Home » Modeling » OCL » errors in Eclipse Modeling Tools for Indigo Packages
errors in Eclipse Modeling Tools for Indigo Packages [message #833970] Sun, 01 April 2012 03:29 Go to next message
I download the Eclipse Modeling Tools for Indigo Packages. And try to install the OCL Examples and Editors from the help->install new software in Eclipse. But during the installing, it shows some errors as follows:
An error occurred while collecting items to be installed
session context was:(profile=epp.package.modeling,
phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=,
action=).
Comparison method violates its general contract!
I just feel puzzled, and for my experiment I need this tool. so I hope someone can give me some solutions. Thanks sincerely.
Re: errors in Eclipse Modeling Tools for Indigo Packages [message #834021 is a reply to message #833970] Sun, 01 April 2012 05:09 Go to previous messageGo to next message
Hi Lucy
I've never seen this problem, but rummaging through Bugzilla it would
appear to be commonly related to an Eclipse 3.7.0 to 3.7.1 upgrade using
Java 7. There is a workaround in
https://bugs.eclipse.org/bugs/show_bug.cgi?id=317785#c45. However
https://bugs.eclipse.org/bugs/show_bug.cgi?id=364735 suggests there is
some outstanding issue.
If you are indeed upgrading from 3.7.0, try the workaround. Otherwise
try just installing 3.7.2 directly.
Ed Willink
Re: errors in Eclipse Modeling Tools for Indigo Packages [message #834053 is a reply to message #834021] Sun, 01 April 2012 06:16 Go to previous messageGo to next message
Dear Ed Willink,
I have solved the problem by using a lower edition. I feel so thankful for your support these days. Your help is greatly appreciated. I will keep contact in this forum. Thanks very much.
Best Regards
Lucy
Re: errors in Eclipse Modeling Tools for Indigo Packages [message #834096 is a reply to message #834053] Sun, 01 April 2012 07:49 Go to previous message
Hi Lucy
Glad the problem's solved.
For my (other's) benefit could you identify the Platform, EMF and OCL
versions you were trying to use.
At present OCL is very restrictive on exact versions. Some other
projects such as Acceleo and Xtext are much more tolerant. I would like
to be more tolerant on OCL too.
Ed Willink
On 01/04/2012 11:16, Lucy Chan wrote:
> Dear Ed Willink,
> Best Regards
> Lucy
Previous Topic:problems about EMF Incubating components
Next Topic:A strange result in OCL query
Current Time: Fri Nov 07 16:56:17 EST 2025
Powered by FUDForum. Page generated in 0.05586 seconds
