task.setParameterValue [message #831080] |
Wed, 28 March 2012 08:50  |
Hi! I have a problem.
I want set param on xml, its Date type. Date Format: yyyy-MM-dd
And I see interested error
SEVERE: org.eclipse.birt.report.engine.api.impl.ParameterValidationException: The type of parameter "DateParameter" is expected as "date", not "java.util.Date".
fragment code
if (p.type.equals(Param.TYPE_DATE))
SimpleDateFormat formatter = new SimpleDateFormat("yyyy-MM-dd");
formatter.setLenient (false);
try
Date date = formatter.parse(Date2SQL(p.value));
task.setParameterValue(paramName, date);
catch (Exception Ex)
fragment xml
<scalar-parameter name="DateParameter" id="98">
<text-property name="promptText">Дата</text-property>
<property name="valueType">static</property>
<property name="dataType">date</property>
<property name="distinct">true</property>
<simple-property-list name="defaultValue">
<value type="constant">2001-12-31</value>
</simple-property-list>
<list-property name="selectionList"/>
<property name="paramType">simple</property>
<property name="controlType">text-box</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
Re: task.setParameterValue [message #832187 is a reply to message #831603] |
Thu, 29 March 2012 18:02   |
The Date parameter should be able to take a java.sql or java.util date.
Can you post the complete stack trace?
Jason
On 3/29/2012 12:56 AM, Sergey Syr wrote:
> Interested moment
> thats void, continue..
> if (p.type.equals(Param.TYPE_DATE_TIME))
> { SimpleDateFormat formatter = new SimpleDateFormat("yyyy-MM-dd HH:mm");
> try
> Date date = formatter.parse(p.value.replaceAll(p.value.substring(0, 10),
> Date2SQL(p.value.substring(0, 10))));
> task.setParameterValue(paramName,date);
> This fragment work!
> I see my changed DataTime parameter on report form
> p.value - String parameter value from enter form
> Date2SQL - formated String from "dd.MM.yyyy" to "yyyy-MM-dd"
> Date2SQL(p.value.substring(0, 10)))) - formated String from "dd.MM.yyyy
> HH:mm" to "yyyy-MM-dd HH:mm"
> what do you think about IScalarParameterDefn.TYPE_DATE ?
Re: task.setParameterValue [message #836124 is a reply to message #835714] |
Wed, 04 April 2012 01:08   |
DateTime type mismatching for Date parameter, because working another handler
DateTime type working totally normal.
SimpleDateFormat formatter = new SimpleDateFormat("dd.MM.yyyy HH:mm");
try
Date date = formatter.parse(p.value);
SimpleDateFormat formatter = new SimpleDateFormat("dd.MM.yyyy");
try
if (p.type.equals(Param.TYPE_DECIMAL))
Double n = Double.parseDouble(p.value.replace(',', '.'));
task.setParameterValue(paramName, n);
if (p.type.equals(Param.TYPE_INTEGER))
task.setParameterValue(paramName, (new Integer(p.value)));
//...etceteras, and so forth, and so on...
FUDForum. Page generated in 0.27319 seconds
