xtext and so is very misleading about what can be
done with the new pivot-based UML-aligned Eclipse OCL. It may however
provide an example of the use of visitors, but in a clumsy fashion since
EClass is not visitable whereas org.eclipse.ocl.examples.pivot.Class is.
In general, synchronization of meta-model evolution is not supported by
EMF, and while many tools successfully make it work, useful
functionality is currently a bonus. Within Eclipse OCL, I was surprised
to find that the OCLinEcore editor updates when the *.ecore file is
changed externally. I know that the Console View does not update
correctly. I'm not surprised that the view in the old tutorial fails to
update.
Ed Willink
On 10/04/2012 10:28, fv fv wrote:
> now, both the query and the library example works :)
> I read the article:
> tutorial.
Re: allInstances, unrecognized variable [message #840955 is a reply to message #840630] Tue, 10 April 2012 14:20 Go to previous messageGo to next message
thank's for your explanation.
After searching for the possiblities of creating an OCL Syntax Tree, I came across the AbstractVisitor Class. I also read something about the classes "OCLAnalyzer" and "CSTNode", would these classes also come into consideration for creating a syntax tree?
I'd be glad to hear your opinion (maybe you know some other classes/tutorials/examples ..?) on this.
Thank's,
Re: allInstances, unrecognized variable [message #840991 is a reply to message #840955] Tue, 10 April 2012 15:18 Go to previous messageGo to next message
I've no idea what you're actually trying to do.
But I'm pretty sure it has nothing to do with "allInstances,
unrecognized variable".
Ed Willink
On 10/04/2012 19:20, fv fv wrote:
> Thank's,
Re: allInstances, unrecognized variable [message #841387 is a reply to message #840991] Wed, 11 April 2012 04:33 Go to previous messageGo to next message
I want to create a Syntax Tree (e.g. an XML File) of an arbitrary OCL Expression.
Re: allInstances, unrecognized variable [message #841447 is a reply to message #841387] Wed, 11 April 2012 06:09 Go to previous message
The syntax tree is already created, you just need to grab its resource
and save it.
Ed Willink
> Expression.
Previous Topic:Avoiding 'import' in CompleteOclEditor using OCL Registry?
Next Topic:Problem when using ereference to another registered package
Current Time: Fri Nov 07 16:56:11 EST 2025
Powered by FUDForum. Page generated in 0.05881 seconds
