Home » Eclipse Projects » Equinox » Rationale for using Equinox
Rationale for using Equinox [message #83439] Sat, 17 February 2007 17:13 Go to next message
Originally posted by: s0347354.sms.ed.ac.uk
I am writing a report and am trying to get my head around the reasons
for using Equinox's HTTP service (and other bundles) for hosting a web
application whose servlets interact with plugins of the Eclipse platform.
When the HTTP Service (and the underlying web server- Jetty) bundle is
started, does it exist in the same JVM as the Eclipse platform?
Is this the easiest/best (and only way) to interact with Eclipse plugins
from a java based web server, or are there other good options (I think
RPC or Java's RMI could also do the same job no?).
Thanks for any clarification/ pointers!
Re: Rationale for using Equinox [message #83454 is a reply to message #83439] Sun, 18 February 2007 07:00 Go to previous messageGo to next message
Originally posted by: tonimenzel.gmx.de
Hi!
First quick answer to the first question: "..same VM.." yes
This is because equinox is basically an OSGi framework implementation
which in turn is all about a single VM.
The OSGi Framework describes itself as "the dynamic modul system for
Java" (www.osgi.org)
More detailed, the framework is divided into 4 layers with each of them
giving a certain benefit over traditional java approaches (details at
http://www.osgi.org/osgi_technology/index.asp?section=2)
The most advanced layer used in the eclipse world is probably the
module-layer which all about bundles and its dependencies to eachother.
(in eclipse world bundles are called plugins).
For the question "remoting question": sure, its usually not a bad
solution using remoting to separate layers but it depends on what kind
of functionality/plugins you are going to use from the eclipse platform.
This platform is basically an application-level on top of osgi providing
more coarse grained functionality.
You should know that that OSGi does not describe an application model
because it describes and does things on a very low level with fine
granularity.
At a low level, usually called modules or components, osgi/equinox
provides a proven architecture which rolls into the server-enterprise
class more and more. But those adopters are more things like containers
itself (tomcat,geronimo), application models like spring and of cause
the eclipse platform. You see, those adopters are all platforms itself.
At the end it depends on your specific application (how much are you
thinking of platforms) and on the part you want to use from eclipse
platform.
Googling for equinox and osgi give you lots of material for your report
to think about.. ;-)
kind regards, Toni
Re: Rationale for using Equinox [message #83467 is a reply to message #83454] Sun, 18 February 2007 07:31 Go to previous message
Thanks very much! That is plenty to get me started... I've googled a
fair bit, and you have clarified my understanding of the OSGi framework.
Thanks again!
Seba
Toni Menzel wrote:
> Hi!
> granularity.
> platform.
> kind regards, Toni
>> plugins from a java based web server, or are there other good options
>> (I think RPC or Java's RMI could also do the same job no?).
Previous Topic:coding to org.osgi.framework only...what will I lose versus org.eclipse.core.runtime?
Next Topic:A DS service is available as soon as the host bundle is RESOLVED?
Current Time: Sat Jul 26 10:39:47 EDT 2025
Powered by FUDForum. Page generated in 0.07460 seconds
